Old 10-07-2016, 06:28 PM   #1
mandoman
mandoman's Avatar
Drives: 2016 RS
paint chips in their front spoiler
2016 RS is any one noticing paint chips in their front spoiler. I have had my car since May I drive my car every day I don't tail gate i stay a way from trucks with big tires I'm very careful. but my front spoiler seems to be a chip magnet
mandoman is offline   Reply With Quote
Old 10-07-2016, 06:34 PM   #2
BowtieRocket
BowtieRocket's Avatar
Drives: 2016 Camaro 2SS- M6
I had the 3M paint protection film "clear bra" installed right away, so that really helps protect mine
2016 Camaro 2SS M6- Garage
BowtieRocket is offline   Reply With Quote
Old 10-07-2016, 07:00 PM   #3
mandoman
mandoman's Avatar
Drives: 2016 RS
always wonder if the 3M paint protection film works. hows it been working out for you notice any paint chips after its been installed?
Old 10-07-2016, 07:00 PM   #4
KirkH
I live near a rock quarry and trucks travel my riute to work. I use a NoviStretch bra. Seems to be working and I can take it off wheneber I want.
Old 10-07-2016, 07:11 PM   #5
mandoman
mandoman's Avatar
Drives: 2016 RS
Old 10-07-2016, 07:16 PM   #6
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
XPEL.....you can do this yourself with the 3 inch XPEL door edge guard from Amazon and just tape off the leading edge and about an inch back… It works very well and is almost impossible to see
Old 10-07-2016, 07:44 PM   #7
BowtieRocket
I see some dings in film, but no chips And, yes, it is removeable
Old 10-08-2016, 01:13 AM   #8
off1c3r
Drives: 2017 Camaro 2LT 50th
I opti-coat my vehicles and add Xpel film to the bumper. It's seriously good protection! I do many long trips so for me it's a no-brainer.
2017 50th Anniversary Edition 2LT V6
1100 - 09/26/2016 | 3000 - 09/28/2016
3100 - 10/04/2016 - TPW: 10/17/2016
3300 - 10/06/2016 | 3400 - 10/06/2016
4300 - 10/17/2016 | 5000 - 10/28/2016
off1c3r is offline   Reply With Quote
Old 10-08-2016, 06:52 AM   #9
E-Ray
Drives: 2016 Camaro 2SS, Nightfall Grey
Mine is a daily driver and I have a few small rock scrapes and chips but just don't worry anymore. The bad ones I use touch up paint on and keep going. Not going to let a few small chips keep me from enjoying my Camaro.
E-Ray is offline   Reply With Quote
Old 10-08-2016, 08:45 AM   #10
KirkH
I wish I could be like that. I sweat every scratch.
Old 10-08-2016, 10:26 AM   #11
RenegadeXR
RenegadeXR's Avatar
Drives: 2011 Camaro SS
Depending on the color of your car, paint chips are really easy to repair even for people like me who have no idea what they are doing. just spray the area with water, lightly rub some 2000 grit wet sandpaper inside the chip to slightly smooth it out and make a good contact surface, dab touchup paint inside it, let it dry, repeat adding coats once per 30 minutes until it's level with the existing paint or bubbling out a little. Wait a couple days so it can cure and get hard, then wrap the 2000 grit sandpaper around a pencil, spray the area with water again, and use it as a file to make it flat. Dry off the water from time to time to check your work (the water makes the job look deceptively good sometimes when it really needs more work.) At this point, if you did it correctly, both the repair area and the surrounding factory clear coat it will be flat but matte colored. Finish with compound or else just polish it. Either works, polishing just takes a bit longer. Easy stuff.
My car is black so it's pretty much impossible to see any small repairs. I also don't bother to add clear coat over the repair area. It's recommended, but I'll have to see how it holds up over time. Not a big deal if it needed to be touched up later on. Paint polished to a high sheen looks visually identical to areas with factory clear coat.
RenegadeXR is offline   Reply With Quote
Old 10-08-2016, 10:52 AM   #12
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
Agreed...for the novice look into DR COLORCHIP....
so easy.....
Old 10-08-2016, 09:08 PM   #13
carguy83
carguy83's Avatar
Drives: 2009 Pontiac SV6, 2016 Camaro 2LTRS
Yup I have found it chips easily! I've touched up four spots and like you it's a daily driver and I don't tailgate. I will be looking into protection of some sort in the spring
carguy83 is offline   Reply With Quote
Old 10-08-2016, 09:24 PM   #14
Moc96
I freaked out over the first couple, but I knew I'd drive myself into an early grave if I kept it up, so I try hard to take chips in stride now. Besides, I can't even see them from my favorite spot...the drivers seat.
Moc96 is offline   Reply With Quote
