Old 10-09-2016, 12:48 AM   #1
Wheel Team 6
Wheel Team 6's Avatar
Anyone have a trunk unlocking problem
Twice now mine has not opened when clicked on the key fob or the button on the driver's door. Kept locking and unlocking it then it finally opened. Done this twice in the past week.
One other thing I'm noticing is one day it runs very strong then a few days later it seems weak. Thought it was the phenomenon of getting used to the car but heads up races against a buddies car that runs low 12's and I leave it. Then against another buddies car that struggles to run mid 13's he is right with me. Almost feels like a throttle tune issue. Anyone have an idea let me know. One pass it pops on shifts sounds great and pulls hard then again it sounds weak and pulls weak. Mode set to track on each pull. I'm baffled by it.
Wheel Team 6 is offline   Reply With Quote
Old 10-09-2016, 06:22 PM   #2
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
My trunk seems to "stick" sometimes. I hit the button and hear the click but the trunk is still locked. I haven't had a chance to look in depth but I imagine it could be an adjustment issue. Seems to just get stuck and not let go. Maybe a some more usage will wear it in and stop the sticking. It's happened 2 or 3 times for me already an I only have 300 miles on the my 2017 SS,
Old 10-09-2016, 08:07 PM   #3
cigarfan
cigarfan's Avatar
Drives: 16' Camaro 2/SS BlackMosaic A/8 NPP
http://www.camaro6.com/forums/showthread.php?t=465017
cigarfan is offline   Reply With Quote
Old 10-11-2016, 01:10 PM   #4
warriordave927
Deadpool
warriordave927's Avatar
Drives: 2016 camaro lt rs m6 redhot
This happened to me once, the only thing i recall was i had forgotten to set parking brake (mine is a 6spd),still cant get used to the button,tried the remote and the door button and wouldnt open the trunk,when i realized brake wasnt set,set it and tried the trunk again and it worked first try
warriordave927 is offline   Reply With Quote
Old 10-11-2016, 01:37 PM   #5
Blue's SS
Blue's SS's Avatar
Drives: 2017 Camaro 1SS, for go, not show.
Mine does it 50% of the time. I'll let the dealer take care of it when I bring my car in for it's first oil change at the end of the month.
Camaro/Firebird fan since 1977!
Previous rides: 1965 Pontiac GTO, 1977 Trans Am Special Ed. "Bandit", 1996 Camaro 3.8, 2002 Camaro Z28, 2014 Camaro 2SS/RS M6 Spring Special Edition
Current ride: "SOUTHERNCROSS" - 2017 Camaro 1SS Silver Ice Metallic/Jet Black w/BO4 56V RZ9 NPP SFE SH1 VW9 W2D
"And no BS! It's (the 1SS) everything you need and nothing you don't." -Craig Cole on the 1SS vs 2SS
"Reach above your dreams of pleasure, giving life to those who died. Look beyond your own horizons, sail the ship of signs." -RJD 'The Sign of the Southern Cross'
Blue's SS is offline   Reply With Quote
Old 10-11-2016, 05:27 PM   #6
V8Addict
V8Addict's Avatar
Drives: 2016 2SS
about your second problem with the perceived fluctuation in performance....why not use your 0-60 timer and check the acceleration on a good day and when you have a bad day just to see it there is a real difference or its all in your mind.
2016 Hyper Blue 2SS, A8, NPP, MRC
V8Addict is offline   Reply With Quote
Old 10-11-2016, 05:31 PM   #7
vet757
vet757's Avatar
Drives: ^^^This
My trunk does the same thing. Is very random. I hope someone can share some insight on this small issue.
vet757 is offline   Reply With Quote
Old 10-11-2016, 05:48 PM   #8
Mr. Texas
Mr. Texas's Avatar
Drives: 2016 Mosiac Black 2SS A8
Mine has stuck twice..
Mr. Texas is offline   Reply With Quote
Old 10-11-2016, 07:08 PM   #9
Wheel Team 6
Issues
My 60' times are awful. I honestly think a 4 or 6 car could beat me. I've tried it a few times here and there. Thanks for the suggestion. Actually I ran my buddies proven time and time again low 12 second modified 2000 ls1 transam and I pulled away from him over and over. Then a couple weeks later ran another friend of mine with an 02 camaro with very little mods 13.50 car at best and he actually pulled on me. This is where my thoughts are coming from if you understand what I'm saying. Thanks to everyone for your feedback. I dropped my car off with my dealer tonight. Will see what comes out of this latest trip to the dealer.
Old 10-14-2016, 07:37 PM   #10
Wheel Team 6
Trunk sticking closed
Update
Trunk was adjusted now opens every time. Was told if the adjusters are out to much the trunk will stick shut.
They think I had bad gas in the car. Ran it empty and put a fresh tank of 93 in. Seems fine for now.
