![]() Drives: 2016 NFG 2SS Join Date: Apr 2016
Service Rear Vision System
Hey guys, I got this message twice in the last month and I didn't think much of it. Today on my way to work, my left blind spot system was acting up; there was no car beside me, not even a car traveling in the opposite direction and it lit up and turned off and lit up again for no reason. And also, it usually lights up when there is a car stopped next to me at a red light per say, but now it doesn't... Issue or normal operation?
2016 NFG 2SS NPP MRC
2015 GTI (totaled) |
Pills are for Pansies
Drives: 2023 2SS Red Hot Vert Camaro Join Date: Jul 2008
I never got that message, but I had that start happening to me last week during rainy weather - both sides! It did however, react properly when a vehicle was actually next to me. It was frustrating though when it kept doing it when there was nothing there.
![]() ![]() ![]() ![]() Drives: '16 2SS GD1 MX0 NPP F55 IO6 Join Date: Jun 2013
The blind spot indicators use the rear parking sensors. They can have false positives as you drive by something that is within 15ft of the rear corner of the vehicle. Something as simple as a barricade can register. All it senses is a different in distance from the sensors while the vehicle is in motion. It cannot tell if something is a vehicle.
If you are at the red light first before the car next to you rolls up, it should go off briefly as it passes your rear bumper. If you pull up next to a car that is stopped first, it hasn't crossed the rear sensors and they would not go off. As for your service rear visions system warning. That can be a loose connection or bad insulation around a connector allowing moisture. You should let your local dealer take a look to make sure everything is snug. |
![]() Drives: 2017 Camaro 1SS Join Date: Jun 2014
They replaced the camera in my 1SS to fix the rear vision system - twice in a month it said the same thing as you on the screen.
Hyper Blue | A8 | NPP Dual Mode Exhaust
![]() Drives: 2016 2SS White M6 Join Date: Jul 2012
I've gotten the "Service Rear Vision System" warning a couple of times when it was raining.
2016 2SS M6, NPP, MRC, Sunroof, Nav, mostly stock. |
![]() ![]() Drives: Coupeless :( Join Date: Jan 2015
Sounds like some part of the system isn't water tight.
#7 |
#8 |
Lol thanks guys for the help on this matter. totally off-topic, but I think I felt my A8 transmission slip today. the shift was very delayed and it feels like a bad manual shift, not jerky, but the shift wasn't smooth and it was on light-medium throttle.
#9 |
![]() Drives: 2SS Join Date: Sep 2016
Got the same message today @ 320 miles.
Do not believe it's related to moisture exposure. Happened immediately after I was checking the camera settings in the menu. Camera still works. Symbols and lines no longer show. |
#10 |
Dealer said my car threw no codes whatsoever. but my engine oil was underfilled? weird as it was topped off like 500 miles ago. This is bad? it's eating lots of oil, but then again they only added 1/2 quart this time, but that's 1 full quart for 1800 miles.
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
i dont have blind spots as i have a 1ss but i had the rear camera **** up once or twice lol
#12 |
![]() Drives: Camaro 2016 RS Join Date: May 2021
I cleaned the parkimg sensors with my finger and the problem was gone.
#13 |
![]() Drives: 22 Camaro 2SS, 20 Subaru Crosstrek Join Date: Aug 2021
5 years...
Earth is an oblate spheroid
2022 | 2SS | M6 | NPP | Summit White | Carbon Flash Wheels | Black Lugs | Red Calipers | Adrenaline Red | Red Knee Pads | Nav | - 1100 - 8/16/21 - 3000 - 9/21/21 - TPW 10/18/21 - 3400 - 10/1/21 - 3800 - 10/20/21 - built 10/19/21 - 5000 - 11/12/21 - 6000 - 11/13/21 |
