Custom cam, ported heads, other stuff. IT'S FINALLY FIXED.
I'm beyond excited. I was planning on going boost, but for now decided to build all motor. I'll lay out the details I have for now, but we're pushing for 500+rwhp on motor.
Car is a 2017 A8 1SS w/ NPP Comp Cam Custom VVT grind - 224/237 .585/.579 116 (looks like he changed specs without telling me too) Custom ported stock heads Hooker Blackheart 1 7/8" long tubes (he did shorties and not long tubes without telling me) Cold Air Inductions intake Dyno tune We're trying to keep the stock converter and keeping NPP (fuse is pulled). I'm dropping the car off next Thursday and picking it up the following Monday or Tuesday.
2017 1SS - Hyper Blue Metallic
Heads, Cam, e85, 3600 Stall, Full bolt-ons, MBRP exhaust 2010 2SS - Summit White - SOLD CAI intake, Borla Atak axle-back (Summit xpipe resonator delete), custom ported TB, Texas Speed 1 7/8" LT Headers w/ Catless connections Instagram: bravomyles Last edited by BravoMyles; 01-04-2017 at 08:38 PM. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
Awesome man.
If you aren't on e85 and with that smallish cam I don't see 500 rwhp with that build through an auto but who knows. No doubt it should run very strong and you should be happy Good luck ! |
Drives: 2016 2SS Camaro Join Date: Sep 2016
Just saw one finished at Vengeance Racing today. Ported heads, cam, long tubes, CAI, A8 car...
Picked up 100rwhp and sounded great. Cam wasn't that radical or it prob would have made more hp |
Hopefully we'll see 500+! I'm staying optimistic, not on e85 yet but would like to go flex eventually. That would help but it's not in the plan this go around.
Heads, Cam, e85, 3600 Stall, Full bolt-ons, MBRP exhaust 2010 2SS - Summit White - SOLD CAI intake, Borla Atak axle-back (Summit xpipe resonator delete), custom ported TB, Texas Speed 1 7/8" LT Headers w/ Catless connections Instagram: bravomyles |
#5 | |
![]() Drives: 2016 Chevy Camaro Join Date: Jun 2016
![]() ![]() ![]() ![]() ![]() Drives: ZL1 Join Date: Sep 2011
Was it blue lol
#7 |
![]() ![]() Drives: 2016 1SS, 2017 JKU Wrangler Join Date: Mar 2016
What did you spend?
SLO 1SS - sold
1SS MRC NPP 6MT 2018 Ram Rebel 4x4 5.7 |
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
that cam looks excellent for a fun stoplight setup.
i would say a 224 intake lobe in a LT1 would be similar to a 216-218 in a LS1...right? depending on the LSA, im gonna guess they went around 116 to keep the revs down for the AFM lifters and it will give it a little chop to the idle, anything in that range would be doable with the stock converter. can you give the LSA so we can see what the overlap looks like? |
#9 |
#10 |
I like the lower lift from a long term perspective. I went through all the rocker bearing failure, spring failure, and push rod failures in the late 90s with the LS-1. Don't want to be changing that stuff every 10,000 miles....
#11 | |
on a car you'll be putting miles on, if you want power, i would get it from the intake duration, but keep in mind at some point you'll driving up the overlap and be losing vacuum and drivability |
#12 |
Not sure
I saw VRs post that's why lol |
#13 | |
#14 |
![]() ![]() ![]() ![]() Drives: 2015 Tiger XCX,2016 Camaro 1SS,LBZ! Join Date: Sep 2015
When are you getting this done? I am curious to the cost as well. Looks like a nice way to gain solid long term power.
