Old 08-25-2016, 01:02 PM   #1
Lord Dirt
Lord Dirt's Avatar
Drives: 2016 Chevrolet Camaro 2SS
K&N BLACKHAWK AIR INTAKE
  • Guaranteed to increase horsepower
  • Designed to improve throttle response and engine sound
  • Washable and reusable air filter
  • Made from all black components
  • Lasts up to 100,000 miles before service is required (depending on driving conditions)
  • Easy to install, usually in 90 minutes or less
  • Washable and reusable lifetime air filter
  • K&N Million Mile Limited Warranty
  • $363.99 USD
    MSRP $660.00 44.9% Off
The K&N 71-3092 Blackhawk Induction Air Intake System is a free-flowing, mandrel-bent aluminum tube air intake system that is guaranteed to gain power. It replaces the restrictive factory air filter and air intake housing on specific Chevrolet Camaro SS models. This low restriction air intake allows your engine to inhale a larger amount of air than it would from the stock air intake. More air means more power and acceleration. This K&N Blackhawk Induction Air Intake System comes with black components including the K&N high-flow air filter with heat shield. The attractive textured black powder-coated tube features a welded, engraved K&N plate giving you a clean, high-performance look under the hood. The intake tube accommodates the factory mass air sensor and crank case vent hose. The oversized cone shaped air filter is made from an oil-free synthetic filter media that can be used for up to 100,000 miles before cleaning is needed depending on driving conditions. This air intake is relatively easy to install usually in 90 minutes or less using the existing factory mounting points using commonly available tools. Some K&N Blackhawk Induction Systems are not legal for sale or use in California and other states adopting California emission standards while others are 50 state legal. View the 71-3092 vehicle applications to determine the legal status for each vehicle.
Product Specifications
Estimated Horsepower Gain20.68 HP @ 4805 RPM
Air Filter ColorBlack
Air Filter Material Non-woven Synthetic
Air Filter Outlet Shape Round
California Restricted Not legal for sale or use in California
Clamp Material Carbon Steel
Clamp Style Regular
Clamps Included 4
Intake Pipe Color / FinishBlack
Intake Pipe Material Aluminum
Product Box Height 14.5 in (368 mm)
Product Box Length 24.1 in (612 mm)
Product Box Width 15.5 in (394 mm)
Product Style71 Series Kits
Replacement Filter RU-3102HBK
Street Legal In All US States No
TUV Approved (Europe) No
Weight12 lb (5.4 kg)
Horsepower gains based on similar vehicle dynamometer test. Results will vary.
http://www.knfilters.com/search/prod...x?prod=71-3092
Lord Dirt is offline   Reply With Quote
Old 08-25-2016, 01:10 PM   #2
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
20 horsepower gain...right.
Plus look at the dyno chart...they ran the tests in 3rd gear lol.
Old 08-25-2016, 01:11 PM   #3
Lord Dirt
Lord Dirt's Avatar
yep, can't wait until someone tests it for us
Old 08-25-2016, 01:12 PM   #4
ccable86
ccable86's Avatar
Drives: 2016 2SS Camaro Nightfall Grey
Does it offer a sound tube delete option?
ccable86 is offline   Reply With Quote
Old 08-25-2016, 01:52 PM   #5
mikeyg36
Drives: 2015 Z/28 #533
HP gains based on "similar vehicle" lol
mikeyg36 is offline   Reply With Quote
Old 08-25-2016, 01:57 PM   #6
jimmypop13
Drives: 2016 camaro ss
I don't see a sound tube in the pictures. Looks like a delete is your only option
The logo being at an angle instead of straight with the car looks absolutely terribleble to me.
PASS
2016 camaro 2SS hyper blue/Kalahari, A8, MRC, NPP, sunroof, SW headers through axleback, Circle D 3600rpm TC, Pray ported IM/TB, E85
Sold: 2002 Z28, NBM, M6, 460rwhp, 2009 HHR SS
RIP : 2002 WS6 Black, A4, 355rwhp
jimmypop13 is offline   Reply With Quote
Old 08-25-2016, 01:59 PM   #7
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Oh god No......
Old 08-25-2016, 02:16 PM   #8
Lord Dirt
Lord Dirt's Avatar
if you click on the first picture you can see there are gaps that will let hot air in
Old 08-25-2016, 02:52 PM   #9
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
Wait the K&N sticker alone is worth 10hp
Old 08-25-2016, 03:00 PM   #10
MiamiBlueCamaro
MiamiBlueCamaro's Avatar
Drives: Gen 6 Camaro RS
Holes?
Old 08-25-2016, 08:04 PM   #11
Slem
Slem's Avatar
Drives: 2016 Summit White 2SS (Auto) Loaded
Junk
Slem is offline   Reply With Quote
Old 08-25-2016, 08:35 PM   #12
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
The 20HP claim is very misleading.
1. From the dyno chart they provided, there is NO gain in max power.
2. Gain is shown below 5k rpm, but NO gain above 5k rpm. If the stock airbox was a restriction, I'd expect a less restrictive aftermarket unit to have the biggest benefit at higher engine speeds and air flows.
Old 08-26-2016, 06:36 AM   #13
bturner2
Drives: 2SS, Hyper Blue, Sunroof, NPP, MRC
I've put CAIs on the last 5 cars I've owned but based on what I've seen written here and other places the 6 gen Camaro air box design is pretty darn good to start with. Right now I'm thinking a high flow filter may be my upgrade this time around.
bturner2 is offline   Reply With Quote
Old 08-26-2016, 08:04 AM   #14
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Even that is debatable. When I had my Coyote Mustangs a very reputable shop did back to back to back testing and even repeated it over a few days with the stock paper Motorcraft filter, K&N, AFE and some other one I can't recall. They were all within 1 or 2 rwhp, but the K&N was the worst, and the others were all nearly the same. I think the highest pull was the stock Motorcraft. So in many cases a clean OEM filter is the best bet. Only exception may be if AFE makes a larger surface drop in like they now do for the S197 Mustangs that is like a panel, with a small cone on the bottom.
