Old 10-24-2016, 11:52 AM   #1
BMR Suspension
BMR Suspension Rear Lowering Spring Redesign
BMR Suspension has redesigned its rear lowering springs for 2016-newer Camaro (SP043/SP041 set), making the spring rate linear. Linear springs rates give you more consistent, predictable handling. This also gives you better ride quality and less noise.
BMR Suspension is offline
Old 10-24-2016, 08:22 PM   #2
TECHTURTLE
TECHTURTLE's Avatar
Rates?
2016 2SS 6-Speed Manual... Magnetic Ride Control, Dual Mode Exhaust, Sunroof, Adrenaline Red Interior, Mylink W/Navigation
Added
Edelbrock E-Force Supercharger, GM 1LE Sway Bars, BMR Upper/Lower Trailing Arms, BMR Upper Control Arms. BMR Front/Rear Chassis Braces, BMR Tunnel Brace. GM Red knee Pads, GM Black Front Splitter, GM SEMA Concept Grille, GM Dark Taillights, GM Ground Effects package... Savini Di Forza BM-14 Gloss Black Wheels 9's front, 10's rear.
TECHTURTLE is offline
Old 10-25-2016, 03:52 AM   #3
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
Same 1" drop?
BradfordCamaro is offline
Old 10-25-2016, 06:38 AM   #4
Jmcalhoun22
Jmcalhoun22's Avatar
Drives: 2019 Camaro ZL1
And for the people that have already bought your lowering springs a month ago? Is there something wrong with them? Do we need to exchange them? I do get a floaty feeling over hills and bumps, that I did not have before.
2019 Camaro ZL1 - A10
2016 Camaro 2SS - A8 - NPP - SOLD
2019 Audi Q5 - Premium Plus
2007 Tundra Limited - TRD Supercharged
Jmcalhoun22 is offline
Old 10-25-2016, 08:09 AM   #5
EXSSIVE
EXSSIVE's Avatar
Drives: 2016 Camaro 1SS M6
There is nothing wrong with progressive springs. Rather, the issue is that a progressive spring puts comfort and load handling capabilities before handling. This is the exact reason you're getting more of a floaty feeling, you're unloading the suspension and the springs are at their softest portion of the available travel.
Progressive springs can provide some unwanted handling characteristics when you start to push the car harder. It's for this reason I would strongly recommend against using a progressive rate for an on road performance car unless you have the dampers to back it up which takes very specific tuning.
It honestly puzzles me why BMR went with a progressive spring in the first place for an on road performance oriented vehicle unless they were wanting to mainly cater to the drag racing crowd which needs more body motion to plant the tires during hard acceleration.
EXSSIVE is offline
Old 10-25-2016, 09:17 AM   #6
BMR Suspension
Originally Posted by TECHTURTLE View Post
Rates?
The rate is the same as the old springs' working rate - 640 lb/in
Same 1" drop?
yes, the drop is identical.
There is nothing wrong with out old springs, the dual rate design can make a little extra noise in some circumstances and we figured out a design change that allowed us to go 100% linear.
Do you have MRC or non MRC? We (and other spring manufacturers) have had a couple of instances where there has been a "floaty" feeling in the rear. We are working on a solution.
Our 2016 Camaro springs were never progressive. The old springs were a dual rate spring - 360/640. This design uses two spring rates for a specific reason. When you design a lowering spring, you have to look at load rating, spring rate, drop amount, and a few other parameters that define the spring characteristics. One of those things is free height. This is important because when the suspension unloads, the spring can unseat if there isn't enough free height. With linear springs, it can be difficult to achieve the desired drop with the correct load rating, while maintaining enough free height to keep the spring seated with the wheels hanging. So a dual rate springs is an easy way to add free height, while keeping the working rate of the spring linear. The soft rate is low enough to completely compress at ride height, so the car only uses the heavier linear rate. They can be a bit noisy because the soft coils are in coil bind. This is why you see other companies use isolaters around every other coil. to reduce noise from coil-to-coil contact. We figured out a new design to eliminate the soft rate, keep the load rate the same, and have enough free height to keep the spring seated.
As for Jmcalhoun22's floaty feeling, it has nothing to do with our spring design. I assume he has an MRC car since the only time we have ever seen or heard of that kind of issue is with MRC. It is an issue we are working on a solution for, and it will most likely be sensor related.
Old 10-25-2016, 09:29 AM   #7
Jmcalhoun22
I have a NON mrc car.
