Old 11-18-2016, 05:51 PM   #1
ender2664
Drives: 2016 2SS
My car wouldnt start
I just got done with a 4 hour drive, 1.5 in bumper to bumper and my car wouldnt start :/
I pulled her into the garage, went inside for 5 mins, tried to start her and no luck. It didnt even sound like she was attempting to use the starter. I pressed the ignition button, clutch down of course, and she just made the same exact sound as when I press the button to only turn on the power.
I popped the hood, waited another 15 mins and now she starts right up. Any clue what that was about?
ender2664 is offline   Reply With Quote
Old 11-18-2016, 06:09 PM   #2
kseguin
kseguin's Avatar
Drives: 2017 2SS MRC NPP
I have the same thing happen. It said it could not detect a remote even though it was in my pocket. The second time I walked away from the car and then walked back to it and it started. There are other posts about this.
2017 2SS MRC NPP
kseguin is offline   Reply With Quote
Old 11-18-2016, 06:16 PM   #3
ender2664
Drives: 2016 2SS
Ty
Old 11-18-2016, 09:20 PM   #4
CamarosThree
CamarosThree's Avatar
Drives: 2010 SSRS 97 Camaro SS 1969 Camaro
Could be due to interference from a cell phone in close proximity.
Celebrating Life One Day at a Time
CamarosThree is offline   Reply With Quote
Old 11-18-2016, 10:44 PM   #5
ender2664
Drives: 2016 2SS
Ty
Old 11-18-2016, 11:02 PM   #6
camaro5
camaro5's Avatar
Drives: X-15 Velocipede
Sounds like a starter motor "hot-soak" problem.
I've read about slow cranking when hot, but this is the next level after slow - no crank.
Opened the hood, let it cool and then it started. That's hot-soaked starter.
Possible remedies -
Heat shield, or better heat shield for starter.
Maybe your starter is a little weak, possible replacement
3rd gens actually got a little fan to blow on carbs after shut off. They boiled fuel and ran bad. Little fan from factory was created to cool and prevent hot-soak, it went on when key was off.
Bigger battery - not likely to fix it
camaro5 is offline   Reply With Quote
Old 11-19-2016, 06:04 AM   #7
raptor5244
Drives: 2022 CT4-V Blackwing
Possible remedies -
I think you are right. I experience similar issues. I haven't got to the point where it wouldn't crank at all but I notice on cold start the starter turns over strong and fast but if I am running errands and have to keep stopping for short periods with a few frequent startups the starter will feel sluggish to turn over. However, like you mentioned if I let it sit for a while and cool it will cranks over fast. Battery is good.
2019 Tesla Model 3
2022 CT4-V Blackwing - M6
Old 11-19-2016, 08:55 AM   #8
ender2664
Drives: 2016 2SS
Possible remedies -
I figured it was correlation and not causation which is why I asked.
I have a hard time buying it is heat soak considering I never have the problem in the summer in the desert. But regardless of what I want to buy, I'll listen to the concensus.
Old 11-19-2016, 09:04 AM   #9
Heavymetal454
Drives: '69 RS Pro Street
Check the resistance of the ground cable from the battery. If it's fried the hot condition puts more load on the starter and it may be incapable of sustaining a high amperage draw when cranking.
Heavymetal454 is offline   Reply With Quote
Old 11-19-2016, 09:06 AM   #10
NUCAR
Drives: 68 big block
If this is a 2016, get it looked at under warranty....
NUCAR is offline   Reply With Quote
