Old 09-22-2016, 02:30 PM   #1
ny tdi
ny tdi's Avatar
Drives: 2016 1LT V6 6MT Convertible
Convertible back seat removal
Hello,
I am a new proud owner of a 6MT 1LT V6 RS Convertible w/ Tech Package in Mosaic Black (no paint issues so far, woo hoo!). Really happy with my purchase, except for the non-folding back seat. This wouldn't be so bad, except that I can't seem to remove the rear back-rest either (like in the coupes). So like looks that convertible owners get the shaft: Can't fold the rear back rest, but you also can't remove it. Am I wrong about this? Anyone know how it's done on a convertible?
I absolutely love the car, and after upgrading to leather leather kneepads, the car is just about perfect for me. 8" MyLink screen and the new knee pads really spruce-up the interior, and the RS Package makes sure I fall in love every time I approach the car.
Just wish I had pass-through access to the trunk...
ny tdi is offline   Reply With Quote
Old 09-22-2016, 04:00 PM   #2
thickstunalex
Drives: Coming: 2017 Camaro SS Vert
Unfortunately it's not designed to be removed as it would expose the convertible top when it's in the stored position.
thickstunalex is offline   Reply With Quote
Old 09-22-2016, 04:15 PM   #3
Drags1998
Drives: 15 SilveradoLTZ,162SSVert BlazerRS
I have a Vert and could not figure it out either. My only though is that the area is Made so that it adds structure to that part of the Body.
Drags1998 is offline   Reply With Quote
Old 09-24-2016, 08:15 AM   #4
ny tdi
ny tdi's Avatar
Probably, the car does handle very well for a convertible. Just wish we could figure this out!
Old 09-24-2016, 08:22 AM   #5
fastball
Drives: 2017 Camaro 2SS 6MT
Yes there's extra chassis bracing behind the back seat in the convertible that isn't in the coupe. Even if you removed your back seat you'd never be able to pass anything through the trunk.
fastball is offline   Reply With Quote
Old 09-24-2016, 08:59 AM   #6
ny tdi
ny tdi's Avatar
Crap! Well, at least the extra bracing makes the convertible handle well on the twisty roads!
Old 09-24-2016, 05:53 PM   #7
Warsteiner
Warsteiner's Avatar
Drives: 2016 Red Hot 2LT RS Vert
There are 2 tabs in the top of the seat. Depress those with a finish tool and you can fold the seat forward. There are a lot of electronics behind it as well as the motor for the top.
Warsteiner is offline   Reply With Quote
Old 09-24-2016, 07:30 PM   #8
ny tdi
ny tdi's Avatar
Hey Warsteiner,
Thanks for the tip. Car is at the Dealer due to some trim pieces popping off. But I'll give it a shot as soon as I get it back on Monday!
Old 07-04-2017, 04:12 PM   #9
THR ZL1 #1
Perma Grinning
Drives: 2012 Tom Henry Racing ZL1
OK, doing this now . .
Seat back:
there are 2 metal clips that is you pull the seat back forward just a bit you can see the clips and push them down to un clip.
at the bottom of the seat back are two 10 mm nuts . . then the seat back comes out.
Seat bottom has a pair of plastic clip cups . . ultimately yank up at the middle front of each seat bun,
Our Garage:
2018 Traverse High Country, 2017 Tom Henry Racing ZL1 Convertible, 2016 Silverado High Country HD, 2014 Camaro SS Convertible, 2012 Tom Henry Racing ZL1, 2002 Berger SS Phase II, 2001 Camaro SS Convertible, 1997 Hendrick Motorsports 30th Anniversary LT4 SS, 1992 Camaro RS Z03 25th . . .
THR ZL1 #1 is offline   Reply With Quote
Old 10-08-2017, 09:10 PM   #10
LtColumbo
LtColumbo's Avatar
Drives: 2017 1LT RS V6 A8, 2020 Fusion
I've got a coupe and I'm trying to remove the rear seats to put on seat covers. Removing the backrest part was easy, but I can't release the front of the seat bottoms. I've yanked pretty hard, using "reasonable force" and they don't budge. I even tried a large screwdriver as a pry bar, in the center on each side, protecting the seat cushion with a piece of vinyl flooring and wound up poking a hole in the flooring. I've read of people breaking the plastic retainers. The seat cover place said I could come down there, but I don't want some animal in there tearing things up.
Suggestions?
LtColumbo is offline   Reply With Quote
Old 10-08-2017, 09:13 PM   #11
Donner
Drives: 2017 50th SS convertible
+1
Donner is offline   Reply With Quote
Old 10-09-2017, 09:02 AM   #12
camaromike77
camaromike77's Avatar
Drives: S O L D
+2
Club F1FTY
Old 02-10-2021, 11:02 PM   #13
Kimberly1226
Kimberly1226's Avatar
Drives: 2021 Convertable SS2
I have a 2021 Convertible SS2 and I have pulled pretty hard on the back rest, I'm afraid to break something. Is it different on the 2021? I would like to put some sort of a seat cover on so my seats are.protected from my dog.
Kimberly1226 is offline   Reply With Quote
Old 05-11-2025, 07:09 AM   #14
Dabiznizman
Drives: 2017 camero Rs Convertable
You have to go throught the speaker hole. Pull the side cover off. Its only clips. Then you have to pull out speaker. It will give you access. To run wire through. Leave top up. Either side will work.
Dabiznizman is offline   Reply With Quote
