Old 11-07-2016, 03:22 PM   #1
jrs580
jrs580's Avatar
Drives: 2016 2ss
Launch control and superchargers
Can anyone tell me how they launch after they install a supercharger? What happenes if you use the built in launch control?
2016 Black Camaro 2SS A8 Red interior
Modifications:Red powder coated Whipple LT1 blower, Aeroforce interceptor w/vent pod, FI Interchiller, Roto-Fab breather, ARH full length headers with high flow cats, JRE AFM modules, Borla S type NPP exhaust, Mishimoto catch can, JMS fuel pump voltage booster,MRR 017 1LE replica rims, 285/35zr20 Goodyear Eagle F1 G:2 front, Toyo r888r 325/30/zr20 back, Phastek blackout kit for the reflectors, GM dark tail lamps, Blendmount radar detector mount with Escort Redline hardwired in.
jrs580 is offline   Reply With Quote
Old 11-07-2016, 05:06 PM   #2
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
I don't have a supercharger but my tuner disabled the launch control software when the car was re-tuned, I'm not sure the brakes could hold the car with the tach over 2000 rpm..
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 11-07-2016, 05:25 PM   #3
Atomic Ed
Drives: 2001 Audi TT, 2016 Camaro
Like Jess said, not going to work well. I'm already at 450 ft.-lbs. of torque at 2500 rpm with a PD SC.
Atomic Ed is offline   Reply With Quote
Old 11-07-2016, 06:08 PM   #4
1LE801
"Lohla"
1LE801's Avatar
Drives: 2016 1SS A8 :"Lohla"
Too much toque for the car to accurately apply it. If the pedal is down, the boost will blow the tires off. Get rubber. Lots of it. I'm on 315 Contis and it's much better but still way to much power for them. A PD blower will necessitate Drag radials if you want to launch.
OG Trans and Diff but all else is upgraded. Twins bring wins ;-)
1LE801 is offline   Reply With Quote
Old 11-07-2016, 08:01 PM   #5
jrs580
jrs580's Avatar
Drives: 2016 2ss
So how do yall launch? From an idle?
Old 11-07-2016, 08:36 PM   #6
jessrayo
Speed Freak
jessrayo's Avatar
The last time I tried it I would just bring up the idle until I could hear the engine pushing on the resistance...but my 60 foot times were not great and I was using drag radials. I think I would do better bringing the revvs up some more and possibly hammering the gas just a little before releasing the brake.... but no drag racing for me again until spring 2017.
Old 11-08-2016, 09:53 AM   #7
jrs580
jrs580's Avatar
Drives: 2016 2ss
the speed shop that is installing the supercharger has told me none of the traction control, stabilitrak or launch control will be effected. I'm curious what happens if you put the car in competitive driving mode, mash the brake and stomp on the gas, i.e launch control.
Old 11-08-2016, 09:55 AM   #8
jrs580
jrs580's Avatar
Drives: 2016 2ss
actually what I'm wondering the most is how the heck the z06 corvette and zl1 manages to use all these features if the car "can't" pull enough power with the blower installed.
Old 11-08-2016, 10:09 AM   #9
1LE801
"Lohla"
1LE801's Avatar
To be fair, I live in Utah and the warmest temps I've seen since modifying he car have been 70 degrees. It does hook up much better the warmer it gets but there is still going to be plenty of tire spin on the street. The Z06 guys are experiencing much the same, I'm certain. If you read the magazines and reviews, typically the best times are found when not using launch control. It takes lots seat time to be able to get the most out of cars with this much power.
Old 11-08-2016, 12:33 PM   #10
jrs580
jrs580's Avatar
Drives: 2016 2ss
I'm most worried about the safety aspect. I don't want to gun it just a little too much on thw highway and the traction control not stop the wheel spin.
Old 11-10-2016, 10:52 AM   #11
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
I played around on the stock tires when I got my car back. I put it into competitive mode and tried to keep RPM's slightly below 2500, stayed on flat road so the car didn't roll, and drop the clutch.
I haven't tried it since getting my Forgelines...not about interested in roasting my Pilot Super Sports lol
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge
93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno)
LesBaer is offline   Reply With Quote
Old 11-10-2016, 11:12 AM   #12
GirlyNFG
GirlyNFG's Avatar
Drives: 2016 Camaro SS M6 w/ NPP
I have tried it on the street and the track. On the track it was .01 difference from my launch. On the street it did feel better using the onboard launch control
Whipple 2.9, Custom New Era Performance cam,
E85, LT4 fuel system, Motec powered port injection, teeny tiny Nitrous Outlet system,
Stainless Works LTs, Centerforce Triad, GForce 9" with strange pro case 3.50 gears. Carlyle 15" conversion
28"x10.5" MT ET Drag 28"x4.5" M&H fronts
PB: 9.569 @ 151.05
GirlyNFG is offline   Reply With Quote
Old 11-10-2016, 11:36 AM   #13
cleoent
cleoent's Avatar
Drives: 16' Camaro E-Force SS
Anyone with an 8A try this? At 2000 rpms, even stock there's probably enough power to override the brakes, but launch control limits that power for optimal acceleration. Would be interested to see how it works with a SC.
cleoent is offline   Reply With Quote
Old 11-11-2016, 12:53 AM   #14
1LE801
"Lohla"
1LE801's Avatar
I'll give it a shot but I see smoke in my future lol
