Old 11-17-2016, 04:17 PM   #1
cohete_camaro
Drives: 2018 Camaro 2ss Red Line Edition
Air conditioner
Anyone else Autostart their car, and the air is somehow on full blast ?
cohete_camaro is offline   Reply With Quote
Old 11-17-2016, 04:23 PM   #2
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Normal, It thinks you want a quick cool down....
Old 11-17-2016, 04:26 PM   #3
cohete_camaro
Really ? That's normal ? Ok...gonna have to take your word for it...lol
Old 11-17-2016, 04:34 PM   #4
crazydmc
ummmm
crazydmc's Avatar
Drives: 2016 2SS M6 Nightfall w/Blk Wheels
I think you can set the max fan speed somewhere in the settings...
crazydmc is offline   Reply With Quote
Old 11-17-2016, 04:35 PM   #5
enzia35
Drives: '16 Garnet Red 1SS
What's autostart? Jk...
'16 Camaro 1SS
'18 Miata GT
Old 11-17-2016, 06:46 PM   #6
clrkmr
Drives: 2017 50th Anniversary
It should come on to the last setting when you turned your car off. If you have it set in auto and a low temp (say 66 degrees) and it is 100 degrees out, it will come on full blast, as an example. If your fan was on high when you turned it off, it will be on high when you auto (remote) start it. As was stated above, there is also a max fan speed setting for remote start. From page 35 of the 2017 manual:
The climate control system will use
the previous settings during a
remote start. The rear window
defogger and heated seats,
if equipped, may also come on. See
“Remote Start Auto Heated Seats”
under Heated and Ventilated Front
Seats on page 60 and Vehicle
Personalization onpage 144.
clrkmr is offline   Reply With Quote
Old 11-17-2016, 11:57 PM   #7
kasperdsmk
Drives: Hopeful 2017 2ss
it will auto set the interior temp based on the outside temp.. i think if it its over 82 degrees if i recall it will put air on full blast and anything under 40 degrees full heat and heated seats..
kasperdsmk is offline   Reply With Quote
Old 11-18-2016, 09:31 AM   #8
BigEnos
Planning stages...
Drives: 1995 Z28,2014 Ford Focus ST
Our 2008 Tahoe used to do that sort of thing also, but once you put the key in it would go back to previous settings. Nice in the winter all the defrosters would turn on and the seat heaters would be nice and toasty. Miss that thing.
BigEnos is offline   Reply With Quote
