Go Back   CAMARO6 > CAMARO6.com General Forums > Regional Sections > USA - Southwest
Old 08-13-2016, 12:54 PM   #1
Joe@CPR.com
Drives: 03 vette, 94 trans am, 04 gto
CPR 6th Gen camaro low side fuel system!
In continuing with our line of low side fuel system offerings for the new gm DI motors we are now proud to announce that our 6th gen fuel system is available for purchase. We have gone above and beyond with this system by making install even easier than previous offerings. We have built the following features into this system that will help make adding additional low pressure fuel to your car easy and effective!
Key features
1) 100% pre made lines all clearly labeled with high quality lines and fittings
2) 100% plug and play pre-made wiring harness and we truly mean plug and play!
3) Comes with everything needed for install even the drill and tap for the tank, save $15 if you don't need this
4) very simple to follow full color step by step instructions
We are ramping up inventory on these to make sure we have more than enough to get these out same day or worse case the next day. As you may or may not know the Camaro's low side goes away very fast compared to the C7's so this will be needed much sooner than those.
Retail $1749.99 shipped to the lower 48.
Package with our high side package for a total fuel system solution for big power and save!
Joe@CPR.com is offline   Reply With Quote
