Old 08-14-2016, 07:35 PM   #1
Husker67
Husker67's Avatar
Drives: '22 Camaro 2SS 1LE Wild Cherry
Oil Life PerCentage
Do you use this to determine when to change your oil? Under 20% change oil???
Husker67 is offline   Reply With Quote
Old 08-14-2016, 07:35 PM   #2
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Many people do, it's a valid system.
Old 08-16-2016, 07:44 AM   #3
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
Are you saying that it's more than just a mileage counter (reminder)? I thought all these systems do is count your miles and remind you to change your oil assuming you're using the same standard oil from the factory. I'm using Mobile 1 Extended Performance and it hasn't changed.
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge
93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno)
LesBaer is offline   Reply With Quote
Old 08-16-2016, 07:47 AM   #4
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
Yes, it's more than just a counter....search here or the Internet.
It's monitors the way you drive, so a person who does interstates a lot has longer intervals vs a car that does urban driving. It is usually dissed by enthusiasts, but it works fine for the masses.
http://www.edmunds.com/car-care/oil-...g-systems.html
Old 08-16-2016, 08:23 AM   #5
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
Thanks Glenn...you learn something new every day.
Old 08-16-2016, 08:39 AM   #6
R3DLT1
Toyota Tech
R3DLT1's Avatar
Drives: 2SS A8
Yup. bought my new Camaro with 158 miles but I'm sure its been sitting for some time now since the oil life read 69%
2016 Camaro SS A8 Roto-Fab CAI: Drag set up 11.9 @116
Sold 95 Camaro Z28 Cam:Bolt ons: 12.3 @114
Sold 2013 Chevy Crzue LTX
R3DLT1 is offline   Reply With Quote
Old 08-16-2016, 01:11 PM   #7
BadBowtieProductions
Check me out on YouTube!
BadBowtieProductions's Avatar
Drives: 2016 Camaro SS
Just got my first oil change done Friday. It was right around 40% and 4,500 miles. Oil looked good, so I might wait a tad longer on the next one.
2016 Camaro SS - A8, NPP, 2SS, Nightfall Gray Metallic
11.68 @ 118 - CAI Intake - TSP 2" Longtubes - DSX Tuning Flex Fuel - DSX Tuned
11.91 @ 117 - CAI intake only
11.99 @ 117 - STOCK 1/4 mile
410 RWHP / 424 RWTQ - STOCK Dyno
YouTube Channel: BadBowtieProductions
BadBowtieProductions is offline   Reply With Quote
Old 08-21-2016, 11:39 AM   #8
Indydriver
Drives: '14 2SS/RS Vert 6M/KTU/NPP/DTA/ARH
It depends. My 2012 Toyota just has a 5,000 mile counter on it. Any OLM worth it's weight is a computerized algorithm as described, but check it out to make sure. If you want real peace of mind, run it down to 0% then send a sample for analysis with a TBN test. Then you'll see if it is too much mileage or not.
Consensus is, by definition, a lack of leadership.
Indydriver is offline   Reply With Quote
Old 12-19-2017, 05:58 PM   #9
Deejay2021
Drives: 2016 camaro rs
So my oil monitor is at 7% should I continue to drive it or drive my other truck until my scheduled appointment it (next Friday)
Deejay2021 is offline   Reply With Quote
Old 12-19-2017, 06:06 PM   #10
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
Just drive your car, it’s not gonna blowup if it hits zero. It is a reminder system not a cut off system .
Old 12-19-2017, 06:08 PM   #11
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
Been hopin to see some more YouTube videos on your channel! Been a while!!
MP3BOOSTED is offline   Reply With Quote
Old 12-19-2017, 07:12 PM   #12
Indydriver
I’ve tested both GM and Honda as described in post 8. They were both spot on. 6500-8000.
Old 12-19-2017, 07:42 PM   #13
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
And keep in mind, it will go to 0% in a year, no matter if you drive the car or not.
Old 01-10-2018, 11:29 AM   #14
Klucas3000
Drives: 2017 SS 1le
Oil Change
I drive a 2017 1le Camaro and my oil life according to the odometer is 2% but have only drove it twice since October. October it was at 35%, I am getting it changed this weekend. I checked the oil but as indicated in the threads below its hard to see it on the stick...I have had it for a year now with 4800 miles on it. Should I be concerned about the 2% or is this based on time and not necessary on mileage?
thank you for comments
Klucas3000 is offline   Reply With Quote
