Old 09-13-2016, 05:04 PM   #1
cjfeola
cjfeola's Avatar
Drives: 2016 Convertible 1LT 2.0T
1LT vert base stereo-Anyone upgraded just the speakers?
Hi everyone,
Proud owner of a 2016 Summit White 1LT convertible. Love this car! Driving it all over Texas with the top down and the stereo booming. Got a great deal buying a leftover 2016, but that meant there were a few things I didn't get. Totally worth it for the amount of money I saved.
First up is the sound system. I'm actually happy with the head unit; the 7" is fine. (Had an 8" in a Malibu loaner for two weeks; didn't see anything I wanted to pay for on it.) The speakers, however, are .... muddy at best.
Has anyone tried upgrading just the speakers? Really great 6s and 6x9s are not that expensive. I'm thinking I'm probably going to need an amp, though.
Thoughts?
And PS: You can buy the Bose OEM speakers on Amazon. Anyone tried them with the base head unit?
Cjf
cjfeola is offline   Reply With Quote
Old 09-14-2016, 07:04 AM   #2
TMPSU75
Drives: 2016 Camaro 'Vert 1LT- RS, NPP, 6MT
Originally Posted by cjfeola View Post
Hi everyone,
Thoughts?
Cjf
Hey CJF.......
I'm in the same boat as you.
After bringing my 'vert to my favorite high-end A/V shop (WWS in Montgomeryville, PA) the best, first upgrade would be adding a subwoofer with a separate amp. The base speakers are NOT bad, but they can't drive the lower bass without distorting.
I am close to pulling the trigger on my new set-up, so I will keep you posted. Considering one of these:
http://www.jlaudio.com/cs110lg-tw3-c...-systems-93304
http://www.jlaudio.com/cp110lg-tw1-2...-systems-93323
http://www.jlaudio.com/cp108lg-w3v3-...-systems-93133
You need to get a very slim design, so it easily fits in the trunk under the drop-top. All 3 of the above fit fine! JL Audio makes the best subs. Have used JL subs many times in previous vehicles.
You can always replace the door speakers later!
Hope this helps.
TM
TMPSU75 is offline   Reply With Quote
Old 09-14-2016, 12:57 PM   #3
SM1
Drives: 2016 1LT V6 Vert HBM+white stripe
Originally Posted by TMPSU75 View Post
Hey CJF.......
Hope this helps.
TM
How much are you looking at for those subs? I agree the base stereo needs one, but want to know what I'm in for. Was thinking about a slim (possibly powered) sub under the folding top and then something like this for the front and rear speakers:
http://www.crutchfield.com/p_206PXA3...2544985&awdv=c
Compact, easy to hide, and should be a nice boost over stock without rattling the car to pieces.
Side note, I live about 5 minutes from WWS in Montgomeryville!
SM1 is offline   Reply With Quote
Old 09-14-2016, 07:50 PM   #4
Warsteiner
Warsteiner's Avatar
Drives: 2016 Red Hot 2LT RS Vert
The subs run from $250 to $350 on Amazon. If you want to amp all of your speakers I would go with a single 5 channel amp like this: https://www.amazon.com/Alpine-PDX-V9...Cp_89%3AAlpine
You will also need some line out converters of some kind.
I think you could most like get everything for under $1000 including all of the stuff you need for install.
A local shop will of course be a little more expensive.
Warsteiner is offline   Reply With Quote
Old 09-15-2016, 08:32 AM   #5
ctrlz
You need to know the impedance of the stock speakers before you replace them with aftermarket or Bose. The Bose speakers are mostly 2-ohm impedance. If the stock speakers are 2 ohm, you can replace them with most anything (but stick with 2 ohm or your replacement will not be as loud). If the stock speakers in the base system are 4 ohm, that means the base amplifier is not 2 ohm stable and will overheat with a 2 ohm load.
Old 09-16-2016, 11:09 AM   #6
cjfeola
cjfeola's Avatar
Hey CJF.......
Hope this helps.
TM
Thanks for tip! After I read this, I tried turning the bass all the way down in the tone controls. You're right! The stock speakers aren't half bad when low bass isn't muddying them up. Really interested in how your upgrade turns out - it sounds like the right first step!
Cjf
