10-23-2016, 03:50 PM | #1 |
Other 2017s slap shift working very badly?
I've tried the slap shift in my 2017 A8 on the dragstrip a couple of times out, and it is terrible in my car. It just reduces power for quite awhile, for so long that you can feel the momentum going the other way, then eventually it makes the shift. This car has the stock 2017 ECM with no tuning done to it yet. Guys are reporting good results doing it on 2016s, so what is going on with this thing?
10-23-2016, 04:09 PM | #2 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
Just leave it in D. Manual mode is slow to respond...
Although not exactly sure what "slap shifting" an auto means. |
10-23-2016, 04:56 PM | #3 |
The shifter will move over to the left, in that spot (says + and -), it stays in whatever gear until you 'slap' it forward to upshift, or back to downshift. I used that gate in an autocross and did not notice that lay-over feeling that I'm seeing now. Of course, your attention is being drawn in more directions during an autocross run, so it may have done it there too and I did not notice it.
10-23-2016, 06:58 PM | #4 |
Have fun on the street manual shifting, but at the drag strip you'll just embarrass yourself. You can't shift it at the same RPM. Its must faster in drive. Put it in the track mode and hit the traction control button twice. Then your ready to go after your burnout.
10-24-2016, 04:16 AM | #5 |
I tried manual shifting because 'D' short-shifts 1st gear. I logged my stock-tune 2017 on the strip yesterday in track mode and, using 'D' it only reached 5477rpm, 5629rpm, and 5658rpm in 1st gear on the 3 logs that I took. Since the peak power on a stock LT1 is around 5800rpm or so (mine was), this means it's not utilizing all of the performance the motor has to offer. It's not even reaching peak power, let alone going a little past to get the recovery rpm higher in the next gear like it should, and like the other gears do.
10-24-2016, 07:38 AM | #6 | |
Drives: 2016 Camaro 2SS Join Date: Mar 2016
This is exactly why when I get to the strip I will try shifting the car manually as well. 1st gear shifts early and the tach ends up back below 4K heading into 2nd gear. 1st gear runs by real quick you have to be on point with your shifting or you will hit the limiter. It sounds like you are clipping the limiter to me when that happens the motor just lays over almost like you hit the pause button. It real gentle when you hit it not like my LS1 where you would get that Rat-tat-tat-tat-tat. I have gotten very accustomed to using the paddles personally. I do a fair amount of rolling runs and shifting manually is the only way I have found to keep it in a gear like 2nd and hold at 25mph until im ready to blast it. I have tried doing this and then pushing the shifter over back into auto mode but the car does not go back into auto mode fast enough and it wont shift in time and hits the limiter. I usually will click the paddle near 56-5700 in 1st and it shifts before it hits the limiter. Really 1st gear is the hardest and the rest of the gears give you more time to react to the tach. Not sure if there is anything to be gained by manually shifting at the track as some guys as of late have posted the ECU tends to close the TB blade at higher RPMs when manually shifting vs leaving it in D. I guess some back to back runs would tell
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB Rotofab ARH 1 7/8 longtubes hi flow cats AFM deleted E85 11.0@124.9 11.65@118.8 pump gas,stock tune/exhaust New combo: Pray Performance Heads/cam MSD intake manifold and Circle D 3C 554/491 on E85 all work & tuning done by Pray |
10-24-2016, 09:21 AM | #7 | |
Drives: Car Join Date: Jun 2010
Why are you using the shifter to "slap shift" over the paddles on the wheel? Also, for drag racing, you'll most certainly be quicker in Sport/Track in Auto mode... |
