WIZPRO
Groan from Gen6 rear end when cold
Each morning when I crank up my Gen6 2SS, I back out of the driveway then once I turn the wheels and step on the gas to pull off. Then a very noticeable "groan" comes from the rear of the car! The sound happens each time I make a turn until the car warms up - then sound goes away.
I want to take it in for service to check it out but once I get to the deanship, it'll be warm and the sound won't be there for them to hear. I have read elsewhere that others have had this same problem. Some have said it is the LSD. Has anyone here had this checked out? If so, what is it and is it something that I should be concerned about?
I did take to dealership for this reason this week. I left it overnight too. They couldn't reproduce it so they won't do anything. I'm going replace diff fluid myself this week to see if it helps.
You are definitely not the first (http://www.camaro6.com/forums/showthread.php?t=440272)
I had mine in twice for this reason, first the changed the diff oil, the second time (still in service) they are replacing the carrier. Hopefully the groaning will go away now. like you said, is only when its cold. |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
Well, I don't get that sound. But car does not move till it's warmed up, 5.min
My car is picky and sure it's with other camaro's as well. It just does not like a start and go.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
![]() Drives: 2016 Chevrolet Camaro 2SS Black Join Date: May 2011
Have the same issue. I brought it to my dealer and they could not reproduce it as expected. They offered a loaner if I left it overnight. They won't act on anything that they cannot reproduce.
Will update when I leave it overnight.
2016 Camaro 2SS Black \ Black, A8, 6 Piston Brembo Brake kit, Front Splitter, 56H Wheels, 35% Tint
Delivered on: 9/8/16 |
![]() ![]() ![]() Drives: 2016 SS Convertible Join Date: Sep 2016
Try adding a little GM lsd additive - maybe factory fill didn't have enuf. Should not cause an issue however.
#7 |
PC Technician
Drives: 2016 Hyper Blue 2SS Join Date: May 2012
I'm curious too. It has been about 35 degrees now and I notice it at low speed turning.
#8 |
![]() Drives: 2SS '16 Camaro Join Date: Apr 2016
Mine does the same thing. I think it's a bad diff. Haven't taken it to the dealer yet.
'16 2SS White/Adrenaline Red Coupe Mag ride, 8-speed, Sunroof, Dual-Mode Exhaust, Black wheels
Also: 2010 ZR1 2018 GT3 2013 LX570 |
#9 |
![]() Drives: 2016 SS Join Date: Jan 2016
dealer change out the deff fluids, it still does it, just not as loud. we will see how long this last before getting really loud again.
#10 |
I have the same issue
2019 Camaro ZL1 - A10
2016 Camaro 2SS - A8 - NPP - SOLD 2019 Audi Q5 - Premium Plus 2007 Tundra Limited - TRD Supercharged |
#11 |
![]() Drives: 2016 Camaro 2SS Join Date: Jan 2015
I noticed this too for the first time last week. It just started to cool off here in the mornings. Also heard it again today as I left for work. It was about 50* out.
#12 |
TBC
Drives: 2017 Fifty 2ss Join Date: Dec 2012
Best thing to do and i did it a few times. If you have a GoPro. Mount it to something under the back of the car that don't move to much and record it. Might need to do it a few time in different place so you can see were the sound is coming from.
2017 Fifty A8, MRC, NPP, NAV, LUM, BLK BOWTIE
#13 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 2.0T RS Join Date: Jul 2016
Also have the same problem, seems to go away after the transmission/rear end temp gets up to about 30C... Still have the stock fluid in the diff after 5000km, I have some new fluid to try just haven't gotten around to replacing it yet. (LTG rear end with LSD)
#14 |
I am taking mine in Monday to leave it overnight so they can check it out.
| Tags |
| rear end groan, strange noises |
