Old 10-14-2016, 04:24 AM   #1
Teem0s42
Teem0s42's Avatar
Drives: 2017 2SS Camaro
Sto n SHo License plate question
I recently installed a Street scene splitter for my 2017 Camaro ss... It looks great but I was wondering if the Sto n Sho w/GM splitter would fit with my Street scene splitter?
I currently have the NON GM splitter version of the Sto n go thats still in box =/... will probably end up trying to trade or sell it.
http://www.phastekperformance.com/ST...nse-sns89a.htm
Teem0s42 is offline   Reply With Quote
Old 10-14-2016, 11:54 AM   #2
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
i have the zl1 addons front plate holder and it works great not sure about this one tho
Old 10-14-2016, 12:07 PM   #3
JustShootMe
Drives: 3015 300s
It may fit , I have one installed on the GM splitter , I can't imagine the other splitter is much longer in the front.
2016 Mosaic Black Metallic 1SS NPP M6
JustShootMe is offline   Reply With Quote
Old 10-15-2016, 05:18 AM   #4
Teem0s42
Teem0s42's Avatar
zl1 front plate
can you link me a picture
Old 10-17-2016, 01:17 PM   #5
kropscamaro16
https://www.zl1addons.com/
Old 03-30-2018, 05:35 PM   #6
gdgraph
gdgraph's Avatar
Did we ever confirm if the sto n sho is compatible with the street scene splitter? I have the #SNS89A (sto n sho for the GM splitter) and am wondering if it will work with the Street Scene splitter... does anyone have this set up... curious if it works or not.
gdgraph is offline   Reply With Quote
Old 03-31-2018, 01:56 AM   #7
Start The Machine
Start The Machine's Avatar
Drives: 2016 M6 2.0T
I belive there are two different lengths. You are going to need the version that is compatible with all front fascia extensions.
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, RPI Designs SS 1LE Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
Start The Machine is offline   Reply With Quote
Old 03-31-2018, 08:52 PM   #8
Msokeefe
Drives: 2018 1SS
How durable is the stonsho for daily use? Just being screwed into plastic doesn’t seem like a rugged set up.
Msokeefe is offline   Reply With Quote
Old 04-01-2018, 10:36 AM   #9
gdgraph
gdgraph's Avatar
Yeah, there's a #SNS89 for stock bumper and #SNS89A for the GM fascia. The GM fascia is different than other splitters, it has two large indents which need spacers, I'm not sure that other aftermarket splitters have that, and also not sure on the length from where you bolt the sto n sho to the tip of the splitter is the same, so I'm curious if anyone has had success with the sto n sho fitting on the Street Scene splitter or American Authority splitter.
I've had the #SNS89A on my GM splitter for almost 2 years and it has held up very well under high speeds and the occasional scrape here and there. My splitter got cracked so I need to get a new one, but the sto n sho is perfectly intact.
Old 04-01-2018, 11:57 AM   #10
jaysonstuart
jaysonstuart's Avatar
I have a front splitter on mine and the one you linked works. In fact I think I purchased that exact one from Phastek.
jaysonstuart is offline   Reply With Quote
Old 04-01-2018, 02:28 PM   #11
Msokeefe
Drives: 2018 1SS
Thanks for the response to my question gdgraph.
Old 04-02-2018, 10:43 AM   #12
MANNAXMAN
MANNAXMAN's Avatar
I confirmed it with user camarography on Instagram. I asked if it required any modification to mount it with the Street Scene splitter, and he said, "I mounted it the same. There is a little more resistance because the lip of the splitter seems to dip slightly so the plate rails slide in and out at a very slight angle." Here is his post where I asked about it - https://www.instagram.com/p/Baz1c4AhzTl/?tagged=stonsho.
1996 Camaro Z28 with T-Tops (Sold 10.22.16)
1986 Camaro IROC-Z with T-Tops (Sold)
1961 Volkswagen Beetle with Sliding Ragtop Sunroof (2009-Present)
1964 Volkswagen Beetle with aftermarket Sliding Ragtop Sunroof (Sold)
Follow me on Instagram - @gen6_2ss_vert
MANNAXMAN is offline   Reply With Quote
Old 04-04-2018, 07:55 AM   #13
ecko04
Drives: Too many to list
It’s not just screwed into plastic. It mounts into the same metal support that secures the front fascia.
I use mine daily. I never take it off, except to wash the car, and I’ve not had a single issue.
Sent from my iPhone using Tapatalk Pro
ecko04 is offline   Reply With Quote
Old 04-07-2018, 12:35 PM   #14
gdgraph
gdgraph's Avatar
Thanks for digging that up!
