Old 10-29-2016, 05:29 PM   #1
BowtieRocket
BowtieRocket's Avatar
Drives: 2016 Camaro 2SS- M6
Power Stop rotors
I've looked around here and didn't see where anyone had installed these. I'm looking for a bit of feed back as I am thinking on getting them on all four corners along with their pads. Thanks!
2016 Camaro 2SS M6- Garage
BowtieRocket is offline   Reply With Quote
Old 10-29-2016, 06:37 PM   #2
Richard0nee
Richard0nee's Avatar
Drives: 2016 SS M6, NPP
I searched around last month.. Not sure if these can work with our brembo calipers.
The price isn't too bad
http://www.autoanything.com/brakes/6...ReviewsSection
Richard0nee is offline   Reply With Quote
Old 10-29-2016, 06:48 PM   #3
BowtieRocket
I called them and they said they work. They make front kits only. Rear would have to be bought a individually.
Old 10-29-2016, 07:17 PM   #4
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
stock brakes are fine leave them alone lol if your going to upgrade just get the 6 piston oem brembo setup
Old 10-30-2016, 01:36 AM   #5
bpang1234
You can only YOLO once.
bpang1234's Avatar
Drives: '16 2SS & '15 Subaru Forester
Agree and Disagree.
The stock brakes are just fine for almost all of us other than the real track rats. Pads, lines and fluid will make up a lot of the difference before moving to the 6-pistons.
MOST aftermarket rotors are not worth it...particularly the ones with holes. Holes are just terrible they make the rotor so much more susceptible to failure. Slotted is "fine" but not really proven to increase performance in all applications. The only two rotor improvements that have been proven to be beneficial all around are:
1. Ventilated rotors (release heat better...our stock rotors already have these)
2. 2 piece rotors (aluminum hat and iron ring that touches the pads)...saves weight, more uniform expansion and keeps the heat away from the wheel bearings because iron and aluminum don't transfer heat to each other effectively. They are more expensive and I would likely not get them unless I was a track-rat.
2016 Camaro 2ss
-Summit White / Ceramic White
-8A, NPP, MRC, Ceramic White package plus knee pads, black bowties.
-1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns.
-1st Car to have the 6LEDesigns Blade Spoiler.
-Borla S-Type w/ custom H-Pipe
-Procharger P-1X Stage 2
bpang1234 is offline   Reply With Quote
Old 10-30-2016, 09:58 AM   #6
kropscamaro16
i had stock brembo brake pads/rotors on my old car 09 cobalt ss turbo and upgraded the lines and fluid and never had a problem everybody upgraded the pads and rotors to r1 concepts and powerslot and all these other companies and just laughed at them wasting there money
if i upgrade it will be the same just lines/fluid or the oem gm big brake kit
Old 10-30-2016, 11:38 AM   #7
BowtieRocket
Originally Posted by bpang1234 View Post
Agree and Disagree.
1. Ventilated rotors (release heat better)
Great info, thanks! Made up my mind. Will just do fluid and pad swap instead
Old 10-31-2016, 02:22 AM   #8
bpang1234
bpang1234's Avatar
Yeah the 3 things that almost everyone here can agree on in terms of the stock brakes are:
1. They dust A LOT...not a big problem for me but it is the number one thing you read.
2. The initial bite is not great.
3. In track situations they fade due to heat.
Pads/lines/fluid can solve 2 and 3...as well as possibly 3.
Pads will effect 1 and 2...Ceramic if all you care about is dust and the stock performance is fine for you.
Fluid will effect 3.
Lines basically just make the pedal firmer which makes it feel better and makes the brakes react to you pressing the pedal faster.
2016 Camaro 2ss
Old 10-31-2016, 05:19 AM   #9
Bluecyclone
Bluecyclone's Avatar
Drives: 2014 Cyclone mustang
Lines SS & Dot 4 fluid is all I am doing.
2014 Cyclone/Select Shift/"/Sold
2016 ruby red GT w/3.55:1/resonator delete X- pipe/UPR catch can/Airaid "tube"W/AEM/J&M/BigWorm/BMR /SVE /ZL1addons/Redline/Steeda/BG fluids/
Bluecyclone is offline   Reply With Quote
Old 10-31-2016, 12:43 PM   #10
kropscamaro16
agreed!
Old 11-01-2016, 05:36 AM   #11
Turbo8u
Motorhead
Drives: 2016 Camaro Convertible 2SS
First off, I drive a convertible so I did not get any brake cooling at all, holes blocked for ventilation on the verts.
I bought the Powerstop Z26 kit and did not notice much difference at all, but I drive my car at 9/10's and many people do not do that.
I went to Dot 4 Motul 660 and it helped but most of my stopping issues were solved with opening up the vents in the grill and fender liner so they could get air. Driving the car at 9/10's now and did not have any issues.
So, I agree, good pads, Dot 4, and some stainless steel brake lines and you should be good.
Cars in the stable right now.
2016 Camaro SS Convertible Nighfall
2013 Dodge Charger SRT8
2002 Chevrolet Quad Cab Duramax
2012 Jeep Wrangler Rubicon BUILT, Supercharged
1969 Camaro FAKE Z28
1968 Ford Bronco Rockcrawler
Turbo8u is offline   Reply With Quote
Old 11-01-2016, 07:12 AM   #12
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
The 6 piston upgrade also comes with larger, slotted rotors. They work really well. I've gotten my car up to 151 and was pretty impressed with how quickly they slowed me down. Drilled rotors suck, they'll warp under hard braking. I think they look cool, but not those with that shiny silver finish.
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge
93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno)
LesBaer is offline   Reply With Quote
