Old 07-02-2016, 03:25 PM   #1
z28guy30
z28guy30's Avatar
Drives: 2016 camaro 1ss
Rear end gear ratio and torque according to HotRod
I was reading the following the attached article below from HotRod magazine, and it left me completely befuddled about what they are talking about. Are they saying that an engine that produces 100 lb/ft of torque will produce 410 lb/ft of rear wheel torque with 4:73 gears? lol I am either reading something wrong, or they have lost their flipping minds.
2016 Camaro SS, Summit White, A8, MRC, Rally Stripes, Black Bowties.
z28guy30 is offline   Reply With Quote
Old 07-02-2016, 03:40 PM   #2
TSloper
Drives: 2016 Camaro SS
They are correct
TSloper is offline   Reply With Quote
Old 07-02-2016, 03:46 PM   #3
Mikey LikesIt
Mikey LikesIt's Avatar
Drives: 2016 Black Camaro 2SS A8
They are correct
Mikey LikesIt is offline   Reply With Quote
Old 07-02-2016, 04:05 PM   #4
z28guy30
z28guy30's Avatar
Originally Posted by TSloper View Post
They are correct
What am I reading wrong then? I read it like a car that only produces 100 lb/ft at the engine will produce 410 to the rear wheels with 4:10 gears which is entirely bogus. If your engine only produces 100 lb/ft you are going to experience frictional loss through the driveline and your rwhp is going to be around 13% less than at the flywheel.
If that was the case the LT1 would produce 1865 lb/ft of torque to the wheels simply by swapping 2:73's for 4:10's. lmao (455x4.10=1865)
Old 07-02-2016, 04:10 PM   #5
ender2664
Drives: 2016 2SS
Torque is effected by gearing.
ender2664 is offline   Reply With Quote
Old 07-02-2016, 04:19 PM   #6
tcal780
tcal780's Avatar
Drives: 16 1SS White M6
You are correct here, talking about HP, however, torque is multiplied by the gearing.
tcal780 is offline   Reply With Quote
Old 07-02-2016, 04:32 PM   #7
z28guy30
z28guy30's Avatar
What am I missing then? The 2016 Camaro SS produces 455 lb/ft of torque at the engine. In the dyno graph below a bone stock 2016 Camaro SS produced 400, 402, and 405 lb/ft to the rear wheels.
The 2016 Camaro SS (automatic) has a differential gear ratio of 2:73.
2:73 x 455 = 1242 lb/ft of torque to the wheels. <--- According to the article.
Old 07-02-2016, 04:44 PM   #8
TSloper
The dyno knows what the effective drivetrain ratio is and divides accordingly.
Old 07-02-2016, 04:56 PM   #9
Zeke.Malvo
Zeke.Malvo's Avatar
Drives: 1969 Mustang MaCh1
No it does not know the effective ratio. a DynoJet works backwards, it reads hp and calculates tq (or not at all if you don't hook up the tachometer, and it'll print hp based on mph).
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtq
T56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear
Zeke.Malvo is offline   Reply With Quote
Old 07-02-2016, 05:05 PM   #10
z28guy30
z28guy30's Avatar
That I am aware of since the dynojet is an inertia type dyno which output is measure by the speed of the drums compared to a load type dyno like the mustang dyno's.
I am just having a hard time grasping the concept of if actual torque to the wheels is around 1242 lb/ft on our cars why does the dynamometer give you a different reading?
Old 07-02-2016, 05:07 PM   #11
Zeke.Malvo
Zeke.Malvo's Avatar
That's exactly what you would do. Torque is multiplied through the gears. Say with stock gearing, you barely chirp the tires in 2nd, but with better gearing you blow the tires off. The engine didn't make more power, but more torque was now available at the wheels.
That's why a high revving low displacement engine can do fine with proper gearing.
Old 07-02-2016, 05:10 PM   #12
z28guy30
z28guy30's Avatar
Can you explain why the rear wheel torque results are lower instead of being much higher due to torque multiplication on the dyno graph then?
Old 07-02-2016, 05:11 PM   #13
Zeke.Malvo
Zeke.Malvo's Avatar
Because the dynometer doesn't read torque at all, just calculates it based off of horsepower and RPM.
Old 07-02-2016, 05:31 PM   #14
ender2664
Drives: 2016 2SS
Isn't it the inverse?
