Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > Exterior Parts & Accessories
Old 09-15-2016, 12:42 PM   #1
Diode Dynamics
Diode Dynamics's Avatar
Drives: Camaro Lighting Experts
Arrow New! Camaro RGBWA DRL from Diode Dynamics! Multi-color w/Switchback! USA Made!
Teaser: 2016+ Chevrolet Camaro RGBWA DRLs from Diode Dynamics!
Full RGBW Multi-color functionality w/integrated Switchback Turn Signal feature!
The only USA Made LED Board Replacements!
These modules are a direct replacement for the factory-installed headlight LED panels in the 2016+ Chevrolet Camaro equipped with the premium package headlight housings.
From the factory, the DRL LEDs in the headlight are illuminated by a circuit boards that holds white LEDs. Our RBGWA multi-color board is a drop-in replacement. You don't have to align and fasten LEDs- this is an OEM-grade solution. Just remove the old panel, and ours fits directly in place, with patent-pending fit and finish.
Made in USA.RGBWA - The replacement panels utilize RGBW and Amber LED chips for full multi-color functionality, a crisp true white color, and a bright amber turn signal with plenty of output for daytime visibility. The white setting will have more visibility than the OEM-white
PWM DRL Brightness Settings - Our DRL LED board replacements also feature built-in PWM dimming to retain the low-power and high power settings for daytime and nighttime use, for a true OEM quality effect.
Remember, this product is not just RGBW - it is RGBW-A! That means there is an LED chip that is specifically white in color, right next to the standard red, green, and blue chips, in addition to an amber LED for the turn signal function. By using an RGBW controller rather than the standard RGB, you can activate and control the white chip independently of the colors. This provides a much more uniform, pure, and bright white color than the traditional method of combining all RGB signals.
To drive the LEDs safely, a new constant-current driver is included for each set, for high reliability. You will also need a standard RGB or RGBW controller. Controllers can usually be powered by any standard 12V source. We recommend connecting to the parking light signal, so this module lights up when the parking lights or headlights are on, or to the factory power input signal.
For OEM-grade reliability, the LEDs are protected by a thermal management system, which is integrated into the panel and driver. If the temperature of the LEDs becomes too high for any reason, the output of the LEDs will decrease, to ensure long life in even the harshest environments. And of course, the advanced constant-current driver ensures that there will be no damage to the LEDs long-term from the harsh electrical system of the vehicle.
Professional installation is strongly recommended, as the factory headlights must be opened in order to replace the LED panels.
All Diode Dynamics products are backed by a 3-year replacement warranty.
This product will be available in early October and is made right here in St. Louis, Missouri!
If you have any questions, please don't hesitate to post, PM, email contact@diodedynamics.com or call us: (314) 205-3033
Thanks for looking!
Nick C.
Diode Dynamics
John C.
Diode Dynamics
Follow Us: FB // IG // YT // TikTok
Diode Dynamics is offline   Reply With Quote
Old 09-15-2016, 12:51 PM   #2
Diode Dynamics
John C.
Diode Dynamics
Old 09-15-2016, 01:32 PM   #3
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
My only question would be how difficult is the install???
Old 09-15-2016, 01:36 PM   #4
Diode Dynamics
They will require you to open up the housings, but the boards themselves are a direct replacement to the OEM units. They are 3D-laser scanned for 100% perfect fitment.
Also, we have a vast network of authorized installers if you don't wish to perform the installation.
Thank you,
Nick C.
John C.
Diode Dynamics
Old 09-15-2016, 01:41 PM   #5
Techn9cian805
The BEAST
Techn9cian805's Avatar
Drives: '16 2SS, '89 Wife
DUUUUUUUUUUUUUUUUUUUDE!
I have a question: will you guys also offer matching light mods for the fog lights?
Scarlet: 3/3/16: 2SS Red Hot, M6,
Instagram: @luis_what_it_is
Techn9cian805 is offline   Reply With Quote
Old 09-15-2016, 01:42 PM   #6
Mr. Grumpy
Car Enthusiast
Mr. Grumpy's Avatar
Drives: 2017 Camaro SS FIFTY
Is the white DRL light as bright as the OEM DRLs? I love the amber turn signal idea but I don't want to lose the OEM DRL brightness.
2017 SS Camaro FIFTY
6MT, Nav, NPP, Black Bowties, Mishimoto OCC, Skip Shift Eliminator, GM Footwell Lighting, NGM Splash Guards, GM Blackout Tail Lights (SOLD)
Mr. Grumpy is offline   Reply With Quote
Old 09-15-2016, 01:52 PM   #7
Diode Dynamics
Our engineering team is working on the DRL's as well, we may be able to depending on the design of the housing and the components inside
Nick C.
John C.
Diode Dynamics
Old 09-15-2016, 01:54 PM   #8
Diode Dynamics
The RGBW white setting is brighter than the OEM DRLs, it also has two PWM Dimming DRL settings (full power & half power) to retain OEM functionality
Thanks!
Nick C.
John C.
Diode Dynamics
Old 09-15-2016, 02:45 PM   #9
Emoto
Sure, why not?
Emoto's Avatar
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon
How is this controlled? In other words, is there a method to make the color change from x to y in the cabin, or must one open the housings to make a change?
Emoto is offline   Reply With Quote
Old 09-15-2016, 02:47 PM   #10
Diode Dynamics
It's controller via remote, or with our new RGBW bluetooth phone app (coming soon).
Nick C.
John C.
Diode Dynamics
Old 09-15-2016, 03:13 PM   #11
Emoto
Sure, why not?
Emoto's Avatar
Nick C.
Very interesting. Thanks!
Old 09-15-2016, 03:22 PM   #12
Diode Dynamics
You're welcome!
Let us know if you have any additional questions
Thank you,
Nick C.
John C.
Diode Dynamics
Old 09-15-2016, 03:30 PM   #13
Diode Dynamics
They will look great when paired up with our Universal RGBW™ Demon Eyes!
Nick C.
John C.
Diode Dynamics
Old 09-15-2016, 05:59 PM   #14
Hyper1SS
Hyper1SS's Avatar
Drives: 2016 Hyper Blue Metallic 1SS M6 NPP
Awesome!! Can't wait. I installed my own on my two 5th Gen Camaro's. So basically the same thing where you have to bake your headlights to open them? With these with the white and amber work with simply plugging them into the factory connector but to change colors you will need the controller?
2016 Hyper Blue Metallic 1SS M6 with body color hood vents, Silver broken 5 spoke wheels, NPP dual exhaust, Dark Night Interior Spectrum Lighting, Illuminated door sills plates.
Upgrades include: Roto-Fab intake, Mishimoto catch can, MBRP cat-back Race exhaust, TSP 1 7/8 headers, EFI E85 Flex Fuel, MRR M017 graphite wheels with Nitto N555 G2 tires, Goodridge stainless steel brake lines, Powder coated Brembo calipers, BMR suspension, Eibach sport springs, Emblempros fender badges
Order ID: TDHQMS
1100 on 01/07/2016 at Penske Chevrolet
6000 on 02/23/2016 Delivered to customer
Hyper1SS is offline   Reply With Quote
