10-21-2016, 12:37 PM | #1 |
Homeless Life Chose Me
Drives: LS3 (sold 4/21) Join Date: Nov 2014
What's Wrong With My Car? (Slow Starts/Dies)[FIXED]
EDIT: FIXED BY REPLACING STARTER
Preface: This only happens on warm starts for example when I stop at a gas station and then start it back up. Never on a cold start. 2011 Camaro 2SS LS3 Scenario 1: I turn the key and it's a slow start like it's a long crank then it starts. This happened almost every warm start. Scenario 2: I turn the key and it's an even slower start like its about to die then it starts. When it starts the tach doesn't work on HUD or dash and the idle is a little weird and it drives different like it has a real sloppy tune. Also louder more crackle/pops. Says service stabilitrac no CEL & traction lights on (see picture). This doesn't happen that much. Scenario 3: I turn key and long crank but doesn't start and dies. This happens less than scenario 3. I have video if that would help. The last time it didn't start I waited a few minutes then it started. I've never been stranded but this is sketchy what if I had to leave as an emergency and it won't start this needs to be fixed. It's not the battery that's pretty new. After some research I'm assuming it needs a new starter some people said the stock one overheats easily. So I'm hoping its nothing worst. What do you guys think? Edits: Mods are dyno tune, CAI, PTB, 1/78 Longtube Headers w/high-flow cats etc.. Voltage is good while running And on cold starts when I twist and let go it cranks by itself but warm starts if I try to do that it just instantly stops.
Pity a man in familiar places, who yet feels like a stranger.
10-21-2016, 12:41 PM | #2 |
ultracrepidarianism
Drives: '14 1SS/RS/1LE/NPP '18 Accord Sport Join Date: Mar 2014
i'd check the battery first
10-21-2016, 12:42 PM | #3 |
Ret AF, cancer survivor
Drives: 2013 Camaro 2SS/RS & 2006 Corvette Join Date: Jul 2015
You might be on the right track with starter, that's what it sounds like to me and where'd I'd start ... good luck solving the issue
10-21-2016, 12:53 PM | #4 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
I would also start to suspect fueling if it only happens on warm starts
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
10-21-2016, 12:57 PM | #5 |
Drives: 23 LT1 / 19 Z06 / after 6 5th gens Join Date: Jan 2014
Do you have LEDs, spliced wires, other non-OEM add ons? Improper wiring, grounding can possibly cause this as well.
"Make yourself sheep and the wolves will eat you"
10-21-2016, 01:05 PM | #6 |
Drives: 2010 Camaro SGM 1LT M6 Join Date: Jan 2015
Mine had this exact problem earlier this year. Started fine on cold starts, but on warm starts it turned over slow and produced a stabilitrac service light when it started up. It did all this till it finally left me stranded at a gas station after spending 30minutes in stop & go traffic. Got a new battery and now no issues.
Arkentect's Build Thread!! - UPSTATE C5 MEMBER
2010 SGM M6 1LT - SOLD Current - 2009 C6 Corvette Z51 |
10-21-2016, 01:08 PM | #7 |
Battery is pretty new. And why do you suspect fueling issue? No spliced wires.
10-21-2016, 01:11 PM | #8 |
first thing is to have the battery load tested, then check all your grounds and connection is nothing is loose,-at the battery and check also on starter.
if all checks ok then you can suspect the starter... next time you start it check your voltage gauge if it drops a lot when cranking if it falls below 10 volts it's not good.. a full battery is 12.3 to 12.8 volts.should not drop that much when cranking. if battery is low--check if the alternator charges it can have some good voltage but if no amps then the battery has no reserve -amperage-to crank the engine. when i picked up my SS,1st day from dealer it was slow to start like it's pulling big amps. apparently that's normal but i don't like it. my old ls1 was better on cranking. started right away. the ls3 are hard to start they don't fire up on the first turn, needs some cranking to get going.. Good luck |
10-21-2016, 01:15 PM | #9 |
Your battery has time to charge up when sitting. Running the car drains it so it's harder to start.
Battery, Alternator, cables, or an accessory draining your system. If your battery is more than 3 or 4 years old, it's time to replace it anyway, but you need to have your charging system checked and make sure it's putting out 14 volts. |
10-21-2016, 01:20 PM | #10 |
drinks virgil's
Drives: 2010 2SS M6 Join Date: Feb 2014
Battery first.
Let the key sit in the on position for 5-10 seconds before you start it. Mine will hunt and die too here and there if I don't let the fuel pump prime the lines.
2010 2SS/RS M6 - CAI Intake - Borla Stinger - VTC - 3.91's
Eibach Sways - LG ZR28's - BMR Springs - 285/35 Squared |
10-21-2016, 01:21 PM | #11 |
376 cubic inches of fun
The Service Stabilitrac message is a sign of low battery voltage during cranking.
Time for a new battery. |
10-21-2016, 01:24 PM | #12 |
The battery is new guys
10-21-2016, 01:26 PM | #13 | |
But I do agree with everyone else to check electrical first and foremost.
10-21-2016, 01:32 PM | #14 |
Drives: 2013 Camaro 2SS/RS Join Date: Jul 2016
If you didn't put that newer battery in I would check to make sure the connections are tight.
