Old 07-23-2016, 04:55 PM   #1
Ace01
Ace01's Avatar
Drives: 2018 1LE SS "Silver Bullet"
Tremec_TR-3160_transmission V6 Gen 56
https://en.wikipedia.org/wiki/Tremec...0_transmission
Did not know that they are using this trans in the Ford GT350 also. So is this a better trans than the one they are using for the V8 in the Gen 6??
https://en.wikipedia.org/wiki/Chevro...xth_generation)
Upgraded for the GT350
Reinforced shift forks
Bronze fork pads
Bronze shift stop bushing
New 2nd gear
REM polished synchronizer assemblies
New synchronizer ring kit
Seals
Polyurethane mount insert
Bench labor
Ace01 is offline   Reply With Quote
Old 07-23-2016, 05:11 PM   #2
Ace01
Ace01's Avatar
http://www.tremec.com/menu.php?m=133 More info
Old 07-23-2016, 06:39 PM   #3
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
The TR6060 is a much stronger transmission. Thats why its used in cars with 600+ hp while the TR3160 generally isn't used in cars with more than low 300s. The 3160 is a bit lighter, and thats probably why Ford used it for the GT350.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 07-23-2016, 07:15 PM   #4
Richard0nee
Richard0nee's Avatar
Drives: 2016 SS M6, NPP
Yes sir. The TR6060 is a very beefy tranny and used predominantly in the Camaro and Vettes.
The driveline chatter, the notchiness is pretty insane. Took me a bit to get used to it but in all honesty, I like the notchiness a lot. Feels badass..
Richard0nee is offline   Reply With Quote
Old 07-23-2016, 08:22 PM   #5
Ace01
Ace01's Avatar
They said they used the TR-3160 in the GT350 because its lighter. Go figure
Old 07-24-2016, 03:17 AM   #6
Zeke.Malvo
Zeke.Malvo's Avatar
Drives: 1969 Mustang MaCh1
The TR3160 probably takes to high rpm shifting better. I'm not sure if the TR6060 has even ever been mated to a high revving engine in a stock application.
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtq
T56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear
Zeke.Malvo is offline   Reply With Quote
