Old 11-01-2016, 10:28 AM   #1
shrubby
shrubby's Avatar
Drives: 16' Black³ / 18' ZL1 1LE
Traction improvement
Wasn’t sure if I should post this in the suspension section or perhaps tires. Recently installed a magnuson sc and would like a little more traction when under aggressive acceleration. Between 20mph and 55mph the car, when aggressively accelerating, but not WOT, can lose traction if you’re not very careful. It’s not a huge issue, but I’d like to be able to use as much power as possible without spinning the tires.
Currently I have MRC with all stock suspension parts. The tires are BFG G-Force Comp 2 A/S, 245/40/R20 fronts and 285/35/R20 on the rear. Should I start with tires or suspension? Cornering hasn’t been an issue, even at the track (although I didn’t have the sc at the time) Recommendations for which suspension parts to add or tires? Launching isn’t as big of concern as aggressive acceleration when at speed. The car has a tendency to go sideways. Live in WA state so were definitely in the rainy season now but this happens when dry.
16' Supercharged SS Black³
18' ZL1 1LE Arctic Blue
shrubby is offline   Reply With Quote
Old 11-01-2016, 11:18 AM   #2
BMR Tech
BMR Tech's Avatar
I would recommend to start by upgrading some of your suspension components. Most customers cannot believe the difference in how the car launches even on stock tires just with a few simple upgrades. Some of our tubular Trailing arms, control arms and toe links make a dramatic difference in how firmly the car plants. You will also notice that the sideways kick out you refer to is virtually eliminated even if you do break traction. Once you add tires to the combination, you will have a really solid setup that will handle a good amount of power easily
BMR Tech is offline   Reply With Quote
Old 11-13-2016, 06:43 PM   #3
ender2664
Drives: 2016 2SS
*follow*
ender2664 is offline   Reply With Quote
Old 11-13-2016, 08:48 PM   #4
Doyal_Mcneff
Drives: 2016 2ss
Can you tell us where you would start? What components and in what order would you add them?
Doyal_Mcneff is offline   Reply With Quote
Old 11-14-2016, 01:46 PM   #5
PolynesianPowerhouse
Big Samoan ina little car
PolynesianPowerhouse's Avatar
Drives: 2016 camaro
I'd start with the cradle... they have braces, a lockout kit, which is an easier install then the bushings, or bushings if you have the means to install em.
After that I'd def get all the arms. I just installed mine this weekwnd and the difference over stock in stability is highly noticeable
In the next few I'll finish the toe arms and cradle.
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt
"Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant
PolynesianPowerhouse is offline   Reply With Quote
Old 11-14-2016, 02:50 PM   #6
MatthewAMEL
MatthewAMEL's Avatar
Always start with tires when trying to 'add traction'.
For what you are describing, no All Season tire is going to give you the level of grip you are looking for.
Start shopping for a 200TW tire. Nitto, Bridgestone, BFG, Michelin, all have tires that will give you a huge bump.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
2025 Hysteria Purple
C8 Z07
Old 11-14-2016, 05:30 PM   #7
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
you road racing or drag racing?
Old 11-14-2016, 05:55 PM   #8
BowtieRocket
BowtieRocket's Avatar
Drives: 2016 Camaro 2SS- M6
BMR upgrades are definitely on my list...
2016 Camaro 2SS M6- Garage
BowtieRocket is offline   Reply With Quote
Old 11-14-2016, 08:11 PM   #9
ender2664
Drives: 2016 2SS
I just put on nitto 555 g2 305s, awsome tire, very excited about it.
I'll end up doing some traction oriented suspension as soon as I fits in my budget.
Old 11-16-2016, 01:43 PM   #10
JaxChris
Upper & lower trailing arms in the rear will make a very noticeable difference in your launches. Even at stock power, the wheel hop is very obvious. First time I started punching the car you could feel it. After swapping trailing arms, I'm good at stock power.
I will also say the cradle lockout is what I should've done instead of sway bars. Now that my wheels point in the same direction under full load, you can feel the deflection of the entire cradle causing a slight wag. The cradle lockout would stop that -- which means the car should definitely be point and shoot then.
TL;DR = Want to launch hard and fly straight? Get upper & lower trailing arms plus a cradle lockout from BMR.
Old 11-16-2016, 02:18 PM   #11
ender2664
Drives: 2016 2SS
The way I launch I don't get any wheel spin or hop, will I still benefit from these mods?
Can I install these myself or is this something a shop needs to do because of alignment?
Old 11-16-2016, 02:27 PM   #12
BMR Tech
BMR Tech's Avatar
I normally recommend people to start with these components. Those are the biggest parts that help with wheel hop and reducing excess movement.
Old 11-16-2016, 02:34 PM   #13
ender2664
Drives: 2016 2SS
What exactly is a cradle lock out? Just bushings and what not?
How long are the trailing arms?
Old 11-16-2016, 03:26 PM   #14
sub_ETCS_ret
sub_ETCS_ret's Avatar
Drives: 2019 Dodge Challenger Scat Pack
Was this pretty easy to do? I hate taking things to a mechanic if I can do it myself.
"Submariners are a bunch of intelligent misfits that somehow seem to get along, understand each other and work well together." - overheard from a surface officer explaining to another sailor about Submariners
sub_ETCS_ret is offline   Reply With Quote
