09-16-2016, 08:58 PM | #1 |
Drives: red Join Date: Jun 2016
Output shaft failure?
Just got my 2010 m6 SS earlier this summer it only has 19k miles on it. Today as I was driving I started to notice that my car was sputtering in first as I would take off and I could feel something knocking in the shifter as if every rotation it would do it. I just read that their was an output shaft problem in earlier models of 2010's. Really stumped on this one
09-16-2016, 10:47 PM | #2 |
If your output shaft fails I don't think you will be going anywhere. You may look to your clutch for the symptom.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, 100 cell Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears. |
09-17-2016, 09:47 AM | #3 |
In The Circle
Drives: 2010 Camaro 2SSRS IOM M6 Join Date: May 2009
If output shaft failed it breaks and the car does not move at all. You have a different problem.
09-17-2016, 05:50 PM | #4 |
Drives: 2010 2SS Camaro 6sp. Join Date: Jan 2012
Mine has 43,000 miles and no issues. Sounds like you could have a branch or somthing wrapped around the drive shaft.
09-18-2016, 06:13 AM | #5 |
I.AM.
Drives: 2011 2SS/RS/A6 cammed-n-whippled Join Date: Oct 2008
What's the last 5 digits of your vin #? The output shaft issue was fixed around #26,000. But, I agree, doesn't really sound like it's the problem here.
NY5thgen.com
