![]() Drives: 2016 1SS Camaro Hyper Blue Join Date: Mar 2015
I just purchased SS OEM Leather Take Off's Need help with OEM dash button...
Hello all. I just purchased OEM SS Leather Skin take off's on EBAY. Feel pretty fortunate to find the exact color match and striping as my cloth interior. I'm going to have the local shop install them. I'm also going to have them install heated seats as well. Any ideas on how I can go about purchasing the OEM Heated Seat Control toggle for the dash? I can see a blank filled option on my dash, was hoping to use the OEM switch / look to activate the seats.
Any help greatly appreciated! -Scoob |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
i doubt thats gonna happen using the same function as factory and if going that route almost certain someone at a dealer would have to mess with the programming to get it work.
![]() Drives: 2016 Mosaic Black 2SS Join Date: Dec 2013
Not being hugely up on what seat heat tech is at these days I would concern myself with amperage and access to the 12v system, the controls size will dictate the logistics of where the switch can go..best of luck
Thanks for the input. Found the part number for the replacement dash strip that has the seat heater button control. A buddy of mine seems to be confident that he can get it to go- I'll post an update in the next couple of weeks.
#5 | |
Drives: 2017 Camaro 2SS 6MT Join Date: Aug 2006
In short it's not going to work. Your friend doesn't understand modern cars. Frankly if he thinks he can "give it a go" I wouldn't let him within 20 feet of my car. Adding heated seats you will need to install your own switches, relays, wiring. It can be done by someone who does know what they're doing, just not with the factory parts from the "2" trim level. |
#6 | |
dont even think that switch would be able to run your own custom circuit with a relay.
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL-1 Join Date: Feb 2009
Seat heaters using the resistance mat use a lot of amperage and have specific controls and fuses/realys.
#8 |
does anyone make logic boards that would enable these types of switches to work with a relay?
#9 | |
If this guy lets his friend try to Jerry rig it he's going to f--k his car up. |
#10 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro SS Join Date: Apr 2013
Would you sleep at night directly next to a home-made space heater with sketchy wiring? You're basically doing the same thing here, if not worse since your body is in direct contact with the thing... |
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Hyper Blue 1SS Join Date: Jul 2015
How much was leather? And good look, post results, think I may follow suit, minus heated seats.
1ss/Auto-Hyper Blue
acs carbon flash spoiler, bmr springs, gm clear tails. Texas speed cam, 223/227 .635/.635 116 LSA, Kooks Long Tube Headers with green cats, MSD Atomic Air Force Intake, CAI Cold Air Intake, QTP cutouts. 503 hp Best so far 11.5 at 123 with a 1.83 60ft. BMR lower and upper trailing arms and upper control arms,E85 DELIVERED 12/29/15 http://youtube.com/bybcous " no talking only racing on my youtube" |
#12 |
Thank you for your replies. I will just have him use the switch that comes with the heated seat kits then. To answer the question on the skins... I was able to purchase them for $900 for all seats. I think its a fair deal for factory leather.
#13 |
![]() Drives: 2018 2SS 6MT Hot Wheels Edition Join Date: Jul 2016
I saw a set on eBay but they were for the convertible and were $800
#14 |