Our 2016 Camaro springs were never progressive. The old springs were a dual rate spring - 360/640. This design uses two spring rates for a specific reason. When you design a lowering spring, you have to look at load rating, spring rate, drop amount, and a few other perimeters that define the spring characteristics. One of those things is free height. This is important because when the suspension unloads, the spring can unseat if there isn't enough free height. With linear springs, it can be difficult to achieve the desired drop with the correct load rating, while maintaining enough free height to keep the spring seated with the wheels hanging. So a dual rate springs is an easy way to add free height, while keeping the working rate of the spring linear. The soft rate is low enough to completely compress at ride height, so the car only uses the heavier linear rate. They can be a bit noisy because the soft coils are in coil bind. This is why you see other companies use isolaters around every other coil. to reduce noise from coil-to-coil contact. We figured out a new design to eliminate the soft rate, keep the load rate the same, and have enough free height to keep the spring seated.
Old 10-25-2016, 09:30 AM   #8
EXSSIVE
EXSSIVE's Avatar
So, according to what you're saying, you're old springs were a linear spring with an integrated linear rate helper spring, correct?
This is still considered by the majority of the industry to be a progressive rate spring-
http://automotivethinker.com/suspens...-rate-springs/
EXSSIVE is offline
Old 10-25-2016, 09:34 AM   #9
EXSSIVE
EXSSIVE's Avatar
I stand by my previous assessment, you're unloading the "helper spring" (340lb) portion of the coil which is making the car feel light under down travel of the suspension.
There are two solutions, get rid of the current springs or use a limiting strap which really shouldn't be needed by a practically stock suspension setup with a proper spring design.
Let me make this clear, this is not a dig on BMR, HOWEVER, the old spring design was not the best for someone who aggressively drives their car. I do like BMR parts, in fact, once the turbo build is done, I'll probably end up with some of them on my car. I just want to make it clear that when choosing springs, you need to be aware to pick the proper solution for the problem at hand.
EXSSIVE is offline
Old 10-25-2016, 09:40 AM   #10
BMR Suspension
Interesting. Let me look into it with our product designer and see what he has to say. We have not seen anything like that in a non-MRC car.
Old 10-25-2016, 09:53 AM   #11
BMR Suspension
It isn't a "helper" spring in the sense of helpers in coil-over set-ups. These are dead coils simply there to add free height to keep the spring seated. We did not advertise these as linear springs, but they have a linear working rate. What this means is when the car is at ride height and travels through its normal range of motion, it only used the one linear working rate of 640 lb/in.
I am not trying to be a jerk in any way so please don't take this the wrong way, but I think you are missing what I'm saying or twisting it around a bit. BMR's old springs are a dual-rate design, not progressive, solely based on the fact that it only uses one rate through the cars entire range of motion. This is completely by design and it's based on the load rating of the spring. If the load rating of the spring was different and the transition of one rate to another happened in the suspension range of motion it would fall into the definition of "progressive" in the article you gave the link to. Does that make sense?
Old 10-25-2016, 10:04 AM   #12
BradfordCamaro
SABIO
I get it. Love my Dual rate Springs
Old 10-25-2016, 10:36 AM   #13
EXSSIVE
EXSSIVE's Avatar
It is not my intention to twist anything that you say. It is my intention to inform and educate if possible, if not, it's my intention to be educated, lol. Do you happen to have a picture of your old dual rates installed?
What you seem to be saying is that the car will compress the 340 rate spring while sitting idle, coil over speak or not, this is essentially an integrated helper or "tender" spring designed to keep the spring from moving when the suspension is unloading from what you have described.
If that is not how the 340/lb section is being utilized and instead the 340 section is not completely compressed during static ride height, they're essentially a stepped rate progressive spring.
While I know we can all agree that the original springs were not a truly progressive spring, dual rate springs are largely grouped into the "progressive" category by the majority of manufactures.
Just trying to clarify.... as they say, a picture is worth a thousand words, or in this case, maybe a few thousand already, lol.
EXSSIVE is offline
Old 10-25-2016, 10:55 AM   #14
BMR Suspension
I 100% agree on the education side of it. I have been an automotive journalist for nearly 10 years, so I share your opinion on education and learning.
I have pictures of the springs installed, but only at full droop (car on our 2-post lift). This doesn't illustrate the point either of us are trying to make.
I will agree with you that springs like our old ones get grouped into the "progressive" category, in the handling world, "progressive" carries a negative connotation and we try to avoid marketing our springs as progressive, because they really are not progressive solely based on the fact that they only use one spring rate. If we are talking about how the industry classifies the springs, then yes they will most likely fall under a stepped rate progressive classification, they are not designed and do not work as a progressive spring. Either way, our redesigned 2016-newer Camaro spring is 100% linear! haha
