Old 07-31-2016, 10:30 PM   #1
ocautomotive
Drives: 2017 ZL1 and 2018 SS 1LE
Slow Cranking (video)
Has anybody else experienced their car cranking super slow after being driven. I know these cars crank for a while to start when cold but I am talking about it starting slow, sounds as if it won't start then pauses for a second and then fires up. I'll go on a drive and video it then upload later. I don't think that it is a battery issue but maybe my starter is burning out...https://youtu.be/XcreOcLb64o
ocautomotive is offline   Reply With Quote
Old 07-31-2016, 10:35 PM   #2
Johnwon
Drives: 2016 Mosaic Black 2SS, NPP, A8.
I have never had this issue. It sounds like the battery to me; they do funny things to these heavily computerized vehicles when low. I'd take it to the dealer for their input.
Johnwon is offline   Reply With Quote
Old 07-31-2016, 10:43 PM   #3
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Long thread written up here on this last week...search
Old 08-01-2016, 03:17 PM   #4
ocautomotive
Here is a video https://youtu.be/XcreOcLb64o
Old 08-01-2016, 03:18 PM   #5
ocautomotive
I cannot find any such thread
Old 08-01-2016, 03:36 PM   #6
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
DI and high compression = longer than expected cranks
Cold climates are even worse.
Old 08-01-2016, 03:37 PM   #7
ocautomotive
I'm not talking about the long cranks that this car does when cold. It literally doesn't crank right, look at video link I posted
Old 08-01-2016, 03:54 PM   #8
SuperSound
SuperSound's Avatar
I did and didn't hear anything odd, but then it was hard to hear in the video. Have you checked the voltage on the battery before starting it in one of these situations? Could be a bad ground showing up when hot cranking.
Edit: Went back and heard it with headphones. Yea definitely not normal. Does it cold start fine?
Old 08-01-2016, 03:55 PM   #9
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
Originally Posted by ocautomotive View Post
Oh - that ain't right. That sounds like a starter that is heat soaked or an old timey carbed engine with heat soak/vapor lock.
I'd say back to the dealer for that.
476 rwhp/440 rwtq (sold)
Old 08-01-2016, 03:59 PM   #10
SSDan
SSDan's Avatar
The long cold start cranking is on purpose to give the mechanical high pressure fuel pump some time to build the needed pressure for the direct injectors. What the OP has going on per my ears in the video is totally different. Its an abnormally slow crank.
Old 08-01-2016, 04:21 PM   #11
Drags1998
Drives: 15 SilveradoLTZ,162SSVert BlazerRS
I'll BET the Battery is BAD!!! Very easy for the Dealer to Check.
Drags1998 is offline   Reply With Quote
Old 08-01-2016, 04:31 PM   #12
ocautomotive
At the dealer right now. Battery is fine, the starter might be bad.
Old 08-01-2016, 07:28 PM   #13
Robertf65
Robertf65's Avatar
Drives: A vintage 'Bird
Yep. Sounds just like a failing or heat-soaked starter.
Robertf65 is offline   Reply With Quote
Old 08-01-2016, 08:05 PM   #14
02fbody35th
02fbody35th's Avatar
Drives: 2018 ZL1
I'm not trying to be a dick but comments like these are uncalled for. The OP had a legit question and was looking for help. If you know the answer why not just post a link to the thread. I looked and haven't seen anything written similar to his problem. I mean that's what these forums are for ain't it? So we can all talk about our cars and ask questions and get answers. The more info out there the better.
02fbody35th is offline   Reply With Quote
