Old 08-26-2016, 10:58 AM   #1
SirReptar
Drives: 2016 1LT RS Hyper Blue Metallic
Rear window not sealed properly?
I was getting something out of my trunk last night and noticed that when I opened it and the light came on there was a little oval shaped patch of light coming through the window. Is this something that is normal or do I have a problem?
I do hear a rattle from the trunk when I'm going slow or over a bump, kinda sounds like the speaker is loose or something. I don't know if the two would be related.
SirReptar is offline   Reply With Quote
Old 08-26-2016, 11:35 AM   #2
E-Ray
Drives: 2016 Camaro 2SS, Nightfall Grey
Is it getting wet on the inside? If it is you have a problem.
E-Ray is offline   Reply With Quote
Old 08-26-2016, 11:42 AM   #3
pdrumans
pdrumans's Avatar
Drives: 2LT Red Hot 2.0t
the light part is coming up from the trunk area through the rear parcel shelf at some point. I can also see the light from the trunk coming through the parcel shelf to the interior and I have no rattles and there appears to be no issues, other than that you can see some of the light.
pdrumans is offline   Reply With Quote
leak., light, rear window
