Old 08-24-2016, 07:01 PM   #1
HurstPerformance
HurstPerformance's Avatar
Drives: 2013 Camaro SS and 2016 Camaro SS
Hurst Spring Kits Are Coming Soon for 2016-2017 Camaros
We just finished installing a set of Hurst springs on our 6th gen. Thoughts on the stance?
HurstPerformance is offline   Reply With Quote
Old 08-24-2016, 11:38 PM   #2
rorymick
rorymick's Avatar
Drives: 2016 Camaro RS 1LT 2.0L Turbo
Looks good! Hopefully you guys will post up spring rates and ride height etc!
'16 1LT 2.0T RS - Catless DP, Intake, Tune/ Eibach springs FE3 shocks/ BMR front bar FE4 rear bar/ Xpel'd front end, CP Reload sealed/ Radenso Pro M.
rorymick is offline   Reply With Quote
Old 08-25-2016, 12:00 AM   #3
G Fo12ce
G Fo12ce's Avatar
Drives: '16 2SS
Looks good, about an inch? Do you plan to make them for MRC?
My Intro Post | My Order | My Ordering Guide
TJCR2Q | 2SS Red Hot|Adrenaline Red|MX0 A8|56R Wheels|5ZU Blade Spoiler|NPP Exhaust|F55 MRC|IO6 Nav
• 4/06/16 1100 Ordered (waiting for 5ZU acceptance)
• 4/19/16 2000 Accepted with 5ZU
• 4/23/16 3000 TPW:5/16/16
• 5/06/16 3100
• 5/13/16 3400 Broadcast Sheet
• 5/24/16 3800 Vehicle Produced
• 5/25/16 4B00 Bayed
• 5/27/16 4300 Intermediate Delivery
• 7/9/16 Delivered!
G Fo12ce is offline   Reply With Quote
Old 08-25-2016, 10:59 AM   #4
HurstPerformance
Thanks! The rates for the springs in this pic are: 150 lb/in. front and 420/550 lb/in. rear. Once we go into production we will absolutely provide final spring rate and ride height info.
Good eye. We are looking for a 1.0" drop front and rear. We will keep you all updated on whether or not we will release springs for cars with magnetic ride control. Thanks for asking.
Old 08-25-2016, 11:18 AM   #5
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
Are you sure it's not the other way around? That seems very low for front spring rate and very high for rear spring rate.
Old 08-25-2016, 04:04 PM   #6
crankaholic
crankaholic's Avatar
Looks great!
What are the tire sizes on that car?
crankaholic is offline   Reply With Quote
Old 08-30-2016, 06:21 PM   #7
HurstPerformance
Yes. These are the correct rates for the springs pictured.
Originally Posted by crankaholic View Post
Looks great!
Thanks! Tires are 245/45/20 front and 275/40/20 rear.
Old 08-31-2016, 12:44 AM   #8
JaxChris
550 lbs/in is way too stiff for cruising or commuting. I'm guessing that will be your drag spring?
Old 09-27-2016, 03:29 PM   #9
HurstPerformance
The ride is actually really nice. Our springs are roughly 8-10% stiffer than factory springs.
Old 09-30-2016, 09:00 PM   #10
laynlo15
Drives: 2022 Lt1 A10
Stance nice, wheel suck. Just saying
Old 10-21-2016, 12:36 PM   #11
rotis
rotis's Avatar
Drives: 2019 ZL1 1LE
With the motion ratio in the rear a 550 lbs/in spring rate works out to ~150 lbs/in wheel rate. It is not very stiff.
rotis is offline   Reply With Quote
Old 08-09-2017, 04:10 PM   #12
HurstPerformance
Whether you're looking to complete your 'Elite Series' build, or just want better handling from your modern muscle car, join Steve as he explains what makes these springs a great upgrade for your ride.
2017, hurst, lowered, springs, suspension
