Old 10-06-2016, 06:28 PM   #1
bseiter98
Parking car in winter
First, I apologize if this has been posted before. I have had muscle cars for many years and I typically do not drive the car in winter. Basically, I change the oil and then park my car I my garage. I start it once a week for at least 30 minutes and drive it down my driveway (when no snow). Then, I park the car in the garage for another week and repeat the same procedure. I have never had a problem with this, do you see any issues or concerns I should have relative to the 2016 2SS?
Thanks!
Brian
bseiter98 is offline   Reply With Quote
Old 10-06-2016, 06:32 PM   #2
RenegadeXR
RenegadeXR's Avatar
Drives: 2011 Camaro SS
I think that's too much work. Just invest in a Battery Tender Jr. to keep he battery topped off via a slow "trickle" charge. There are contact points in the engine bay for power and ground. Attach the leads to these and run the wires down through through the floor and then plug the included A/C adapter into a wall outlet all winter. Beyond this, I don't think you really need to do much assuming your winter is typically 3-4 months. You also don't really need to replace your oil any earlier than when the oil life indicator screen in the dashboard indicates it's time.
RenegadeXR is offline   Reply With Quote
Old 10-06-2016, 06:36 PM   #3
bseiter98
The reason I drive it is to simply charge the battery and eliminate potential tire issues. I don't know if this is a concern with the run-flats. Thanks!
Old 10-06-2016, 06:38 PM   #4
bigd1276
2017 HyperBlue 2SS
bigd1276's Avatar
Drives: 2017 HyperBlue Camaro 2SS
Mine sets all winter long. I may start it up every couple weeks and let it run for 30 minutes or so. Been doing that since I bought my 2010 Camaro back in 09. I've had no issues with doing it that way.
http://www.camaro5.com/forums/showthread.php?t=30755
2010 IBM 2LT RS......Traded for.....
2012 IBM 2SS RS......Traded for.....
2017 HBM 2SS
bigd1276 is offline   Reply With Quote
Old 10-06-2016, 06:45 PM   #5
RenegadeXR
RenegadeXR's Avatar
The following two tools will take care of everything from the comfort of your garage:
https://www.amazon.com/Accutire-MS-4...dp/B00080QHMM/
https://www.amazon.com/Battery-Tende...dp/B000CITK8S/
Total cost: $37. Well worth it. You eliminate the risk of the battery running flat, and the pressure gauge gives you a reading within 0.5 PSI in under a second. I use both of these pretty often.
Old 10-18-2016, 01:29 PM   #6
LibertyHill
LibertyHill's Avatar
Drives: 16 2SS 6MT NPP MRC / 15 K1300S
Here is a great deal on a much better marine grade trickle charger maintainer:
http://www.delcity.net/store/Portabl...0.h_807260.t_1
Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC
LibertyHill is offline   Reply With Quote
