#1 | |
![]() Drives: Camaro Lighting Experts Join Date: Feb 2012
![]() HDLED Switchback Halos: 2016-2018 Chevy Camaro Premium Introducing Diode Dynamics HDLED Halos! The first and only LED halos that are 100% Made in USA. ![]() Designed specifically for projector-style premium headlights on the 2016-2017 Chevrolet Camaro, includes custom-shaped halo rings with multiple functions: extremely bright white for the DRLs, lower-power white for night time use, and a brilliant amber for the turn signals. It will add a distinct, unique look to your 6th Generation Camaro both day and night! ![]() HDHalo Technology: These halo rings feature all the benefits of our exclusive HDHalo technology, including: - Proprietary durable phosphor coating, to create uniform, solid appearance. - Extremely bright, high-density LEDs that are visible even in direct sunlight. - Multi-function PWM drivers, fully waterproof, featuring low power, high power, and turn signal modes. - Integrated mounting tabs for easy installation. Order includes two application-specific halo rings, four halo-accents, two drivers, and two wire pigtails with T-tap connectors. Wiring: All wires have a durable braided wire covering. The LED has a 20-inch wire with female JST type connector. This connector may be de-pinned in order to run wires through small holes during installation. Both the input and output wire on the driver are also 20 inches each. A pigtail is included that is also 20 inches, with male spade connectors on the end to connect to factory wiring with included T-taps. You will have plenty of room to run wires anywhere you'd like. PWM Control: Aside from the high brightness and perfectly uniform output, one great feature of these halos is the PWM dimming control. The drivers have four wires, to be connected to any 12V signals as follows: White: Low Power, 50% brightness Red: High Power, 100% brightness Amber: Signal Black: Ground The white and red wires both activate the main color, at different brightness levels. For switchback rings, this is 6000K white. Your order will ship by default with "low priority" drivers, meaning that if both wires are powered, low power will take priority. This is convenient for connecting the red wire to a parking light or DRL signal, for use during the day as a high-power DRL. Then, if the white wire is connected to the headlamp power, they will dim down at night. Of course, this is completely optional, and you can just use one of the input wires if you'd like. The signal wire will output even higher power to the ring, so it cannot be run constantly, or the driver will overheat. It should only be connected to a turn signal. If you'd like amber for a running light, please select the single color amber rings. For single colors, the same drivers are included, so you can operate the light with low power, high power, and as a turn signal that switches off and back on completely while blinking. If you are interested in solid red halos for tail light use, just email us to request "high priority" drivers after you place your order. With high priority drivers, you can use a red halo as running, brake, and turn signal, without any extra drivers or controllers needed! Electrical Specifications: Input Voltage: 9-16V Input Power: Dependent on size, generally one watt per 10mm diameter in "high power" mode Total Light Output: Dependent on color and size. They're bright! Please contact us for exact measured output figures. Installation: If you are installing these in headlights or tail lights, professional installation is strongly recommended, as the factory lamps must be opened for installation. The halos must be custom-mounted in position using adhesive or beading wire using the integrated mounting tabs. If you wish, mounting tabs may be removed with a pair of clippers or basic sanding. 2016-2018 Chevy Camaro Premium Switchback LED Halos ![]() ![]() 2016-2018 Chevy Camaro Premium Switchback LED Halos If you have any questions, feel free to post or shoot us a PM. All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty. *PM us for the free-shipping code* (U.S. forum members only) -Nick C. ![]()
![]() Drives: 2016 Camaro RS Join Date: May 2016
Any updates or expected release date for the rgbwa drl and fogs?
2016 Summit White 1LT RS, Brembo Brakes, NPP Exhaust,Front Glowtie, Rear Red Glowtie, Adrenaline Red Interior
#7 |
#8 |
