Old 08-25-2016, 03:08 PM   #1
PRAY
PRAY's Avatar
Drives: 2016 2SS
700rw with AFM and A8 possible?
I want to have my cake and eat it too. I really love the way this car drives and it stays in 4 cyl mode a lot where I live. I have been tracking it and am averaging just under 20mpg. I drive it about 300 miles a week so mileage does matter to me. I am wondering if you guys think it would be possible to get over 700rw with the stock bottom end while retaining the AFM. I know Comp has some cams out there that retain the AFM and are worth 40rw on motor. I am wondering if a cam would still have the down low grunt and upgrading the AFM valves to a 3" system would keep it engaged as much as it is now. If I could keep the car as docile as it is right now and pick up 300rw it would be the perfect car.
Here is the plan.
Ported TB/Intake
Comp AFM cam 32% fuel lobe/ springs/ PR's
Ported heads
ECS S/C 10 to 12 lbs
Headers back to the stock muffler, keep AFM but upsize to 3"
Catch can system
160* T-Stat
Plugs/Wires
CPR LSFS
LS7 lash cap
Meth
Tune
Old 09-08-2016, 11:42 AM   #2
47AJV8
Drives: A White Car
Anything more than 650 RWHP and your pistons are living on borrowed time. Other than that, yes this setup should make 700+ rw.
"From ABS shudder that came on surprisingly early in the lousy brake pedal's travel to a looser rear end than Kim Kardashian"
47AJV8 is offline   Reply With Quote
Old 09-08-2016, 02:25 PM   #3
PRAY
PRAY's Avatar
Drives: 2016 2SS
Pistons are a concern. I may just drop some forged replacements in when it is time to turn it up. I would be happy with 650rw for a little while.
