Old 10-31-2016, 01:53 AM   #1
Jseller
Drives: 2007 Ford Fusion
2017 ZL1 Front End / Rear End
Obviously the front grill is different on the zl1 vs the SS but is the front end any wider?
Is the rear end of the ZL1 wider than the SS?
Does anyone know the dimensions on this to back it up?
If the rear end is wider will the rear wheels be off set?
thanks,
Jonathan
p.s. ordering my red ZL1 this week right here in Detroit!
Jseller is offline   Reply With Quote
Old 10-31-2016, 02:02 AM   #2
Zeke.Malvo
Zeke.Malvo's Avatar
Drives: 1969 Mustang MaCh1
thanks,
Jonathan
The rear is not wider. The fronts are said to wider, but appear no larger in person and in photos.
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtq
T56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear
Zeke.Malvo is offline   Reply With Quote
Old 10-31-2016, 07:13 AM   #3
NB2017ZL1
NB2017ZL1's Avatar
Drives: 2017 ZL1 10 Speed Hyper Blue
Front is clearly wider by every account from all the engineers saying so. Why would they make this up?
https://youtu.be/y_5xWPFGIWE
2017 ZL1
NB2017ZL1 is offline   Reply With Quote
Old 10-31-2016, 09:18 AM   #4
KLR ZL1
H-Town Camaro Club Member
KLR ZL1's Avatar
Drives: 17 Hyper Blue Metallic KLR-ZL1
The front is wider. The hood is wider, the front fascia is wider and the fenders are wider and this is all from a Camaro engineer. No specifics on deminsions. OP why does it matter if you are ordering one?
KLR ZL1 is offline   Reply With Quote
Old 10-31-2016, 10:46 AM   #5
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
Call me old or what not, but i do not think that the fenders are wider, the hood is different that it has a hole in it for the CF insert, and will soon prove it, have a ZL1 bumper on the way to test fit on a 1LT car.
2SSRS@Gen5diy is offline   Reply With Quote
Old 10-31-2016, 11:10 AM   #6
Zeke.Malvo
Zeke.Malvo's Avatar
Who said anything about making it up? I'm sure they are wider, no reason to make it up, just that they APPEAR no larger than the standard stuff in person and in photos.
Old 10-31-2016, 11:38 AM   #7
Eata34
Eata34's Avatar
Drives: 2011 Camaro 2LT
I would love to see this happen. Is there a time frame that you could give me that way I could come back and check this thread of will it be posted in the ZL1 thread? How can i know when you put that fender on the 1LT?
Eata34 is offline   Reply With Quote
Old 10-31-2016, 12:32 PM   #8
SoCal Racer
Drives: C4,C6 Z06,Silverado,'17 Red Hot ZL1
I'm not sure it is alot wider like on a GT350 vs a standard Mustang, but I heard from many GM reps that the ZL1 front fascia will not fit on a standard Camaro. I think they did not like people running around with "fake" ZL1s...since everyone wants to look like a ZL1, even when they are not.
Even if it is or isn't...does or doesn't, I am sure the aftermarket will make something if there is a demand...and it seems like there definitely is.
SoCal Racer is offline   Reply With Quote
Old 10-31-2016, 02:06 PM   #9
hotlap
hotlap's Avatar
The fenders look the same and that the extra width is in the fascia below the seam
Ronald Reagan -
Old 10-31-2016, 02:07 PM   #10
hotlap
hotlap's Avatar
Ronald Reagan -
Old 10-31-2016, 08:49 PM   #11
RedCamaroZL1
RedCamaroZL1's Avatar
Drives: 2017 Camaro ZL1
The front fenders are wider by a few millimeters on each side. Total width is maybe an inch wider. He back fenders are not wider. I asked the engineer at the factory fest about the back. Only the front.
2017 Camaro ZL1 Red Hot A10, PDR, Nav, ECF
RedCamaroZL1 is offline   Reply With Quote
