Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Forced Induction - V6
Old 09-07-2016, 06:58 PM   #1
alstonye
alstonye's Avatar
Drives: 2012 camaro IPF supercharged V6
IPF supercharger pulley
Hi, all.
I have a 2012 IPF supercharged camaro V6. Few months ago, the belt of supercharger broke, and the installer says one of the pulley had a bad bearing in it causing the pulley not able to rotate anymore. Then, he replaced the new bearing and belt. Today, I went to auto repair and check my car. They found there is a dent on edge of pulley of my supercharger. I am not sure what the reason is causing the bad bearing or pulley. Is this because of the installer of supercharger, or something? he sucks? Any ideas or thoughts? I am going to have a long trip, and I just do not want the belt to break or my car break down again.
Thanks, guys!
alstonye is offline   Reply With Quote
Old 09-07-2016, 07:14 PM   #2
tlavoie87
Built Not Bought
tlavoie87's Avatar
Drives: 2010 Twin Turbo LFX
there was a bad batch of bearing that they originally came with and ipf was supposed to send new ones to existing customers.. boco bearing makes a good replacement 6003 is the bearing make sure its abec 5 at least.. as far as belt go with a gotorback or continental same company really good belt.. as far as the pulley thats tuff to say could have been damaged when being installed who knows .. if you need another stock pulley for the charger itself 3.8 i have one has about 100 miles on it ill sell cheap
2010 Twin Turbo LFX
In Memory of my DAD Gone but never Forgotten 2014
"Built Not Bought!'
Sponsors:
OverKill Motorsports
tlavoie87 is offline   Reply With Quote
Old 09-08-2016, 07:36 AM   #3
derek1387
Drives: 2015 1LS Red V6
Post a picture of what you are having troubles with. A dent on the pulley wont be because of a bearing. But we can at least tell you if it could cause problems based on where its at
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Dream Gear Mobile Audio
Thanks to Will @ Overkill Motorsports, Jason @ JacFab, Jim @ Ohio Speed, Brandon at Dream Gear, and the boys at Randy Curnow Chevrolet
5th Gen V6 Performance Facebook Group
derek1387 is offline   Reply With Quote
Old 09-08-2016, 08:02 PM   #4
alstonye
alstonye's Avatar
[IMG][/IMG]
Old 09-08-2016, 08:06 PM   #5
alstonye
alstonye's Avatar
[IMG][/IMG]
Old 09-08-2016, 08:14 PM   #6
alstonye
alstonye's Avatar
Few months ago, the belt just broke, and the installer says one of pulley had a bad bearing in it causing the pulley not able to rotate, and then he replaced 2 new bearings. So I thought the pulley would be fine. But I checked my car yesterday, and it seemed the pulley is not good. Not sure what problem it is. By the way, I found someone says should install the upgraded idler pulley bearings(4 of them), but I only saw there are 2 pulleys com with 2 bearings. Do I need replace 4 of them? I just contacted KPE and ordered 2 upgraded pulley, and it come with 2 bearings.
Old 09-08-2016, 08:47 PM   #7
tlavoie87
Built Not Bought
tlavoie87's Avatar
yes 2 pulleys 2 bearings in each pulley .. looks like they seized and over heated .. kpe does a new version of the pulley not sure if the belt size changes because there bigger though.. what did he charge from the new pulleys ?
2010 Twin Turbo LFX
"Built Not Bought!'
Sponsors:
Old 09-09-2016, 03:14 AM   #8
derek1387
They are offering the new pulleys and corrected belt.
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Old 09-09-2016, 09:18 AM   #9
DGM
DGM's Avatar
Drives: 2013 Camaro 1LS - Ashen Gray
wow...
"WIDOW" Overkill Edition w/Mace Cams,80mm tb,Jacfab spacer/ported intake,Alky Control,ARH off road pipes,SOLO custom system,3.91 gears, MGW,Phantom grilles,ZL1 appearance pkge, 3dCarbon vents, Lingenfelter hood and spoiler, PLX boost/wideband modules/gauge,ZL1 fuel pump,LF3 hpfp,DSS aluminum driveshaft,JPSS sway bars, Z28 replica wheels and CxRacing coilovers..
DGM is offline   Reply With Quote
Old 09-09-2016, 09:56 AM   #10
tlavoie87
Built Not Bought
tlavoie87's Avatar
Cost?
2010 Twin Turbo LFX
"Built Not Bought!'
Sponsors:
Old 09-09-2016, 10:35 AM   #11
derek1387
Originally Posted by tlavoie87 View Post
Cost?
I am not sure. Haven't been told the price but give Jay a call and he can get you all of the info.
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Old 09-09-2016, 11:43 AM   #12
tlavoie87
Built Not Bought
tlavoie87's Avatar
I I'll do .: still waiting for an invoice for the power steering adapter lol
2010 Twin Turbo LFX
"Built Not Bought!'
Sponsors:
Old 09-09-2016, 05:51 PM   #13
alstonye
alstonye's Avatar
I am not sure what the price is now. My car is still in the auto repair, and waiting for the new pulleys arrived. I will tell you the price when I get the receipts. Just like the pictures I posted, I just saw there are 2 idler pulleys in the supercharger( IPF idler 1 and 2), and one pulley come with one bearing. So should be 2 pulleys and 2 bearing in total. But you says 2 pulleys and 2 bearings in each pulley, may you explain this for me? Sorry for the noob question. I just ordered 2 pulleys with upgraded design form KPE, and just want to make sure I did not miss another bearing or pulleys, and would replace all the upgraded design of pulleys.
[IMG][/IMG]
Old 09-09-2016, 06:48 PM   #14
tlavoie87
Built Not Bought
tlavoie87's Avatar
maybe these pictures will help makes sense of it ..here a top view one picture is with 1 bearing and the second is with both bearings "sandwiched" together
2010 Twin Turbo LFX
"Built Not Bought!'
Sponsors:
