Old 11-10-2016, 12:10 PM   #1
Randall08
Drives: 2016 Camaro RS
Engine power reduced!! Voteless throttle controller
So I have had the viteese throttle controller on my car for about 3-4 months now. Loves it and had zero issues until last night. Got off of work and started my car and the display screen says engine power reduced, the engine light came on and the throttle would not go over 3000RPM. Just wanted to give all of you a heads up that it may possibly happen to you if you have the controller installed. To fix it I just removed the throttle controller and then disconnected the main negative terminal for 30 min and then connected the terminal back. It's back to normal and the engine light is gone.
Randall08 is offline   Reply With Quote
Old 11-10-2016, 12:59 PM   #2
BowtieRocket
BowtieRocket's Avatar
Drives: 2016 Camaro 2SS- M6
2016 Camaro 2SS M6- Garage
BowtieRocket is offline   Reply With Quote
Old 11-10-2016, 01:07 PM   #3
fastball
Drives: 2017 Camaro 2SS 6MT
Aftermarket gizmos on today's high tech cars is just a little questionable.
fastball is offline   Reply With Quote
Old 11-10-2016, 01:12 PM   #4
I`m Batman
I`m Batman's Avatar
Drives: 2016 Camaro SS M6
I wonder if you can somehow put the car into "power reduced mode" on purpose. You can use it as valet mode.
I`m Batman is offline   Reply With Quote
Old 11-10-2016, 02:43 PM   #5
LibertyHill
LibertyHill's Avatar
Drives: 16 2SS 6MT NPP MRC / 15 K1300S
Is there any reason to believe the throttle controller had anything to do with the fault?
Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC
LibertyHill is offline   Reply With Quote
Old 11-10-2016, 04:06 PM   #6
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 2SS, 71 Std, Suburban RTS
Yup this can happen with the controller. I haven't had issues, but if setup goes wrong or maybe a power blip in the car throws it off, it can cause limp mode. Most people with the controller have issues upfront with a rushed setup job, this is the first I am hearing of issues beyond setup.
Mine has been going strong for 9 months now on this car. No issues yet.
Sledgehammer70 is offline   Reply With Quote
Old 11-10-2016, 05:03 PM   #7
Ruebernard
Ruebernard's Avatar
Drives: 2023 Radiant Red Tintcoat 2SS
Same here! I love mine.
If it were more fun, it would be illegal!
Ruebernard is offline   Reply With Quote
Old 11-10-2016, 07:06 PM   #8
Wolvie70
Wolvie70's Avatar
Drives: 2016 2SS, Summit White, A8, NPP
Seems like he used scientific methods to come to his conclusions.
Wolvie70 is offline   Reply With Quote
Old 11-10-2016, 07:14 PM   #9
JFM-jr
JFM-jr's Avatar
"I have had the viteese throttle controller on my car for about 3-4 months now.
I removed the throttle controller
It's back to normal and the engine light is gone."
seems to me not alot of science needed to come to a rational conclusion here
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB
Rotofab
ARH 1 7/8 longtubes hi flow cats AFM deleted E85
11.0@124.9
11.65@118.8 pump gas,stock tune/exhaust
New combo: Pray Performance Heads/cam
MSD intake manifold and Circle D 3C
554/491 on E85 all work & tuning done by Pray
JFM-jr is offline   Reply With Quote
Old 11-10-2016, 07:16 PM   #10
Richard0nee
Richard0nee's Avatar
Drives: 2016 SS M6, NPP
Lmao
Richard0nee is offline   Reply With Quote
Old 11-10-2016, 07:20 PM   #11
Michigan1LTRS
Blessed ❤️
Michigan1LTRS's Avatar
Drives: 2017 1LT RS I4
Yeah, but he also disconnected the battery for 30 minutes. So how do we know that alone would not have worked without removing the controller?
Old 11-10-2016, 07:51 PM   #12
sixbrx
Drives: 1SS Hyper Blue
Exactly, for all we know simply turning the car off and back on would have also made the issue go away at least for now.
sixbrx is offline   Reply With Quote
Old 11-10-2016, 09:55 PM   #13
synaptik
Drives: 2016 2lt RS
a lot of people complained of this on the 5th gen also. removing the throttle controller fixed it for them. its the only thing that has stopped me from ordering one as I know if it can go wrong .... it will happen to me
synaptik is offline   Reply With Quote
Old 11-10-2016, 10:31 PM   #14
Wolvie70
Wolvie70's Avatar
Clearly you are a scientist as well. I stand corrected.
