Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Wheels and Tires Talk Sponsored by The Tire Rack
Old 06-18-2008, 11:44 AM   #1
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
Pedders is Ready for Camaro!!!
Hi to all,
Just a heads up on the suspension mods for the Camaro.
We are ready. We will have various upgrade levels available for the Camaro BEFORE it is available. There are some minor differences between the G8 and the Camaro, but already know about it and we have already taken care of it.
One of the biggest issues we are seeing on the G8 and will transfer to the Camaro the following:
1. Rear suspension assembly is mounted to the frame by 4 soft bushings. These bushings allow quite a bit of side to side movement or step out as we call it. that means the suspension as an assembly can move separately from the body. This was designed to reduce road noise and not make the rear so tire balance sensitive. But as the G8, installing our kit eliminates the step out, and does not create any noticeable noise. If your rear tires are out of balance or were close to being out of balance, then you will feel it more. The bush install is relatively simple. You partially drop the rear cradle assembly, and install inserts top and bottom into the voids that are manufacturer in the cradle bushings. This will make a tremendous improvememnt, and can be done by a talented, auto savy with tools, DIY er.
2. Rear differential supports. As in the G8, these bushes, 3 of them, are fairly soft and move a lot on hard torq applications. Replacing these bushes with our poly bushings does require a special tool that we have made. Installing our bushes here will assist in better torq management and torq transfer. Again, no noise level increases
3. Rear upper control arm bushes. These huge bushings are alittle more challenging but not too difficult. The OEM stuff is very soft. Putting them into compliance will assist in better cornering, and torq transfer for the drag racers. There is no doubt at all that the Camaro will become an very aggressive road race ad drag race vehicle. We are ready for these setups.
4. Overshocking and overspringing, wil be a problem for the Camaro due to minimal tire widths that will be available. A balance approach will give you much better handling and performance than putting on too aggressive shocks/springs. More on that later
5. Rear trailing arm bushes, link bushes and tie rod bushes are all very soft rubber. The serious performance driver is going to want these bushes swapped out. Again, our poly bushes do not make noise and offer a very serious increase in compliance and predicibility
6. Front radius rod bushing will be fluid filled as of current data just like the G8. Under hard braking and cornering, there is too much movement. Our Pedders front radius rod bush will allow you to increase positive casters approx 1 degree or so, which is a very big deal.
7. Lower control arm bush is soft and non compliant, and allows lots of movement. Ours fixes this issue.
8. We already have adjustable sway bar kits with superior end links. We may make a special killer performance set for the Camaro.
9. At a minimum, we will have our GSR front struts and adjustable coil overs available by SEMA, plus some special options that we cannot discuss yet, that will be introduced by SEMA.
10. There are some collapsing issues on the G8's upper strut mount bushings. This is a result of strapping and shipping issues from Au. We are not sure yet if this will continue to be a problem, since the Camaro will come from Canada and no boat ride will occur.
Our pedders web site for Camaro, is having a huge volume increase. In fact you have almost crashed our site multiple times due to the volume of hits. We are going to be working on a heads up email program very soon, to help all of you keep abreast of the latest and greatest opportunitys for the Camaro. When the site is upgraded to start recieving info, we will post it on this forum for all to see and sign up
www.peddersusa.com. Then click on the Camaro in the picture.
We are extremey excited about the Camaro, and in the near future we will be able to discuss what we have been doing in the background for this serious, killer ride. But mums the word right now!!
thanks
mike
dms
So future Camaro owners, we are ready for you!.
Info@PeddersUSA.com is offline   Reply With Quote
Old 06-18-2008, 03:40 PM   #2
nfamous209
Drives: 2002 Camaro z28
Send a message via AIM to nfamous209 Send a message via Yahoo to nfamous209
sounds good mike, cant wait to see ur products on the car.
nfamous209 is offline   Reply With Quote
Old 06-18-2008, 03:40 PM   #3
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
WOW; Already? I've read many good posts regarding your product on G8board and will will looking forward to adding your parts to my car.
'20 ZL1 Black "Fury"
radz28 is online now   Reply With Quote
Old 04-13-2009, 04:12 PM   #4
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Camaro Xa Kit #1 is in the building!!!
JusticePete is offline   Reply With Quote
Old 04-15-2009, 06:03 PM   #5
D1BADZ
hmmmmm
D1BADZ's Avatar
Drives: 2010 IOM in-n-out 2SS
So did you still need a test fit car?
Mine on a rail in Michigan and I live in san jose????
"Responsibility is a Heavy Responsibilty" (Cheech)
D1BADZ is offline   Reply With Quote
Old 04-15-2009, 10:23 PM   #6
JusticePete
San Jose is a long way from Muskegon Michigan, but the answer is yes. We are still looking for an early release production unit.
Old 04-15-2009, 11:00 PM   #7
D1BADZ
hmmmmm
D1BADZ's Avatar
Dohh, I could have swore that DMS was looking for a bay area tester, and he was looking for someone local, sorry MI a little to far.
Old 04-15-2009, 11:09 PM   #8
Info@PeddersUSA.com
Early in the process we were. But we decided to do the test fitting in the Michigan area. They should get the Camaros first.
I will, however, work out a special deal with you to do a photo shoot of the process of installation. But I will need some bushings as well.If I can find someone to do all the bushings, that would be great.
the photo shoot is to make install manuals. I will want to do this ASAP, and at a minimum will require a Street Xa package
mike
dms
Old 04-15-2009, 11:13 PM   #9
Vash
Drives: 00 Blazer
Nice. I like the prizm stickers, nice touch.
Vash is offline   Reply With Quote
Old 04-15-2009, 11:16 PM   #10
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
so does this mean il be getting my suspension soon?
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 04-15-2009, 11:26 PM   #11
JusticePete
6 to 8 weeks after the FINAL fitmentment. We are busting at the seams waiting on a vehicle... just like everyone else.
Pedders suspension already for the Camaro Info@PeddersUSA.com Suspension / Brakes / Chassis 75 10-21-2009 07:25 PM
Zeta (Camaro/Commodore/G8) suspension details Gatecrasher Wheels and Tires Talk Sponsored by The Tire Rack 66 04-16-2009 01:11 PM
AutoCross and Pedders Day Sept 15-16 Info@PeddersUSA.com Off-topic Discussions 4 09-03-2007 12:26 PM
Air-Car Ready for Mass Production KILLER74Z28 General Automotive + Other Cars Discussion 11 06-08-2007 06:07 AM
