Motorhead
Drives: 2016 Camaro Convertible 2SS Join Date: Jun 2016
2016 Camaro Brake Cooling Ducts
So has anyone done brake cooling ducts on the their 2016 yet? I drive pretty hard and even with the Powerstop Z26 kit I'm cooking the brakes on mountain roads so I'm concerned that when I track it will not have brakes at all.
Ideas/pictures? thanks, Phillip
Cars in the stable right now.
2016 Camaro SS Convertible Nighfall 2013 Dodge Charger SRT8 2002 Chevrolet Quad Cab Duramax 2012 Jeep Wrangler Rubicon BUILT, Supercharged 1969 Camaro FAKE Z28 1968 Ford Bronco Rockcrawler |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
What brake fluid you using?
![]() ![]() Drives: 16' Camaro E-Force SS Join Date: Jul 2016
explain cooking brakes? Soft pedal or no bite?
Motorhead
I'm still running stock fluid. Should I upgrade to Dot 4 or 5?
Motorhead
Exactly! Both! Petal wants to go to the floor and it's like driving a runaway mine train!
#7 |
Motorhead
Thank you! I will try that next!
#8 |
![]() ![]() ![]() Drives: Garnet Red - 20 ZLE Join Date: Jun 2016
Dont put DOT5 in this car. Not the right fluid.
Buy Castrol SRF or Motul 600. Both are great. |
#9 |
Motorhead
Thanks for the info!
#10 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
Even with the stock fluid, I'm surprised you are "cooking" them. Are you riding them all the way down steep mountain roads? Do you have the factory track cooling deflectors and rotor shields installed?
#11 |
マスタング = 遅い
Um yeah...you are wondering why you have issues when you are hammering on your brakes, yet you are using the OEM fluid lol? All cars come with DOT 4 pretty much now, it's the boiling point that matters. Get some high boiling point Motul in there and that should at the very least help...
#12 |
Motorhead
Factory deflectors installed. I do drive it like I stole it though...
#13 |
#14 |
![]() Drives: 2016 Camaro 1SS M6 Join Date: Sep 2016
On top of that, if I had to guess, you're probably riding the brakes instead of getting on them hard. This causes excess heat that builds in the system. You need to be smooth but aggressive.
Staying on the brakes instead of hard on, then off, is actually harder on the braking system as it builds a lot of heat. |
