![]() ![]() ![]() ![]() ![]() Drives: 17 SS a8 Join Date: Feb 2010
Max effort fuel system?
This add says 900rwhp on e85 when combined with their high pressure system. The high pressure system is an lt4 pump and injectors.
Let's assume they also are including the larger lobes on the cam. Are their numbers accurate? 900rwhp is higher than I thought possible with just the di. http://cordesracing.mybigcommerce.co...e-fuel-system/ |
![]() ![]() Drives: 2016 1SS, 2017 JKU Wrangler Join Date: Mar 2016
I wonder what the limits are for just the high side kit? I hate that we might have to swap cam to get more fuel with e85
SLO 1SS - sold
1SS MRC NPP 6MT 2018 Ram Rebel 4x4 5.7 |
![]() Drives: 2017 Camaro SS Join Date: Aug 2016
The lt4 pump is already higher flow, you dont need to change the cam lobes
i called them. They said they are running everything listed above. Lt4 pump, lt4 injectors, increased lobe on the cam and their low side kit.
They also claimed it is good for 900rwhp on e85 just like the add does. I would like a confirmation of this before going this route. |
There's no camshaft, the cam lobes on the LT1 and LT4 are the same, its the pumps and injectors that are included in the 2 kits. There's no cam swap involved.
Andy, they make an aftermarket cam that has a larger fuel pump lobes ground into them.
My question is what is the hp limit of the high side when on e85 and using all available products? |
#7 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
It is possible to get 1200 whp with modifications to the current fuel configuration. You need to browse the Corvette forums to see the specs on the cars. GirlyNFG got over 800whp on E85 with a 32% lobe. Attached is pic from Comp Cams website of their possible fuel lobe configurations.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. ![]() |
#8 | |
SABIO
#9 |
Thanks. That helps. I did start to check out some of the cars and specs but most of them are running meth and pump gas. I will keep reading.
#10 |
I am not familur with them and am just looking for someone that is using their stuff to confirm their claims. Confirming a manufactures claim with people's real world experience is common.
#11 | |
![]() Drives: 2017 Nightfall Grey Auto 2SS Join Date: Mar 2012
I know they did some fuel work on his Vette and he was very please with the results you might ask him about it. |
#12 |
![]() ![]() Drives: 2001 Audi TT, 2016 Camaro Join Date: May 2016
If it were me, I would look into replacing the in-tank pump first. I believe Jessrayo did this for about a grand, including labor and pump. No need for three pumps
#13 |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS Join Date: Aug 2016
#14 |
I think I am going to do all the high pressure system mods and oversize the low pressure system so that I am ready for whatever happens later. if I max out the high pressure system and they have no new parts available then maybe run one or two charge pipe mounted injectors on a hobbs switch.
