Old 10-02-2016, 01:47 PM   #1
bryguycbr
bryguycbr's Avatar
Drives: 2016 2SS Nightfall Gray
Send a message via Yahoo to bryguycbr
CEL on, code is P0420
CEL on, I have a Bosch OBD II reader, plugged it in and it shows P0420 - "Catalyst System Efficiency Below Threshold Bank 1".
Does anyone know what this would be causing/failing. Car drives OK, power seems to be OK, I had a new Stainless Works catback exhaust installed about 150 miles ago.
Still taking in for dealership to investigate CEL, but wanted a heads up on what you guys think it might be. I don't think my dealer will give me any grief on the exhaust.
Any thoughts.......Thanks
2016 2SS, Nightfall Gray Metallic, Jet Black Leather, A8, MRC, Clear-Bra, ROTO-FAB CAI sound tube removed, Stainless Works Catback with AFM valves, ORACLE ghosted sidemarker set
bryguycbr is offline   Reply With Quote
Old 10-02-2016, 01:51 PM   #2
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Your exhaust screwed with the catalytic converter in someway. Prepare for this to be a customer pay issue, not warranty
Old 10-02-2016, 02:15 PM   #3
bryguycbr
bryguycbr's Avatar
I might take it to the guys that installed my exhaust and see what they think.
Thanks for reply.
Old 10-02-2016, 02:21 PM   #4
somewhatdamaged
somewhatdamaged's Avatar
Drives: 16' 2SS M6
Sure seems like there's a lot of folks throwing codes with that catback for whatever reason, seems odd that it would happen when it doesn't touch the primary cats.
somewhatdamaged is offline   Reply With Quote
Old 10-02-2016, 02:33 PM   #5
bryguycbr
bryguycbr's Avatar
The guys that installed the exhaust are big time motor heads, they might learn something more about the 2016 Camaro. They tried talking me into very extensive motor upgrades.......and I told them hold up on this, let me drive the car a bit before you start tinkering with increasing the HP, they want to do all kinds of sh**t to this car.
Update: I added a Vitesse Throttle Controller last week, I removed it today, and will clear the CEL code from the car using the Bosch OBD II scanner. I'm thinking maybe the Throttle Controller has something to do with this problem, I'll update this post to give details of results.
Old 10-03-2016, 04:06 PM   #6
bryguycbr
bryguycbr's Avatar
Cleared Check Engine Light using Bosch OBD II scanner, drove car for about 50 miles, all is good. Talked with exhaust installer (Twenty First Century Muscle Cars), he said sometimes cat will fail when new and it may only act up when starting cold engine, if CEL comes on and is same code (P0420) I'll take to GM dealer for repair, if GM does not want to repair, exhaust installer will replace cat, he has a lot of spares and will fix issue for free. I told 21st CMC I had a throttle controller installed, but he didn't think that should cause a CEL or cat to fail. So, I'll keep the throttle controller removed and try to put some miles on the car and update later.
Old 10-05-2016, 10:04 PM   #7
bryguycbr
bryguycbr's Avatar
Drove car, now have 6712 miles, check engine light still off, Vitesse Throttle Controller originally caused P0420 - "Catalyst System Efficiency Below Threshold Bank 1".
I will not use that again, I'm going to talk with them and see what they have to say about their item causing CEL to appear.
Old 10-05-2016, 10:53 PM   #8
Richard0nee
Richard0nee's Avatar
Drives: 2016 SS M6, NPP
Vitesse throttle controllers have been known to throw codes which is why I stay away from them. I know there are members that have used them with no problems so good for them.
Then again, I have no delays or sluggish throttle so I don't really need it anyways.
Richard0nee is offline   Reply With Quote
Old 10-06-2016, 12:35 AM   #9
1LE801
"Lohla"
1LE801's Avatar
Drives: 2016 1SS A8 :"Lohla"
That throttle controller is JUNK!
OG Trans and Diff but all else is upgraded. Twins bring wins ;-)
1LE801 is offline   Reply With Quote
Old 10-06-2016, 10:13 AM   #10
bryguycbr
bryguycbr's Avatar
I sent an E-mail to Vitesse explaining what happened, will be interesting what their reply is.
The few miles I had it installed, it worked OK, but in time rear tires will be worn out from excessive acceleration. The SS doesn't need any help with throttle.
Old 10-07-2016, 05:26 PM   #11
bryguycbr
bryguycbr's Avatar
I now have 6780 miles, no CEL, my best guess is Vitesse Throttle Controller caused CEL with code P0420.
Old 10-10-2016, 10:11 PM   #12
bryguycbr
bryguycbr's Avatar
CEL back on P0420, New Stainless Works Catback exhaust causing CEL, having it looked at this Thursday, this 2016 SS is very sensitive to any changes.
Old 10-11-2016, 12:07 AM   #13
Richard0nee
Damn that's some shit. Have them recheck all the weld points.
Keep us updated
Old 10-11-2016, 04:22 PM   #14
V8Addict
V8Addict's Avatar
Drives: 2016 2SS
guess you jumped the gun when you blamed the throttle controller.
2016 Hyper Blue 2SS, A8, NPP, MRC
V8Addict is offline   Reply With Quote
