Old 10-13-2016, 12:36 PM   #1
Danny80027
Danny80027's Avatar
Warranty affected by K&N Performance Intake ?
I'm getting ready to order the K&N Performance Intake kit 63-3092 for my 16SS and i was wondering if the aftermarket installation will void the manufactures warranty? please advise, Thanks guys
Danny80027 is offline
Old 10-13-2016, 01:05 PM   #2
TSloper
Drives: 2016 Camaro SS
Cancel the order and go with the Rotofab.
Take it off before dealer visits if you are going in with powertrain issues.
TSloper is offline
Old 10-13-2016, 01:28 PM   #3
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
^listen to this guy
K&N is unproven junk. Tim (TSloper) is our resident tuning expert and has personally tested the Rotofab unit. If he recommends it, you want it.
SuperSound is offline
Old 10-13-2016, 01:31 PM   #4
diirk
diirk's Avatar
I concur with the above. The K&N would be near the bottom of the list when shopping for a CAI. You can leave it on for routine maintenance, but as mentioned, if there's anything engine related, you'll probably be better off if you reinstall the stock airbox.
16 2SS 6MT NPP White | MRR | ACT | JBA | SCT | C7C
04 Ram 2500 CDT 4x4 Quad
91 Miata 1.8 Feal Wilwood Track Car
1morproject
diirk is offline
Old 10-13-2016, 01:36 PM   #5
Danny80027
Danny80027's Avatar
interesting to hear the remarks about K&N intakes. Is there some unbiased reviews out there with factual data ? I don't mean to discredit options, but every fabrication /manufacture has their claims as to why their product is superior. Thanks again guys
Old 10-13-2016, 01:38 PM   #6
SuperSound
SuperSound's Avatar
http://www.camaro6.com/forums/showthread.php?t=465449
Old 10-13-2016, 01:45 PM   #7
TSloper
I'm not pitching Rotofab based on some personal emotional preference. It is the only intake out there, that through real world end user logging, we know does not skew the MAF output. CAI and Mishimoto both skew the MAF readings which will cause you headaches if you pursue further bolt on modifications and do not tune for the situation.
If you feel compelled to burn new ground it's your choice but just looking at the photos of the K&N it is already inferior.
Rotofab has been out for a while. It sounds like the website needs an update.
TSloper is offline
Old 10-13-2016, 01:47 PM   #8
SuperSound
SuperSound's Avatar
I'm a little bummed, i just previewed the Rotofab website and their 2016 product is still in the development phase. Thanks for the input tho
Not sure where you saw that.
https://www.roto-fab.com/2016-17-cam...-intake-system
FYI: You should browse the LT1 section
http://www.camaro6.com/forums/forumdisplay.php?f=231
Old 10-13-2016, 01:50 PM   #9
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
Originally Posted by SuperSound View Post
Doesn't really say much since there were no results there, nor any comparison to other intakes other than stock.
I suspect that all of these will produce little if any benefit over the stock intake with a drop-in high flow filter once the ECU has adapted to the change. These days with NA engines, CAI's are less for power and more for sound and looks since the stock intake is already a CAI.
cellsafemode is offline
Old 10-13-2016, 01:54 PM   #10
SuperSound
SuperSound's Avatar
The results were on the first page. It wasn't about dyno numbers or comparisons to other units (which there are separate threads for). TSloper posted hard data about how it affects the MAF readings. But you are right, CAI aren't good for much power anymore, but they do once you start adding other items and tuning.
Old 10-13-2016, 01:54 PM   #11
Danny80027
Danny80027's Avatar
Supersound, that thread on the Rotofab CIA ended up with no HP or Torque gained Dyno results??
Old 10-13-2016, 01:58 PM   #12
Danny80027
Danny80027's Avatar
sorry guy's , I'm kind of new and just data mining this group. thanks everyone, i really appreciate your thoughts
Old 10-13-2016, 02:00 PM   #13
TSloper
I've said from day one that I don't expect much from a CAI on a stock engine. And I still have that mentality. On a modified setup there will be without a doubt a benefit. The more significant the mods there greater delta you will see between stock and the aftermarket CAI.
My only concern on this thread is keeping someone from make an unwise purchase for technical reasons. Rotofab does not screw up the tuning nor will it hold you back if and when you start modding.
TSloper is offline
Old 10-13-2016, 02:08 PM   #14
Danny80027
Danny80027's Avatar
I previewed the Rotofab 2016SS product on their website and could not find any dyno data ? Is their any manufacture published data available -vs- stock intake? thanks again
