![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS Join Date: Jul 2016
Getting it done on the stock tires, FINALLY
I got to the track today. I was extremely disappointed that I couldn't get my DR rims to fit. I almost didn't go. Anyway, I am glad I did. I only got a couple passes in before it started raining. The car has my ported Int/TB, Roto-fab dry filter CAI, and I tuned it. It is full weight on the stock rims and tires. I had about a half tank of gas. The car was only cooled down long enough for me to air down the rear tires, air up the front tires, pull the intake manifold cover and pay to run. I got in the lanes immediately to avoid the weather. Coolant temp was in the high 190's to low 200's. The IATs were in the high 70's at the beginning of the run.
The first pass would have been in the 11.6's but it spun the 1/2 shift. The second pass was hot lapped. I stalled the car to 2K, let off the break and hit the gas pretty quickly. Since the track was so bad last time I was hesitant to get into it to hard. Looking at the log I was only seeing .91g/cyl so I was down a bit of power to my last dyno runs where I was seeing .97g/cyl. The trans was short shifting 4/5 and it was dropping the rpm down into a low timing point. I was in the middle of correcting all of that when the rain started. DA was around 0 to -200. The Kestrel was having issues depending on which way I pointed. It was closer to 0 according to the interwebs. The g/cyl really tells the story. I am very happy with the way the car preformed. I honestly think I would have been in the 11.50's if I could have implemented my tuning changes and got more aggressive with the launch. The track would have taken it today.
Great runs, but without those drag radials or slicks its gonna be tough get your 60 ft times down to get that 11.60 you wanted
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
Nice job!
![]() Drives: 2016 Camaro 1SS A8, 1998 K1500 5spd Join Date: Aug 2010
Nice runs! I've been saying these cars have 10 second potential with bolt ons. My guess is we will see a few dip into the 10's soon! With a converter, drag radial, and e85 you would be close.
*2016 1SS A8-12.100 @115 Bone Stock.
11.54 @116 with cat delete, converter and dr's Previous Rides 2010 Camaro 1SS M6-12.14 @114 Bolt Ons 2014 GMC Sierra SLT 5.3/6L80 |
#5 | |
I still say I can get to 11.50's as in on the stock tires. I just need the weather. It is coming. We get some serious neg DA days here. If I can see the g/cyl I saw on the dyno just the extra power alone will be worth a tenth or more. I will be moving to a drag pack soon or at least a DR. Just want to see what I can do on the stock stuff. I am hard headed.
As soon as guys are willing to tune you will see plenty of 10 sec bolt on cars. Just look at how crazy fast some of these guys are going with just a drag pack and a bolt on or two. Headers and E85 should be worth 50+rw on my car. Add a legit drag pack and I personally don't see a need for a converter at that point. 10's in good weather.
#7 |
#8 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
#9 | |
Looking at my dyno graph, at 3,000rpm my motor is making roughly 95% of the peak tq number that occurs between 4,300 and 4,700rpm. I think I can close that gap with some more tuning. I would have to start a dyno run at 2K so see how bad the tq number is down there. I would say a 3,500 stall would be ideal looking at my dyno graph.
#10 |
![]() ![]() Drives: 2016 Camaro 2SS Join Date: Mar 2016
Nice runs on stock rubber wait until the drag radials go on it is gonna drop into some great numbers.
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB Rotofab ARH 1 7/8 longtubes hi flow cats AFM deleted E85 11.0@124.9 11.65@118.8 pump gas,stock tune/exhaust New combo: Pray Performance Heads/cam MSD intake manifold and Circle D 3C 554/491 on E85 all work & tuning done by Pray |
#11 |
I too suspect 10s will be possible on the stock converter bolt on na with e85. Near full weight. Incredible.
I'm planning on a cf driveshaft as well. Every little bit helps. |
#12 |
FASTER!
Drives: Challenger Hellcat, 2SS Camaro Join Date: Apr 2008
More nice runs. Not sure about the love affair with the stock rubber, but whatever turns you on LOL
I did have my best 60' just smashing the gas as some have stated, it was marginally better at 1.88 vs 1.93. The car also spun and wheel hopped so harder on the equipment vs. me loading up on the brakes to about 1200RPM jumping off the brake and going to the floor with the throttle. I'm starting to wonder if the launch control instructions in the manual aren't 100% correct, of if GM just kinda noticed the car would do that during testing and called it launch control. My runs where I gently apply the brake and bring the RPMs up to 1200 or so are drama free no spin launches. |
#13 | |
I have tried a ton of stuff on the stock rubber. The technique I listed is the best for me and another guy that cuts 11.75's consistantly and had gone 11.83@116.8 bone stock. I think he has gone well into the 7.50's in the 1/8th. 24psi, light burn out, 2K stall, off break and onto the gas. Just hold on from there.
#14 |
FASTER!
I understand what you're saying. I think the challenge is the unknown variable of the track and how it's prepped. One track may have awesome prep and allow the stock tires to do something, where another may have none at all, like my local place, and the stock tires won't do too well. I got a 1.88 on the stock rubber which actually surprised me. Average street tire 60' is high 1.9 low 2.0 for most, so pretty dang good actually. With DR and slicks it takes a lot of the track prep variable out of the equation. You're pretty experienced, so I'm probably stating the obvious.
