Go Back   CAMARO6 > CAMARO6.com General Forums > Regional Sections > CANADA
Old 07-09-2016, 06:45 AM   #1
gmurad
Is Petro-Canada Ultra 94 good for the 2SS?
Ultra 94 from PetroCanada is what I have near me, is this good for the 2016 2SS?
I'm not sure if I'm getting good performance out of it. The car doens't feel as powerful as my previous 2010 C63 AMG running on the same fuel.
gmurad is offline   Reply With Quote
Old 07-09-2016, 07:02 AM   #2
MiamiBlueCamaro
MiamiBlueCamaro's Avatar
Drives: Gen 6 Camaro RS
Seat of the pants is not good try a car dyno.
Old 07-09-2016, 07:58 AM   #3
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
I had this same question recently.
It is fine to use.
You have 2 choices. Sunoco 91 or Ultra 94
Sunoco 91 has no ethanol, so it is a true 91 octane
Ultra 94 has ethanol which bumps up the rating a few points.
Our cars are mapped to use fuel that has ethanol so there are no concerns using it.
I started with Sunoco 91, but went to back Ultra 94 and have not had any issues or felt the car performs less.
Old 07-09-2016, 08:40 AM   #4
Boilermaker128
Drives: 2010 CobaltSSTC
Recalibrate your butt Dyno. Or maybe your 2ss is slower then your last car. Sucks going down hp, I've always bought up lol.
Boilermaker128 is offline   Reply With Quote
Old 07-09-2016, 09:53 AM   #5
garfin
Resident Disciple
garfin's Avatar
Drives: 2010 CTS-V 6MN '98 Camaro SS (Sold)
It is fine to use.
There is definitely no loss of performance with Ultra 94, and there should be no concerns about using it. I've been using 94 octane gas since the time it was called "Sunoco 260" and I'm a firm believer that using 94 will allow you to extract maximum performance and smooth engine operation out of your car. I remember when 94 was the only fuel my '85 Mustang GT (carburetor) was able to accelerate from 1000 rpm in top gear without engine knock!
However, over the years I've consistently noticed that using the ethanol-spiked Ultra 94 (ethanol is used to help reduce emissions) causes an approximate 10% drop in fuel economy when compared to the top octane fuels from Shell or Esso that have no ethanol. This really comes into focus for me when traveling in the U.S. on the interstate using 91 or 92 octane fuel with no ethanol as I get noticeably better fuel economy.
Ethanol has less energy per unit of volume that gasoline, so it only stands to reason that any ethanol that is added to gasoline will negatively impact fuel economy.
Best regards,
Elie
2010 Cadillac CTS-V 6MN Thunder Gray
1998 Camaro SS # C079 SOLD
garfin is offline   Reply With Quote
Old 07-09-2016, 10:06 AM   #6
gmurad
Thanks for the info.
Is it ok for me to switch between Ultra 94 and another type of "cheaper" fuel when I'm interested in saving some $$$?
Can they be mixed together or do I have to wait until one is done?
Which "cheaper" fuel could be used for those occasions?
Old 07-09-2016, 09:40 PM   #7
2016SS
2016SS's Avatar
Drives: 2016 Summit White 2SS
I used 94 in my last few cars always worked fine! I'm sure it will be the same for the Camaro. It is what I currently run 94 also in my SS
2003 Cadillac CTS Sold
2006 Nissan 350Z Sold
2008 Cobalt SS/TC Sold
2016 Camaro 2SS Summit built 3/28/16 delivered
2018 Camaro ZL1 cancelled by GM 😡
2019 Corvette 2lt Z51
2016SS is offline   Reply With Quote
Old 07-10-2016, 01:14 AM   #8
Razzaa
Razzaa's Avatar
I use 94 from Chevron. It doesn't have any ethanol
Razzaa is offline   Reply With Quote
Old 07-10-2016, 07:32 AM   #9
SQUALO
Drives: CHEVROLET
I'm using 91 in my Stingray (same engine as SS) with no issues, gas is expensive enough don't waste more money than you have to, on 94, if the car isn't calling for it.
Don't forget the obvious, we're driving sports cars, if fuel economy is a major concern for you, you should have bought a sub-compact.
SQUALO is offline   Reply With Quote
Old 07-11-2016, 10:38 AM   #10
camaro99
camaro99's Avatar
Drives: Angry Dorothy II 2016 2SS
94 for racing...
btw anyone have side detector issues (Lane change alert system)??...my very clean and dry lca sensors in rear bumper probably need replacement ...following dead battery situation with a 2hr charge on charger ??
camaro99 is offline   Reply With Quote
Old 08-24-2016, 07:31 AM   #11
TheShadow
Drives: 2016 2LT V6 RS A8 NPP, Hyper Blue
Hey, my wife's Mini Cooper S coupe is definitely a sub-compact but drinks 91 too. agree on the 94 vs. 91 though - that always seemed like a Sunoco marketing scheme more then an actual performance boost...
TheShadow is offline   Reply With Quote
Old 08-29-2016, 06:27 PM   #12
Camaro455ss
Camaro455ss's Avatar
Drives: 2016 Camaro 2SS ... 2024 Camaro 2SS
Hey guys.....
Just picked up a brand new 2016 6th Gen 2SS a couple of weeks ago...
I've been using 94 ultra from petro Canada since the first day!!! ....... I thought Sunoco merged with petro long ago...... I haven't seen them around...so two questions
1) where are you getting the Sunoco ultra? Are you guys just referring to petro canada's ultra 94 as Sunoco ultra?
2) what about shell 91 octane? In the states they have 93 octane gas at shell stations... whereas here in Canada we only get 91......... so would 91 octane from shell be safe to use on our cars?? Please let me know..
Thanks
Camaro455ss is offline   Reply With Quote
Old 08-29-2016, 07:36 PM   #13
Slem
Slem's Avatar
Drives: 2016 Summit White 2SS (Auto) Loaded
91 shell here in Canada has no ethanol petro Canada 94 is boosted Octane by Using ethanol. Both are good for your car, however I switched my self to 91 shell v power because I notice it performs a little better then the 94 petro, you will also get better fuel economy using the shell 91 and it runs like a champ. Note you will always get better fuel economy you pure octane rather then using octane with ethanol.
Slem is offline   Reply With Quote
Old 08-30-2016, 02:48 AM   #14
Camaro455ss
Great thank you!! So I will switch to 91 shell.... after all Ferrari, Mercedes, BMW stand behind shell!
Thank you!
