Go Back   CAMARO6 > Marketplace > Vendor and Seller review / feedback / experiences
Old 09-19-2016, 08:15 PM   #1
ender2664
Drives: 2016 2SS
Need for speed
A horrible shop!
I will give full details once I am through dealing with GM corporate. That's right...they are forcing me to deal with GM CORPORATE!!!
in the mean time...AVOID lest your car and warantee be destroyed!
ender2664 is offline   Reply With Quote
Old 09-19-2016, 08:17 PM   #2
Richard0nee
Richard0nee's Avatar
Drives: 2016 SS M6, NPP
Oh man, would like to hear the details.
Richard0nee is offline   Reply With Quote
Old 09-19-2016, 08:18 PM   #3
MiamiBlueCamaro
MiamiBlueCamaro's Avatar
Drives: Gen 6 Camaro RS
Old 09-19-2016, 08:20 PM   #4
ender2664
Drives: 2016 2SS
Once I figure out if the entire vehicle warantee is not going to be scrapped I will get into the details.
Just wanted to get this up as soon as possible incase a non disclosure agreement is plead to and I need to keep my mouth shut from then on :/
Old 09-19-2016, 08:27 PM   #5
Richard0nee
Is this Need for Speed motorsports in Gledale?
Well since you mentioned warranty I'm taking it some kind of power adder install went wrong.
Old 09-19-2016, 08:36 PM   #6
ender2664
Drives: 2016 2SS
Need for Speed Motorsports in Glendale
Old 09-19-2016, 08:47 PM   #7
cleoent
cleoent's Avatar
Drives: 16' Camaro E-Force SS
I'm assuming it is his tires being too wide he messed up the harness which has caused issues.
If that's the case this is 100 on the OP. Sorry man. All you had to do was spend 3 minutes searching and you would have found the posts saying that the harness needs to be relocated.
cleoent is offline   Reply With Quote
Old 09-19-2016, 08:49 PM   #8
ender2664
Drives: 2016 2SS
Wrong
Old 09-19-2016, 09:09 PM   #9
JFM-jr
JFM-jr's Avatar
Did you have a tire rubbing issue on the harness of both rear wheels on your car?
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB
Rotofab
ARH 1 7/8 longtubes hi flow cats AFM deleted E85
11.0@124.9
11.65@118.8 pump gas,stock tune/exhaust
New combo: Pray Performance Heads/cam
MSD intake manifold and Circle D 3C
554/491 on E85 all work & tuning done by Pray
JFM-jr is offline   Reply With Quote
Old 09-19-2016, 09:12 PM   #10
Richard0nee
My guess... that he tried to squeeze a few more HP and the following happened:
1. Something went wrong, shop didn't do the install correctly, didn't want to take responsibility and told the OP it's a defective part from GM, go to GM for resolution.
2. Something went wrong, shop did do the install correctly, didn't want to take responsibility and told the OP it's a defective part from GM, go to GM for resolution.
Either way, shop is not taking responsibility and told the OP go to GM.
This shop is about 40 mins away from me.. haven't heard much about them but knew of them.
It's a GRAY area for both side... Sucks that it happened.. well, whatever happened!
Old 09-19-2016, 09:15 PM   #11
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
If modifications caused a problem, the warranty will not cover it. The car is at a speed shop. It's not that hard to figure out. Not sure what the beef with GM would be...
But then again, that's this thread's purpose so far....Feed the guessing game.
Old 09-19-2016, 09:59 PM   #12
motorhead
Why do people start threads like this? What do they accomplish?
Old 09-20-2016, 02:57 PM   #13
MrChrisLS3
Drives: 2018 1SS M6
I love guessing games
A) OP purchased wheels and tires ad had them installed at their shop.
-Wheels were too wide or improper offset and caused damage
B) Shop either did not know this would happen or did and failed to warn OP about a known issue.
C) Shop did inform OP that the wheel and tire size may cause an issue and OP wanted them anyway.
Regardless of the scenario, GM is out of the picture. If the aftermarket wheel and tire package caused the issue, regardless of what the manufacturer of the wheels claims about fitment, it does not fall under warranty, and any and all consequential damage is not covered.
MrChrisLS3 is offline   Reply With Quote
Old 09-20-2016, 03:17 PM   #14
Perdieu
Perdieu's Avatar
Drives: 2017 Nightfall Grey Auto 2SS
I've been working with Paul @ Need4Speed and haven't had any issues. Can't wait to see what this "issue" is.
Perdieu is offline   Reply With Quote
