Old 07-10-2016, 09:36 PM   #1
tbis
tbis's Avatar
Drives: 2016 1SS Summit White
SS clutch noise when shifting low gears.
When Pressing the clutch to shift going 1st to 2nd or 2nd to 3rd at low rpms; A loud clunking noise occurs. It is intermittent... sounds like metal to metal and does not seem normal. i saw a thread on this in the past with no resolution. Did anyone have this problem and get it resolved?
[SIZE="100"]
tbis is offline   Reply With Quote
Old 07-10-2016, 09:57 PM   #2
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Take a video. That will be your best bet, hearing it helps...
You sure it's not typical clutch chatter? Are you letting the clutch up fast enough?
Old 07-10-2016, 10:09 PM   #3
tbis
tbis's Avatar
i'll try to make one and post it. it happens when pushing the clutch in. not coming up on it.
[SIZE="100"]
Old 07-10-2016, 11:39 PM   #4
tbis
tbis's Avatar
I found the thread you commented on made me feel better that i wasn't the only one
[SIZE="100"]
Old 07-11-2016, 05:18 PM   #5
442DMND
Drives: 2017 SS/1LE
I have the exact same issue on my 2017 and just made an appointment to get it checked by dealer. Will keep you updated.
2017 SS/1LE Hyper Blue Metallic, PDR, Illuminated Bowtie, GM Dark Tails, Diode Dynamics Sidemarkers
442DMND is offline   Reply With Quote
Old 07-22-2016, 03:06 PM   #6
RCurtis
Drives: 2016 2SS 6MT
I had the same issue and took the car to the dealership. They said it was completely normal for this transmission and even let me test drive one of the other camaros on the lot and it had the exact same noise. Its shitty, but its something your going to have to live with.
An easy way to recreate the noise is to put load on the transmission (start going up a hill at 5 mph in second gear) and then clutch in really fast. When the transmission unloads you will hear this clunking metal sound.
RCurtis is offline   Reply With Quote
Old 07-22-2016, 05:38 PM   #7
sschons74
sschons74's Avatar
Drives: 16 Camaro 1SS & 82 Silverado C10
It likes to clunk until you get used to managing your revs around the shifts. It takes some getting used to, but I keep my revs up higher, this tranny doesn't like to putt from 1st to 2nd to 3rd. It shifts smoother at higher rpms, like around 3000.
Ordered 1SS Black on Black, M6 in late summer 2015.
Hurst shifter, Soler Performance ported TB.
sschons74 is offline   Reply With Quote
Old 08-03-2016, 07:51 PM   #8
02fbody35th
02fbody35th's Avatar
Drives: 2018 ZL1
I've noticed the same thing with mine. It's really noticeable when driving slowly in first gear then a quick clutch in to coast or change to second. It makes a clunk sound in the drivetrain. do you guys agree that this is normal?
02fbody35th is offline   Reply With Quote
Old 08-03-2016, 09:28 PM   #9
clanky
Hyper Blue 2016 Camaro 2S
clanky's Avatar
Drives: 16 Hyper Blue2SS NPP MagRide 6M NAV
Mine does it and so does the one I test drove before I bought mine. Must be normal, feels and sounds strange for sure though.
clanky is offline   Reply With Quote
Old 08-12-2016, 04:25 PM   #10
MXSG
MXSG's Avatar
Drives: 2016 1SS
It's definitely normal. Every 2016 Camaro I test drove made that sound. I traded in a 2011 Corvette which had the same transmission and made the exact same noise (except louder!)
MXSG is offline   Reply With Quote
Old 08-18-2016, 02:00 PM   #11
gippy87
Drives: 2016 2ss
add me to the list. its annoying for sure but i believe it to be normal as well.
gippy87 is offline   Reply With Quote
Old 06-20-2017, 03:06 PM   #12
Anti
Drives: 2017 Nightfall Gray 1SS LE
Glad to hear others are having this issue and not just me.
Anti is offline   Reply With Quote
Old 06-20-2017, 08:10 PM   #13
elementaltoad
elementaltoad's Avatar
Without a video it's hard to know if it is similar to what I hear, but I know if I push the clutch in while in 1/2/3 at low speeds, parking lot, or pulling up to a light, I get a clunk.
Sometimes it's a thud, or metallic sounding clunk depending on how much RPM it still has as I put the clutch in quickly. It is normal as far as I can tell, and all of my manual F-bodies did it with the T56, the TR6060 in my 2016 does it too. I even get a similar noise out of my NV3500 in my old TBI truck. I even seem to remember my Miata's making that noise, but less so. Tiny cute little clutches in those.
2016 Camaro 2SS Garnet Red 6 Speed
1990 Firebird Formula WS6
1989 Firbird Formula 350 WS6, LS Swapped
elementaltoad is offline   Reply With Quote
Old 06-20-2017, 08:26 PM   #14
crazydmc
ummmm
crazydmc's Avatar
Drives: 2016 2SS M6 Nightfall w/Blk Wheels
no clunk here...
2016 2SS M6 w 16k miles
crazydmc is offline   Reply With Quote
