Old 10-25-2016, 07:29 AM   #1
joepitt
joepitt's Avatar
Drives: 2016 2SS Camaro, 2017 Acura
Oops; I put regular fuel into my SS
I recently upgraded from a 2LT (v6) to a SS and accidentally put regular fuel in when I filled the tank. I know it won't break the engine, but I seem to remember something from the Camaro5 in 2010-11 forum that someone's car didn't recover and run right when they went back to premium. Anyone hear about a problem like that with the 2016 cars?
2016 2SS, Auto, Garnet Red, Black Interior, Magnetic Ride, Performance Exhaust, and Nav.
Past highlights: 2013 2LT/RS, 2010 pre-order Camaro 2LT,1969 Chevy Malibu, 1972 Plymouth 'Cuda, 1972 Pontiac GTO, 1979 Turbo Buick Century.
'See the USA in your Chevrolet...'
Dinah Shore, 1952: http://www.youtube.com/watch?v=KGZvQoPxhNs
joepitt is offline   Reply With Quote
Old 10-25-2016, 07:48 AM   #2
Mityguy
Drives: 2018 Hyperblue Camaro 1SS/1LE
I haven't heard of any problems with that. But one time won't kill you; I'd try to run the tank all the way down to like 1 gallon remaining and fill up with 93 again.
Mityguy is offline   Reply With Quote
Old 10-25-2016, 07:56 AM   #3
Capisce
you're just supposed to take it easy until you can re-fill. should be ok
2SS - Summit White - MRC - NPP
Capisce is offline   Reply With Quote
Old 10-25-2016, 08:00 AM   #4
Mityguy
Yeah good point; definitely shouldn't be going hard on regular.
Old 10-25-2016, 08:02 AM   #5
moonrider
Drives: 2016 2SS
The dealership I bought mine from put regular in for the first tank and I pinged pretty bad, but was fine after I filled it up with premium. You could go to Advance and get some octane boost.
moonrider is offline   Reply With Quote
Old 10-25-2016, 08:10 AM   #6
joepitt
joepitt's Avatar
I didn't think about the octane boost. thanks
Old 10-25-2016, 08:15 AM   #7
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
I have neither heard nor read of any complaints about the LT1 getting stuck in the low octane table in the ecu and requiring a fuse pull reset like on the LS3. Everyone that has made your mistake reports that when they returned to high octane fuel- everything was good.
Good luck - I think you will be fine.
476 rwhp/440 rwtq (sold)
Old 10-25-2016, 08:25 AM   #8
TSloper
Drives: 2016 Camaro SS
It won't get stuck. If KR doesn't occur it will reduce the knock learn factor.
TSloper is offline   Reply With Quote
Old 10-25-2016, 09:24 AM   #9
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
Don't put octane boost in it. Just use the tank without getting on it and go back to premium.
Eric SS is offline   Reply With Quote
Old 10-25-2016, 09:31 AM   #10
Slem
Slem's Avatar
Drives: 2016 Summit White 2SS (Auto) Loaded
Do not add anything to the fuel , do not floor it, just drive it easy and run that regular fuel out and fill with premium
Slem is offline   Reply With Quote
Old 10-25-2016, 10:17 AM   #11
SpookShow'84
Bump in the night
SpookShow'84's Avatar
Drives: '84 Monte Carlo SS, '15 Optima
Curious why he should wait until he needs to fill up again before topping it off with 93 or a cat safe 101 to boost the octane average. It would give him a little cushion against knock even thought the ECU will adjust to what the car is burning. Is it just to get all the 87 out of there ASAP?
SpookShow'84 is offline   Reply With Quote
Old 10-25-2016, 10:41 AM   #12
TSloper
Just run the tank down the fill. Otherwise it will take a while to get back up to 93.
Old 10-25-2016, 10:45 AM   #13
oldman
Drives: SS 6 speed of course
completely not true. The car will detonate at part throttle low RPM. Put booster in it, drive 5 gallons out fill with 93. don't do it again.
Old 10-25-2016, 11:06 AM   #14
Eric SS
#becauseracecar
Eric SS's Avatar
Booster will only raise your octane by about .5 or so. I like someone else's suggestion of buying a couple of gallons of 101 or something if you are going to do anything.
