Old 09-23-2016, 09:22 AM   #1
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
SS 1LE - no lift shift?
I noticed this in the Motor Trend story. It mentions no lift shift. I kinda doubt that they would straight up power shift, do we think the PTM in this car also has no lift shift on certain drive modes at WOT?
Old 09-23-2016, 10:08 AM   #2
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
I saw that too! Very interesting.
Old 09-23-2016, 10:32 AM   #3
Iroc_Z28
Iroc_Z28's Avatar
Drives: 2017 1SS 1LE
i noticed that as well... my assumption would be the no lift shift feature is activated through one of the PTM modes
Iroc_Z28 is offline   Reply With Quote
Old 09-23-2016, 10:47 AM   #4
Iron Oak
Club Motorsports Track Op
Iron Oak's Avatar
Drives: STI, Land Rover and future 1LE
If you watch the lightning lap on the 1LE you can see him no lift shift a couple times.
Iron Oak is offline   Reply With Quote
Old 09-23-2016, 10:57 AM   #5
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
It looks like he's lifting up on the accelerator pedal while shifting to me. Maybe I missed the specific instances you're talking about.
Old 09-23-2016, 11:21 AM   #6
Iron Oak
Iron Oak's Avatar
First shift in the video is a no lift @ 0:24
1:45 questionable but sounds like it
same with the shift at 2:10
Then he does a couple more no lift shits at 3:10 and 3:20
He doesn't do it every time but more often than not.
I'm not a huge fan of no lift shift, it just seems like an accident waiting to happen.
Old 09-23-2016, 12:08 PM   #7
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
How do you figure? I've used it on other cars, on track it's great.
Old 09-23-2016, 01:03 PM   #8
Iron Oak
Iron Oak's Avatar
I guess I am just used to lifting slightly when shifting. Especially when I drive a lot of different cars, its easy insurance for me. I rather not accidentally tac out a clients vehicle.
With this being my own personal car, I may give it a go again.
Same with Launch control, I'd rather just do it myself.
Old 09-23-2016, 02:05 PM   #9
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Well the car does cut timing when you press the clutch, it's not like straight up power shifting or anything like that.
Old 09-23-2016, 02:05 PM   #10
Thor142
Thor142's Avatar
Drives: 2014 2LS (traded in) 2015 1SS 1LE
So no lift shift is part of the active rev match correct? The car puts the RPMs at the correct speed for the gear you are going in to?
Thats worth a couple seconds alone. I suck at heel toe...
Thor142 is offline   Reply With Quote
Old 09-23-2016, 02:06 PM   #11
Iron Oak
Iron Oak's Avatar
I assumed as much. Good to get confirmation though.
Old 09-23-2016, 02:08 PM   #12
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Active rev match is for downshifting...throttle blipping.
No lift shift means at WOT you keep the throttle pinned, no lifting when you shift. The car senses the clutch engagement and kills a little timing to keep the revs in check.
Old 09-23-2016, 02:09 PM   #13
Boilermaker128
Drives: 2010 CobaltSSTC
It helps a ton if your turbo'd. you don't lose all boost just most of it.
Boilermaker128 is offline   Reply With Quote
Old 09-23-2016, 02:10 PM   #14
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Sort of. I haven't used it on the 6th gens, yet. I wouldn't doubt if it's evolved to that level...
On the 5th gen ZL1, it just held the throttle plate closed enough to avoid hitting redline while you engaged the clutch to shift. You were able to hold the accelerator to the floor and bang through the gears
