Old 11-05-2016, 07:28 PM   #1
PRAY
PRAY's Avatar
Drives: 2016 2SS
Gains with Roto-fab.
I tested the Dry filter today with the box sealed up as designed. I was impressed with the gains. No matter how you slice it, I got an average gain of 13/15rw with the fuel staying the same. The data matches up to the numbers. It was double checked against other cars data with the same numbers. We will see what I get at the track tomorrow. I think my gains were higher than normal due me porting my Int/TB and the gains I saw with those. I would say that and average of 6-10rw should be expected with the ability that most people have to regulate dyno data and stock cars or programming.
Old 11-05-2016, 07:53 PM   #2
Roto-fab 1
Roto-fab 1's Avatar
Awesome gains! Thanks for sharing.
Michael
Old 11-05-2016, 08:01 PM   #3
PRAY
PRAY's Avatar
Drives: 2016 2SS
I will get some track logs tomorrow for a more realistic street view of what is going on. I really want to see if my Dyn/Cyl goes up and my MAP KPA goes down to what I was seeing on the dyno today. If the MAP stays up and the Dyn/Cyl takes another uptick then this thing is doing its job in the real world. I will have the WB hooked up as well. Should be interesting to see what the logs say at speed.
Old 11-05-2016, 08:41 PM   #4
Razor2SS
Drives: 2017 1SS
Wow impressive combo/gains, time for E85. Can't wait to see the improvement at the track.
Razor2SS is offline   Reply With Quote
Old 11-05-2016, 09:47 PM   #5
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
Why would you see a gain below 3k rpm where flows are relatively low? That doesn't make sense to me.
Old 11-05-2016, 10:49 PM   #6
My87z28
Drives: 1987 Z28, 385cid, '16 Camaro 1SS
Pray,
I know that you initially tuned the car before putting the ported intake and TB on, was there any retuning done afterwards. Also was there any retuning done after installing the CAI?
I like many others want to retain the factory warranty for at least the first 10-15k miles. Since my car is not a daily driver, that may take me 3 years or so see. The ported intake, TB, and CAI (along with cat back which I have already) are very enticing, since you are seeing gains. However, how are these things (in your opinion) going to do together on a stock tune?
02/23/16: 1100, 03/16/16: 2500 # TGHR6N
03/16/16: 2500, 03/18/16: 3000 TPW : 4/11/16
04/8/16: built & VIN 04/11/16 - 04/28/26 : 4B00 Bayed QC hold, 04/29/16 : 4200 Rail yard
'16 1SS 6M, black with jet black interior, split spoke gray machined faced wheels, and black front/rear bowtie emblems.
My87z28 is offline   Reply With Quote
Old 11-06-2016, 06:09 AM   #7
PRAY
PRAY's Avatar
Drives: 2016 2SS
Possibly because my air demand is already higher than stock. Possibly because there is more air available from the RF just by sheer size and volume of the tube. Air is a slinky and volume does matter at TB opening. Same goes for heads. Larger runners store more air behind the closed intake valve. As soon as the valve cracks there is more air present to fill the cylinder. This makes more power from the hit. From what I have seen, more air at any point makes more power. Same thing happened when I swapped my ported int/tb. My gains were from beginning to end.
Old 11-06-2016, 06:17 AM   #8
PRAY
PRAY's Avatar
Drives: 2016 2SS
Originally Posted by My87z28 View Post
Pray,
I did tune the car pre int/TB and it was tuned pre Roto-fab. In both cases the AFR and timing didn't change and both times I saw the gains I posted. Tuning didn't help anything over what was already done. What I can't attest to is what the stock tune will do or tolerate. I can only ASSUME that everything will be fine based off of my street and dyno logs. There are guys running my Int/TB right now that made great gains at the track on stock tunes. One is getting a RF for track passes this weekend. I am sure he will post what he gets out of it. I personally think that my int/TB and a RF will be a great addition to anyone who doesn't want to tune. I honestly think 20+rw would be the minimum you would see. But I am only speculating and basing my speculations off of the dyno numbers I have seen and the data I collected after many dyno and track runs. That combo is still less than a MSD and honestly crushes it up to 6,200.
On my car I have seen a gain of 30/33rw over the stock tuned base line with just my ported stock Intake Manifold, ported stock TB and the Roto-fab with the Dry filter.
Old 11-06-2016, 09:33 AM   #9
My87z28
Thank you Pray
Old 11-06-2016, 09:55 AM   #10
BowtieRocket
BowtieRocket's Avatar
Drives: 2016 Camaro 2SS- M6
Looks to me the tune and porting had more to do with gains than the CAI. Hard to understand why you titled this thread as "Gains with Roto-fab"... Good info on the other mods though!
2016 Camaro 2SS M6- Garage
BowtieRocket is offline   Reply With Quote
Old 11-06-2016, 10:06 AM   #11
PRAY
PRAY's Avatar
Drives: 2016 2SS
Sorry if the post is confusing. The test and gains posted in the graph above were with only swapping the Roto-fab. Car was previously tuned and the int/TB testing had already been done. The int/tb/tune are the base line numbers in the graph.
Old 11-06-2016, 10:08 AM   #12
PRAY
PRAY's Avatar
Drives: 2016 2SS
E85 is next but it will only be for testing. No stations near me to make it at all worth it.
Old 11-06-2016, 10:13 AM   #13
EFI Tuning
EFI Tuning's Avatar
Drives: 2016 Camaro SS
The intake and TB will be available through us very soon.
Tim
EFI Tuning is offline   Reply With Quote
Old 11-06-2016, 10:14 AM   #14
EFI Tuning
EFI Tuning's Avatar
You are 20 minutes too far out. LOL
You will want it for the track
