![]() Drives: Z28 Join Date: Nov 2015
Where are the Single Point of Failures? Try to eliminate them.
Ok, you are driving somewhere on a long road trip and your car stops running. If it is the fuel pump in the tank or direct fuel pump up under the intake you are hosed. In my Gen 4 Z28 I cut an access hole to be able to replace the fuel pump on the road in under 30 minutes. Where the heck is the fuel pump tank access hole on the Gen 6? Doesn't exist! On my Gen 4, I sometimes carry an extra ECM, MAF, EGR, Smog parts, distributor, coil, water pump, heater hoses and gaskets. On the Gen 6 fortunately some of these parts are not used. Do you know where the Crank Sensor is on the new LT1? It is on the block, ride side. So where are the Single Point of Failures and how can they be eliminated? Come on Chev engineers, you can do better than all the crappy coolant plastic parts on an SS! I will replace them with metal parts and they will never fail.
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
Wow! Amazing that you think you can add a part that will never fail.
In any modern car if you are carrying around the parts list you do it would probably go down as the worst car of all time. Plastic parts, by the way, are NOT any indication of a part that will fail. Plastics and composites are often a BETTER solution for cost, weight and performance. Now if you want to push the engine to the right in the stress - strength curve, you can simply start adding money to both the cost of the car and cost of any replacement parts. You are misguided to think GM engineers aren't aware of what it takes to meet the requirements in a modern performance car. They do.
Obviously I don't need to have a part never fail but the goal should be to reduce the Mean Time to Repair (MTTR). If you like to spend $1000 to replace a fuel pump, go right ahead. I don't like that cost! It is not ok with me. Even Hondas and BMWs have fuel pump access holes, many times under the rear seat.
OP - between this post and your one on run flat tires I get a kick out of your Mad Max view of the world. "Be ready for anything. Carry everything you own with you."
I'm of the opposite mind. I carry no spare parts with me for any car I own or have owned. After thousands and thousands of miles with several different vehicles built since the 90's I've never had any of the road side failures you've mentioned. Now my 60's and 70's cars weren't so good.
Yes, Mad Max was entertaining. Glad you were amused.
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
I would hate to have your pessimistic views on life. If the Camaro is such a POS that requires you to carry all the replacement parts why did you buy another one? Also, replacing parts with metal parts will make the car a heavy POS like the Gen 4's were.
SMH I hope you're just trolling. |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Hyper Blue 1SS Join Date: Jul 2015
If this car was 10 years old, i would carry a part or two on a road trip, but is brand new, get a spare tire and call it a fay.
1ss/Auto-Hyper Blue
acs carbon flash spoiler, bmr springs, gm clear tails. Texas speed cam, 223/227 .635/.635 116 LSA, Kooks Long Tube Headers with green cats, MSD Atomic Air Force Intake, CAI Cold Air Intake, QTP cutouts. 503 hp Best so far 11.5 at 123 with a 1.83 60ft. BMR lower and upper trailing arms and upper control arms,E85 DELIVERED 12/29/15 http://youtube.com/bybcous " no talking only racing on my youtube" |
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '16 Garnet Red 1SS Join Date: Mar 2014
That's the second time today I've seen someone mess up the word day.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
#9 |
Spell check on android is no good
1ss/Auto-Hyper Blue
#10 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
#11 |
![]() ![]() ![]() ![]() ![]() Drives: Gen 6 Camaro RS Join Date: Dec 2015
Repair stuff like a boss:
https://youtu.be/qDK86kzgUPg |
#12 |
Snackbar Tuning
#13 |
Drives: 2016 Camaro 2SS Join Date: Sep 2016
I just make sure I have a quick detail spray and micro-fiber in case of bird shit. The clear on this car leaves much to be desired. But the performance more than makes up for it, in my opinion anyways.
#14 | |
A Heartbeat Away.........
Drives: Not As Fast As I Would Like To Join Date: Mar 2016
![]() Here it is. These things are priceless. https://www.amazon.com/Flexible-Claw.../dp/B000RB7AGY
2016 Hyper Blue Metallic 2SS | A8 | MRC | Sunroof | Nav | Mishimoto Catch Can | GM CAI | Hurst Shifter | Borla S-Type Exhaust | Body Color Splash Guards | 1LE Splitter | GM Dark Tail Lights | ZL1 Third Brake Light | Custom Fuel Door, Badges & Bowties | Oracle Side Markers | Blacked Out Stuff | Opti-Coat Pro+ The problem with this world is stupidity. I'm not saying there should be penalties for stupidity, but why don't we just take the warning labels off everything and let the problem solve itself. |
