![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
Security concern
I'm a little concerned about theft and break ins on these cars. I read the thread last year about one member getting his new Camaro getting stolen out of a Target or Wal-Mart parking lot. And the security camera videos of people walking down the street with some kind of box in their hand and opening cars. One of the local stations had a story last week about people using some kind of receiver to pick up the signal from your remote, even from inside your house, and re-sending it to your car. They recommended putting the remote in a metal can when you're in the house.
So what I've been thinking about is getting one of the remote controlled devices that people use to turn off their NPP, such as Forza Exhaust Bypass Valve Controller Kit, and putting it on the fuse for the remote lock/unlock module. Has anyone tried something like this? Think it would work? It would be an extra step whenever you lock or unlock but maybe it would give you a better chance of the car being there.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers, Mamo Throttle Body Delivered: 08/15/2016 #TeamBeckyD |
![]() Drives: The Tumbler Join Date: Mar 2016
...damn...that's actually a really good idea! I would never have thought of something like that. The most I came up with was getting a LoJack decal from EBay or something and slapping that on the driver window in the corner.
Please forgive the double post.
I think your best bet would be talking to that company the makes the remote system, and seeing what they think. Please keep me updated on what you learn. I would absolutely get something like that if it was doable. |
#4 | |
FMPG
Drives: 2016 2SS Join Date: Dec 2015
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge ![]() 93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno) |
FMPG
I found this in his follow-up email to me...if I'm reading this correctly, I think it may work:
"....Also, the instructions suggested installing the yellow fuse tap in fuse location F30 … the one used for the windshield wipers. This location seemed to be a logical spot as it was thought it would be switched to the ignition. Like this … ![]() As it turns out, fuse location F30 is not switched to the ignition … it is hot all the time. This will result in a small, but continuous, current drain. Not a problem for a daily driver car. But, should you leave the car without starting it for a period of 3 to 4 weeks, it could drain down your battery to the point where the car may not start. You can turn off the power to the controller using the push button switch or you could install the yellow fuse tap in a fuse location that is switched to the ignition. One such fuse position is Fuse #43. Like this.
Thanks guys. I hope I'm not overthinking this. I don't know which fuse it would be or what else that may control. I sent a PM to Steve at Forza last night so I'll see if he has any ideas.
Richard
#7 |
![]() Drives: Love any sports cars Join Date: Mar 2015
Here is my opinion on using the Model C1 as an enhancement to the security ...
Yes, I think it could be done. The Model C1 controller can act like an on/off switch for any fuse on the car. So, you could use the controller to control the fuse F56 in the trunk .. "Theft/Universal remote system" Once you press the remote on the Model C1, it would cut power to the Theft/Universal system. Another potential fuse to cut power to would be the Engine Control Module Ignition fuse ... F57 or the Fuse system control module ignition ... Fuse F50. Both of these are located in the engine compartment fuse block. The controller is not necessarily just for a fuse. It can act like a on/off switch for any circuit you should want to control. So, it could easily be adapted to control say a circuit that manages the remote entry system. Now, having said that ... I cannot say with certainty that the results will be exactly what you are looking for. I have some concern that all you are doing is interrupting the circuit on those fuses. If you were to merely pull the power (disconnect the battery), the model C1 controller would reset to default and the normal operation of those fuses would be restored ... hence, the action of disabling those circuits would cease and those circuits would be enabled again. In my opinion, a very inexpensive and 100% effective method of preventing someone from driving off in your car is to remove relay K10 from the engine compartment fuse block. This relay controls the starter. Without the relay, there would be no way to start the car. Once removed, you could take the relay with you or place it in an out-of-way location that would not be obvious. You could even store it under the hood somewhere. Another relay that should also disable the car is relay K7 which controls the Engine Control Module. The Removal and insertion of the relay should only take a minute or two and is only moderately inconvenient. And, the likelihood that a potential car thief can diagnose why the car may not start ... or happens to have that exact relay handy is very remote. Regards, Steve |
#8 |
FMPG
Our responses crossed paths so I'm deleting mine. Steve's is better
#9 |
![]() Drives: Black 2017 2SS Join Date: Jan 2012
Just swap out your automatic transmission for a manual. Problem solved.
2017 Black 2SS, M6, NPP, MRC, NAV, and black bowties - delivered 6/23/16
#10 |
![]() ![]() Drives: 2016 Camaro 2SS Join Date: Jun 2016
Why not just keep your remote in a metal box? These devices theoretically work by amplifying the signal between your remote and the car. From what I understand you need a 'Faraday cage' for your remote.
#11 |
Camaro5 had issues in the oakland area with manual v8 5th gens getting jacked easily.
[SIZE="100"] |
#12 | |
![]() ![]() ![]() Drives: 2019 CLA 450 Mercedes Join Date: May 2016
Yep! It is a funny thing, but mine will not start without the clutch depressed. IF and is sure is a big IF they could get it started, I am guessing they might not be able to drive it off.
2019 Lunar Blue Metallic Mercedes CLS 450
2021 C43 AMG Mercedes Coupe Metallic Cardinal Red 2014 Lincoln MKT EcoBoost (The Bus) |
#13 |
I like the idea of pulling a relay for when the car is parked for an amount of time, such as when at a resort or in an airport parking lot. Similar to pulling the wire from the coil to the distributor. But I think just disabling the remote locks would work just fine for daily use. The only time it should loose power, other than me pulling a battery cable, is if the battery discharged somehow, and then nothing would work. I think I might give it a try. Now if they would just run my car through the plant and send it to me.
Richard
#14 |
![]() Drives: 2016 Mosaic Black 2SS Join Date: Dec 2013
I use a thing called a garage and a system that allows LEO's to not only know where the car is but kill the engine (Onstar)..beyond that if they want to bad enough..they will find a way wether it is to put it on a truck or tow it...neat ideas though..
