![]() Drives: 2017 2SS Summit White Camaro M6 Join Date: Mar 2012
Who's doing a hard break in?
I'll be getting my 2ss delivered soon and was considering a hard break in as opposed to by the book. I've always broken in my motorcycles with a hard break in and they've always ran great with little oil consumption. So let me know what you guys have done with your new cars.
![]() ![]() ![]() ![]() ![]() Drives: 2016 Camaro 2SS, Nightfall Grey Join Date: Nov 2012
Bought mine with almost 30 miles on the odometer, you know it had a hard break in. Compliments of the dealership.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS Join Date: Jul 2016
I break in all of the motors I build in a methodical way that people would consider "hard" but they always seal right up and don't burn oil. I broke in my 16' the same way but I don't think I would do it that way again. I forgot that the trans and rear also need a break in and those two types of break ins contradict the way I break in motors. I would never just go light into a new trans (clutch if you are M6) and definitely not a new rear end.
I would also never break a motor in with synthetic oil. Joe Gibbs for the first two oil changes up to 500 miles and dinosaur oil up to 2,500. Then synthetic. These cars come straight from the factory with synthetic in them. I am not sure how much "breaking in" of the motor happens any more. I have a feeling the motor is what it is when we get it. If you look at GM's methodology and compare that to rear end company's break in instructions they are pretty similar. I am not saying that there is anything wrong with my car now but I would follow GM's instructions next time. That is just me though.
![]() Drives: 2017 Camaro SS Join Date: Aug 2016
the guide doesn't say to baby the throttle, it does also say to avoid constant same speed driving
I will be doing a moderately hard break in, following the guide's actual words the day I pick up my 2ss I will be taking it on at least 50 mile run, hopefully closer to 100 miles, I'll find an appropriate gear for the road I'm on (most of it will be 70mph limit) and taking the car from 1800rpm to 4000rpm with smooth but deliberate throttle to WOT - obviously I will need to find quiet enough sections of road where I don't have people right up my backside so that on the slow back down I don't get run in to the break in guide says to avoid WOT from a standstill and to avoid slamming the anchors on, but it doesn't say to baby the throttle, smooth and deliberately using WOT is a recommended part of break in as you need to have load on the motor to break it in |
![]() Drives: 2016 SS Convertible Hyper Blue Join Date: Apr 2016
Break them in like you plan to drive it. If you drive spirited and like to use the giggle pedal then that's how to break it in. Ive done that on all my cars and bikes. Ive always had good luck. If its going to break its going to break if not then it wont. IMO manufacturers want you to baby stuff keep it held together past warranty then it can drink oil etc not thier issue.
![]() Drives: 2016 Camaro 1SS M6 Join Date: Sep 2016
http://mototuneusa.com/break_in_secrets.htm
Very similar to the procedure I use on all of my new vehicles and engines. |
#7 |
![]() Drives: 2017 Camaro 50th Anniversary 2SS Join Date: May 2016
The question this raises to me is... Can the dealership mechanics review the car history from the computer to see if the car was being broken in hard? Would this void your warranty?
50th Anniversary Edition 2SS, NFG, BLACK, M6, MRC, NPP, BLACK BOWTIES
Build Date: July 21, 2016 Production Sequence: 934 |
#8 |
![]() Drives: 99 M3, 04 STi, 16 2SS Join Date: Oct 2016
Perhaps a similarly difficult decision is about the oil to be used during break-in. The only available dexos certified oils are synthetic and semi-synthetic. I think the car comes with semi-syn. If you read the mototune site a couple posts up, and other conventional wisdom, it is generally suggested to break-in the engine on dino oil then switch to synthetic once the break-in is done. That doesnt appear to be possible while abiding by the dexos requirement.
#9 |
![]() Drives: 2017 1LE SS Join Date: May 2014
I followed a mix of the book and what the guys who've had this motor longer in the c7 Vettes are doing. I mixed up the speeds, drove it fairly aggressive but never wot and never over 4k rpm. Never used cruise control. Changed oil at 500 and 1500. Changed the rear end oil at 1500 as well.
Sitting at 3600 now, no strange sounds, no oil consumption. Does it matter? Who knows lol
'If one day the speed kills me, don't cry. Because I was smiling.' - Paul Walker
#10 |
Drives: 2SS Join Date: Sep 2016
Here we go again... just follow the freacking owner's manual.
#11 |
Or search the countless threads in the " Mechanical Maintenance: Break-in / Oil & Fluids / Servicing" of this forum.
Do not put a conventional oil in the engine or you will void the warranty. This is a modern mass produced engine. Not one hand built at a speed shop. Conventional break in methods do not apply.
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
You have to remember the GM recommended break in period is for the entire powertrain; not just the motor. The break in period for the 5th Gen Z was hotly debated; but I followed it until 1,500 miles, disconnected the battery and let it fly. Bone stock it dyno'd 511 rwhp fully heat soaked. 22K miles later it runs strong, has good oil pressure and doesn't burn oil.
#13 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
Why did you disconnect the battery?
#14 |
![]() Drives: 2017 Corvette Stingray Grand Sport Join Date: May 2015
