Drives: 2016 Camaro 2SS Join Date: Sep 2009
Many of our customers in both the GM and Ford segments of our operation, have ride height issues after lowering their vehicles.
Some very common complaints after lowering vehicles are: -Car did not drop much in the rear -Car is sitting lop sided -Car is making noise now -Car feels very unstable and floaty -After lowering the car, some of the bushings have worn out Many times, it is simply due to not loosening all of the suspension pivot point bolts, and re-torquing them to their specific TQ values when the car is sitting on all (4) wheels/tires - loaded. The best way to perform this is get the car on a drive on lift, or blocks or drive on ramps. The car needs to be level and sitting on all 4. Loosen all of the suspension pivot point bolts enough to where there is no load on the nuts. After ALL of them are loose, go ahead and RE-torque them all to OEM specified values. The pivot points that need to be "indexed" or "clocked" or "timed" are any of the suspension mounting points that have a rubber bushing, as pictured below. FRONT (where there is rubber) ***TQ Values are 81ft/lbs for all of the trailing and upper control arm*** ***TQ Value for the camber adjustment eccentric bolt on the LCA (bottom pic) is 111ftlbs*** ![]() REAR (where there is rubber) ![]() ![]() ![]() ![]() ![]() ![]() Hope this helps! Happy Modding! Last edited by BMR Tech; 06-30-2016 at 09:26 AM. |
SABIO
Knowing the proper way will help.
Thank you for taking the time to clarify. I plan to re do in a day or so.
![]() Drives: 2016 Camaro 1SS Join Date: Jan 2016
Hey Kelly, do you have any of the torque specifications on the Gen 6 Camaro SS for the suspension parts? Thanks for this post. It has been helpful.
2016 Nightfall Gray Metallic 1SS 6MT, Edelbrock E-force supercharged, Killer Chiller with 3-way bypass, catch can ***FOR SALE, MESSAGE ME IF INTERESTED***
Previous: '12 Mustang GT 6MT (12.47 @ 115.88) '09 G8 GT (11.86 @ 120.47) '05 GTO 6MT (slow, lol) '01 Grand Prix GTP converted to turbo, high 11's |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
This should be a sticky.
![]() Drives: 2016 Garnet Red 1SS Join Date: Feb 2011
Do all these points get loosened during an alignment? Would an alignment alone get the job done?
Toyota Tech
Drives: 2SS A8 Join Date: Jul 2014
GREAT INFO BMR! Ive always been a UMI guy but man u guys take it to the next level!
2016 Camaro SS A8 Roto-Fab CAI: Drag set up 11.9 @116
Sold 95 Camaro Z28 Cam:Bolt ons: 12.3 @114 Sold 2013 Chevy Crzue LTX |
#7 | |||
The beauty is, they should also all use a simple 18mm wrench and socket set-up. ![]() I won't argue that! Quote:
Maybe with your 2016 you can swing on over to the BMR Team. |
#8 | |
Is an alignment a must with your lowering springs?
2019 Camaro ZL1 - A10
2016 Camaro 2SS - A8 - NPP - SOLD 2019 Audi Q5 - Premium Plus 2007 Tundra Limited - TRD Supercharged |
#9 |
![]() Drives: 2016 Camaro SS Join Date: Apr 2016
Thanks for the info and torque specs.
16 2SS 6MT NPP White | MRR | ACT | JBA | SCT | C7C
04 Ram 2500 CDT 4x4 Quad 91 Miata 1.8 Feal Wilwood Track Car 1morproject |
#10 |
SABIO
Thread posted about GM procedures for installing performance suspension.
All they do is drop the lower control arm. Lower control arm bolts are 111 ft lbs. You also have to take out lower shock bolt. All 3 bolts are single use! Discard them. They are torque to yeild bolts GM does not call out clocking bushings. Now I have to order new bolts.
#11 |
Toyota Tech
#12 |
OEMs have always recommended replacing suspension bolts after loosening. When you read the service manuals from GM, Ford or Chrysler they will always call for new hardware. There are several reasons for this, primarily liability.
However, in almost 20 years, we have YET to replace any bolts on any of our many many many cars. BMR as well as myself personally, have 1000+ HP cars that have made hundreds of passes and 1.2 sixty times, and we also torture test our cars on road courses with Hoosier race tires. While I won't sit here and tell people that replacing bolts is a bad thing, I will state that I have never seen it necessary. When you go get and alignment for example, on any car made, the alignment is performed on hundreds of thousands of cars on the road as I type...by loosening and re-torquing OEM suspension bolts, without replacing each time. (food for thought) As for the torque to yield - I have not seen this to be true. When I think of a TTY bolt, I think of a cylinder head bolt, or of the like, that requires a multi step torque method. For example...TQ to 45ftlbs, loosen 1/4 turn, TQ to 55ftlbs, loosen half a turn then tighten one full final turn. Bolts with this type of TQ method are 100% single use. The bolts on our 2016 Camaro have been removed atleast 15 times and re-torqued to their OEM values. They easily hit their torque value without excessive stretch or yielding. My recommendation is, when re-torquing the bolts - feel for "give" in the bolt. If the bolt yields, the TQ wrench will keep turning right before the TQ value is met. As for the LCA bolt - I completely missed over that! I gave all of the values for the Upper and Lower Trailing arms etc. Thanks for the input Bradford! |
#13 |
I would recommend editing the original post and adding the torque specs there, and updating the procedure as needed. So that keeps all the necessary info in one place.
#14 |
マスタング = 遅い
