Old 09-09-2016, 02:08 PM   #1
MXSG
MXSG's Avatar
Drives: 2016 1SS
Jerkiness in 3rd Gear (M6)
Has anyone experienced any jerkiness in 3rd gear in the manual? It only seems to happen when I'm accelerating normally. For example, as I'm starting off I shift from 1st to 2nd at around 3k-3.5k and then to 3rd at the same RPM, give it just enough throttle to get up to speed and then when I let off the gas there is always a very noticeable "lurch". Rev match doesn't seem to affect it either.
MXSG is offline   Reply With Quote
Old 09-09-2016, 02:24 PM   #2
jeverton
jeverton's Avatar
Drives: 2017 Camaro 50th Anniversary 2SS
Take a look here... http://www.camaro6.com/forums/showthread.php?t=465613
50th Anniversary Edition 2SS, NFG, BLACK, M6, MRC, NPP, BLACK BOWTIES
Build Date: July 21, 2016
Production Sequence: 934
jeverton is offline   Reply With Quote
Old 09-09-2016, 04:16 PM   #3
MXSG
MXSG's Avatar
Drives: 2016 1SS
Originally Posted by jeverton View Post
Thanks! Yes, that sounds similar to what I was trying to describe. As long as it falls under the "it's normal" category then I'm not going to worry about it.
